rattlewagon's 1992 Pickup Build-Up Thread
Old Jan 26, 2014 | 10:03 PM
  #341
ToyoTech559's Avatar
Nice job on the stud. Good to know too
Sweet job on the frame notch. Going all in on the SA is gonna be awesome once done
Old Jan 28, 2014 | 09:24 AM
  #342
rattlewagon's Avatar
Got my tanning booth set up
Got the frame finished and boxed on all sides and mounted the steering box.
Like a glove.
And the passenger side. I trimmed the smaller spacer on the other side for more up travel but didnt do this side because I didnt need to, but it looks pretty goofy being so tall. There is about 1/8th of an inch between the hemis at the closest point. Plenty of room!
Old Jan 28, 2014 | 09:29 AM
  #343
Red Wagon's Avatar
Nice work and shop.
Old Jan 29, 2014 | 12:17 PM
  #344
Thanks Toytech and redwagon!
Im pretty lucky to have access to this shop, I would be doing it in a small 2 car garage without it, using just hand tools.
Group pic from Sat night, One sammy is getting the front end welded and the other is in.. well.. just because he wanted to tinker! Haha.
Old Jan 29, 2014 | 01:08 PM
  #345
ChefYota4x4's Avatar
Sick stuff! You're a maniac! .... In a GOOD WAY! Lol... Great shop, btw
Old Feb 5, 2014 | 05:07 AM
  #346
julsruls's Avatar
awesome build
Old Feb 5, 2014 | 05:50 AM
  #347
Thanks Chef and julsruls!
Went down to change the oil in the Fiances A6 and got a little bit done.
The steering shaft needed to be about 1" longer due to the box being farther forward. So I cut a sleeve and Ill weld it up next time Im down there.
Old Feb 17, 2014 | 03:44 PM
  #348
Sittin on all 4s.
Tierod clearance
Flexed it out a little better with some help of the excavator
And got my tank mounted. And started running break lines.
Shocks and front drive shaft coming next.
Old Feb 18, 2014 | 02:44 AM
  #349
FourwheelinVT's Avatar
Looks awesome! Good job on the SAS. Can't wait to see a little snow on those tires!
Old Feb 18, 2014 | 06:58 AM
  #350
93Xtra-Cab's Avatar
Looks good, rattlewagon
Old Feb 18, 2014 | 08:59 AM
  #351
rustED's Avatar
Nice work, looks real good, can't wait to see some wheel in pics!
Old Feb 18, 2014 | 09:25 AM
  #352
Roark's Avatar
Looks good! Can't wait for the action shots!!
Old Feb 21, 2014 | 07:33 PM
  #353
Thanks guys! Action shots soon I promise.
Intake is a little wonky, but it cleaned up the engine bay, which is what I was after.
Front shock mock up. They are the 12" ford shocks with ford shock towers. Set for 3.5" up travel and 8.5" down. Should be plenty of travel.
Finished pic, Bumpstop is some small polypro (or something) on the spring plate, and bumps against the frame, just before the tie rod hits it.
Rear shock setup. Same Ford shocks and towers, but cut the towers down to fit.
Made a square shaft out of 2 single joint yokes. 8" droop and 4" stuff. Used 2.5" Receiver tubing (no inside seam) and some 2" .25 wall tube for the inside part. It required re drilling the mounting pattern on the t case output, but wasnt a big deal. . (more angle than clearance the CV joint) And took it for a drive!
I need to get a small piece of gas line tomorrow after work, but expect some action shots soon, and plans are now being drafted up for a bed/cage
Looks like I got the RUFs and Chevies height to match quite nice.
Old Feb 22, 2014 | 01:52 AM
  #354
Yeah buddy! It looks better with some snow on those wheels instead of all that dust! HAHA
I'll be over later today to help with more testing.
Old Feb 22, 2014 | 05:56 AM
  #355
bone collector's Avatar
Looking great man!! I like the shock towers!!! awesome idea. go wheel that bad boy and then build a bed cage. awesome and inspiring work as always!!!!
Old Feb 23, 2014 | 04:32 PM
  #356
Some out side pics! It will run for a few minuets, then dump fuel into the engine. Going to start by putting the wonky intake back to stockish and checking the AFM and TPS.
You can hear it start run bad right after the rpms come down. Had to shut the camera off to limp it back to the garage.
[youtube]HlKAieJ0Tfw[/youtube]
Old Feb 24, 2014 | 05:48 AM
  #357
gilbert72's Avatar
looking good!!! really liking that sas in there, hope you get her purring like a kitt in no time!
Old Mar 3, 2014 | 03:29 PM
  #358
meatmonkey's Avatar
I am greatly saddened to see those yellow piece of junk Monroes on an otherwise spot on build.
Do yourself a favor and take them back before you get weld spatter or dirt on them and pick up some kYB Gas-A-Just's for not much more. Even if it's a $100 difference, it's worth it.
I can't explain in words the difference in stability and ride quality between low end low-pressure garbage twin tube shocks and better sealed, high-pressure mono-tube shocks.
Funny, I put the gas tank on my blue truck in pretty much the same place. Offset it just enough to fit a milk crate alongside it.
If you insist on using one of those dumb open element air filters (I've been guilty of it too), at least build a good splash guard around it, otherwise in deep water/mud the fan will literally force feed your motor liquids.
The beauty of the stock airbox is that the paper filter will ussually sop up enough water to stall the engine before it totally hydrolocks itself. And truth be told there it nothing to be gained by a bettter flowing filter as the MAF itself it the greatest restriction on airflow.
Make sure to put two small tubes going from the frame as far up those Ford shock towers as you can. Like the same 1" tubes that come with most conventional shock hoops. Otherwise the Ford towers will fatigue and crack just above wherever they are welded on the frame. Yeah, I know a factory Ford setup uses something like 3 rivets to hold them in place and they don't break often, but I'm convinced that's because riveted C-channel frame flexes more than a boxed, welded, Toyota frame. Frame no flex=shock tower flex
Is your receiver tube driveshaft loose at all? I've heard that the receiver stock is slightly oversized, and it seems like most 2" recievers are kinda loose fitting.
I ask because if so, you'll want to redo it. It will bind when under torque and not slip easily. This will kill diff pinion and transfer case output bearings.
I've made one with conventional 2x2" inside .25 wall 2.5x2.5 and had to grind a small groove up all the way up the male side to clear the weld on the inside of the 2.5.2.5. Installed a countersunk (needle fitting required) grease fitting on each side of the female, midway into the shaft overlap, and it was no-slop yet very easily slipping.
Tell me your going to be making some sort of solid bracket for the short piece of solid line coming out the the caliper? Ok, I'll stop now I'm just being OCD. I wish my woods truck was this far along.
Old Mar 3, 2014 | 04:23 PM
  #359
I got them for practical nothing, so they are staying on for now..
Already been put back to the the stock box.
They will be braced in to the motor amount.. when I get time. Haha.
Is your receiver tube driveshaft loose at all? I've heard that the receiver stock is slightly oversized, and it seems like most 2" receivers are kinda loose fitting.
Its a bit loose, But I dont think it will slip all the way out enough to be wobbly.
Wasnt go to..its only a 3" hardline, but now that your making me feel bad about it. haha.
Nit pick away!
Old Mar 5, 2014 | 06:47 AM
  #360
I think my poor running was a bad 02 sensor/mount. One of the studs broke off the exhaust so the 0s sensor would blow up out of the pipe when I reved it. Taking the pipe off to repair it left me with broken/stripped studs in the manifold, so that came off so I can get the broken bits out. 1 step forward 2 steps back.
The flowmaster is beat and getting replace with a punched out Harley sportster muffler. Should be interesting.
