Redeth's 1989 4Runner Resurrection
Old Feb 12, 2013 | 09:33 PM
  #1001
ToyoTech559's Avatar
I am due for rotors and will be looking for a review on those eBay black rotors. I wish they would stay black even after break in
Old Feb 13, 2013 | 08:51 AM
  #1002
Redeth005's Avatar
Originally Posted by Co_94_PU
Haha, got side tracked and lost and had to go back and make sure i was still in the right thread for "insulation issues". You guys all look the same on the Web
IIRC the older 4runners like the newer ones(95's), are open to the enviromnment in the rear quarter areas. This leads to the rust rust issues due to mud accumulation and condensation. And it's just damned cold.
"Frost King E/O 12 in. x 15 ft. Self-Stick Foam/Foil Duct Insulation" or the Insulated bubble wrap(yeah didn't dig for it's proper name), is available in the HV/AC isle of the big box store.
You want to clean out (probably seal, por15?) and affix this stuff inside the rear quarter, between the outer and inner panels, to the inside wall.
The self adhesive stuff would probably be ok w/o any additional securing if the panel is properly cleaned. For the bubble wrap stuff I'd use a few squares of sheetmetal and rivets for extra bracing, under the upper trim and other hidden/out-of-sight areas. A good foil tape can be used to build the box areas around the storage cut outs. Then seal the rivets with a dab of silicone chaulk.
If you're not using the self adhesive stuff you might be concerned about condensation, a few strips of tyvek or tarred-paper should ease that concern. Or just go whole hog and rubber-ceement/silicone that sucker up too to kill any air gaps.
A little bit of ssheet metal fab and you could close up those holes, almost completely, just don't forget to put in a few drain holes.
Damn sorry I got long winded again. I really just wanted to say that bubble stuff is available as a duct insulation
Damn dude, thanks for the helpful information. This is definitely a project i wanted to jump on soon. I never really thought about the rusting issue but i guess you're right on that one lol Have you done this whole process on your truck? or do you have a thread that you got this info off of so i can bookmark and refer to it in the future for when i do this upgrade?
Good find on that foam, Richard. Similar to what Mark and I did but we used Sears Right Step anti-fatique mat. As for insulation, that foam would provide good noise deadening and also thermal insulation. To fill in those valleys on bed, just put half-inch strips of remnants of same foam to fill valleys.
Re: Keeping warm, instead of bulky, heavy comforters that don't hold heat much, I suggest you look into mummy or rectangular sleeping bags that use synthetic or down insulation - never cotton. Cotton does not insulate well. For couples, there are single sleeping bags with openings facing each other and would zip together. For cushioning, consider backpacking sleeping pads- my favorites are Ridgerest. Low-bulk, Would not mind punctures and lightweight. You would not need much insulation on bottom. I sleep with only my sleeping bag and Ridgerest on snow.
Hey Ray thanks for dropping by. Thanks for the info. Now that you mention it I actually have a few sleeping bags that i plan to use. I will eventually be doing this mod that you guys have all done/talking about. But as of now i have bigger problems to attent do that hit me all in one shot this past week on the truck(i'll explain after the the quote replies )
But for this next off road trip i wanted to just use 2 memory foam toppers(4" of foam) with 2-3 nice cushiony comforters on top of that foam so i can get more of a comfortable sleep, Then i wanted to use the sleeping bags with maybe 2-3 nice furry blankets(SUPER WARM) i figured that will probably keep us warm enough; at least for just this trip. I might get to all the insulation stuff after this trip.
Originally Posted by Grego92
EDIT: Oh never mind!!!! you are doing some upgrade/conversion....not stalk
Richard check the prices on Aisin BMT-051 (Make sure that is what you need)
http://www.amazon.com/Aisin-BMT-051-...1&s=automotive
or Check Advics BMT-051
http://www.rockauto.com/catalog/x,ca...2Bfor%2BADVICS
If that is your part, you shouldn't be paying more than $70 for OEM. Even if you choose the Aisin part it will likely come in a Advics box but still might have Aisin stamped on it. That's exactly how my new master cylinder came....advics box but aisin stamped on it. I think once all the Aisin stamped parts are gone they will likely start coming with Advics stamped on them.
Aisin, in name, no longer make brake components. They are now made under the Advics name.
Ha yea i was took a look at the links you sent then i saw you edited the post. lol Yea I figured if i need to replace my Master Cylinder Then i might as well upgrade it for better braking power then going with stalk. I was eventually gonna do this anyway; only i didnt plan to do it this soon haha. Oh well stuff always happen when you least expect it. I'm glad i had money saved up for such an occasion lol
Yesterday based on the info You and Mark gave me i figured i'd get the advics name. I ended up going with the one from NAPA. Here: http://m.napaonline.com/parts/PartsD...401_0257354893
Not bad. It was $85 Well total(tax included) came out to $92
I went to Mark's house to pick up the connector for this Master cylinder last night I'd like to jump on this project ASAP at least before next months trip.
Old Feb 13, 2013 | 08:55 AM
  #1003
Redeth005's Avatar
Now as for problems ive ran into this past week, Obviously my Master Cyl being one of them i also had my rear window motor go out too We were lucky enough to be able to roll my window back up but i dont think it's gonna work anymore lol.
Now this is also something i wanted to get to work on before the off road trip because i need to get in and out of my truck lol gonna be a pain in the arse loading and unloading everything through the front seats lol
EDIT: (add on)
Another thing i think i might be having a problem with is with my metal brake lines that lead into the master cylinder. It doesnt look like mine will be long enough to be able to mount onto the new location of the new master cylinder.
When i looked at Mark's M.C. I seen that you guys with 4cyl MC's have a bit more brake line to play with and bend to your liking then us people with the 3vze. I really wanna avoid kinking my lines when i install this new MC.
Mark mentioned Flexline or Flexible Brake Line. Ive researched this and ive found a few already, but id really like to just walk into a store and grab it myself then ordering it. So i called Autozone and O'reily auto part stores and none seem to even know wtf im talking about. I also called NAPA and they dont seem to know what i was talking about either. what the heck man. i know these things exist so why cant i find these lines?
Old Feb 13, 2013 | 09:39 AM
  #1004
ChefYota4x4's Avatar
https://www.yotatech.com/forums/f116/budget-4runner-rear-window-motor-replacement-209572/
Old Feb 13, 2013 | 09:44 AM
  #1005
http://www.pirate4x4.com/forum/toyot...ow-repair.html
Old Feb 13, 2013 | 09:47 AM
  #1006
http://www.fixya.com/cars/t1892160-1...ailgate_window
Old Feb 13, 2013 | 09:58 AM
  #1007
Sorry bout the guy, lol, but lots of info...
http://m.youtube.com/#/watch?v=uI7tIPPEMw4&desktop_uri=%2Fwatch%3Fv%3DuI7tIPPEMw4
Old Feb 13, 2013 | 10:23 AM
  #1008
Co_94_PU's Avatar
Peel and seal thread here. I did a quick scan of that thread alot of it is sources and safety info, not a lot of howto, and noticed there is not alot of metal in the older style to attach to on the inner side. The 95's are solid metal begining just in front of the storage/speaker area.
Ive not done it on my pickup truck, there isn't very good access to that area, It could be done I guess maybe with the bed removed. So far the only bolts I've found are for the forward panel, the rest appears to be welded.
Old Feb 13, 2013 | 10:24 AM
  #1009
Co_94_PU's Avatar
Think you lost some of the url maybe, "video does not exsist"
Old Feb 13, 2013 | 12:01 PM
  #1010
Redeth005's Avatar
Mark, Thanks for those Tailgate window links. Thats gonna come in handy for me.
Co_94 That Peel n Seal thread is gonna be really helpful. Thank you too
I edited the last post and put the new text in Blue
but in case you're laze to scroll upward here it is lol
I found this on the NAPA Website just now:
http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
Are any of these the ones i should be looking for? they seem kind of on the thick side to me.
Edit:
I just spoke to a different guy from NAPA just now. He said they dont have flex line for brakes. But they do have some different length straight ones that we might be able to bend to shape how ever we need. I'm gonna drop by to see what exactly this guy was talking about for those lines. Who knows maybe I might find something that will work.
Also they have the rear window motor. For something like $56 for one. Then the other os $102. So I wanna see which one is the one for my truck too. Ill let you guys know how it goes.
Old Feb 13, 2013 | 06:00 PM
  #1011
Co_94_PU's Avatar
Yep that is the stuff, note the working pressure on the items on the first page are the highest. They also inverse scale with the size,eg smaller hose higher working pressure. For forming hardlines you'll need some "special" equipment, anti kink springs that fit inside the tube. The stuff on the first page is rated for both air and hydraulic brakes.
You can probably get the same piece thats on the tire end and it'll fit right up, or might need some adapters. That would save you having to do the cut and flare on your stock lines, and it's abit more reliable. Don't forget to make flares and double up on the clamps.. Yeah me and compression fittings don't get along, even less so when it's high pressure.
Not sure on the pressure rating required. Anything over the working pressure rating will degrade faster, but the important bit is the burst pressure for sure.
Old Feb 13, 2013 | 09:49 PM
  #1012
Redeth005's Avatar
A couple of things i bought today.
Flare Wrench set(Sears) - about time i bought some and a basic Brake bleeder kit for $6(autozone)
Here is my new Master Cylinder, I bought an extension brake line. It's only about 6" and i also bought the converter or adapter for the brake line(w/e the real name for it is) lol The reason i bought these 2 things is because i dont have to make the line a heck of alot longer. I really only need about 4-6 inches. so with this adapter i will connect my current brake line into one end then the extra 6" into the other side. then that will give me the extra length i need to mold and fit into the new master cylinder.
Note: Keep in mind you see this master cyl has both brake line inputs on the side there.
This is my current MC. See that moth my lines are located on the top part of the MC.
On this picture you can clearly see that the line toward the tip of the MC headed down to the 3way splitter thing on the bottom part will not be a problem for me to bend and because it will pretty much already be where i need it to be.
Now as you can see in this next picture you can see that the other line closest to the reservoir will end up being a few inches too short. Which is why i got that extension.
So i just plan to run this brake line a little further to the right side of the booster(according to the picture) and around the new reservoir, then bend it to fit just right.
I figured that going this route isn't too bad. those 2 pieces only costed me about $5-6 at PepBoys auto parts. So if it doesn't work then oh well. but i think doing this route should work for me.
Here is another shot i took. Just to show the other side.
I watched a couple of YouTube videos today on how to bleed a master cylinder and how to brake the brake lines. I think after a few more views i might have a good idea of how to get this done.
Here is one video i liked for bench bleeding the Master Cylinder
Here are a few i liked for bleeding the brakes
Old Feb 13, 2013 | 11:10 PM
  #1013
Co_94_PU's Avatar
What is that sexy shiney bit of kit on your fire wall, looks like maybe a fuse holder. That shiney red caught my eye, it's about what my paint is suppossed to look like, it looks so out of place
So about half way thru that last video I learned something, the assistant is supposed to get the easy clean comfortable job Gonna have to have a few words with some ppl!
Looks like you're all set, remember to have fun!
Old Feb 14, 2013 | 12:24 AM
  #1014
Cyberhorn The Dragon's Avatar
I WAS just! about to ask the same thing LOL
heres how mine looks redeth i didnt have to bend the first line at all it was on the side already, the front line i did have to reshape it to line up with the port my old one was leaking from inside the MC like yours i cut the wire off the old MC connected it up to the one for the new type as an adaptor works great an doesnt cut the harness
Old Feb 14, 2013 | 01:48 PM
  #1015
Redeth005's Avatar
Yea that's the fuse holder for my ampliphier. I've been meaning to relocate that wiring for a few months now haha. I want to remove it and instead of running the wire through the driver side firewall then under the carpet to under the passenger seat(where the amp is located) i wanna just run that wire straight from the battery and somehow into the passenger firewall. It'll save on wire and plus i have no need for the wire to loop around the whole cab like that lol its pointless. Ive just been really lazy haha! I'll get to it though i promise. Damn That just motivated me to wanna get it done now. Thanks guys lol
Hey William, Thanks for the picture. Yours came out pretty clean. Yours is a 4cyl motor though. the metal brake lines are pretty much already there and are long enough to do the job without an extension(At least thats what i noticed when looking at Chefyota's MC) My middle line on the other hand doesnt run along from one side of the Booster to the other side then to the MC like all your 4cyl trucks do. Mine only goes about 1/2 way as portrayed down below. So thats gonna be the one that im going to extend.
Old Feb 14, 2013 | 02:14 PM
  #1016
Redeth005's Avatar
I just realized that my Brake booster looks like the one that Mark is upgrading to. the Dual Diaphragm Brake Booster. Thats pretty nice. Looks like I'ma have the perfect combo there lol
Old Feb 14, 2013 | 03:33 PM
  #1017
OOOH, look at that sexy booster! ^^^^ Who's is that? hahahahaha
Congratz, hope this goes without hiccup, should no problem.... HAVE FUN!
Old Feb 15, 2013 | 09:12 AM
  #1018
......^^^^^^^ is that working?
Old Feb 15, 2013 | 09:46 AM
  #1019
Redeth005's Avatar
its working on my phone.
Old Feb 15, 2013 | 02:33 PM
  #1020
Then WORK IT MANG! Lol... Best wishes on all that!
