RAD4Runner's 1986 4Runner dlx Build-up
#1001
Rad4Runner
Hope you stop by and say hello when your going through Cedar City 3 miles off the 15
Don't know much about the mechs/shops cause I live here!
When do you plan on being in this area of your trip?
#1002
Awesome! Always cool to meet Yota Brethren. No exact dates but tentative is next Friday the 27th. Then return trip a few days later. Will ping u.
#1004
#1007
Rear Body Panel Storage Updated on Separate Thread
#1009
CONTINUING THE DISCUSSION ON CARGO TIE-DOWN HERE.
keywords: cargotiedown, reardeckcargo reardeckstorage
#1010
Wrong Starter Relay Wiring: Affected Models Documented
1986 22RE Manual (rad4runner's printed FSM ):
1988 22RE Manual (From FSM PDF):
TRUCKS FIXED BY REWIRING: phantez's (https://www.yotatech.com/forums/f116.../#post52299513)
1989, 22RE, Manual (cr@ves4wheelin@yotatech):
Griswald's 1989 22RE: http://www.toyota-4runner.org/classi...ml#post2730870
1989-1992 4Runner V6, 1989-1990 Pickup V6 (schematic shared by DrCreosotes@yotatech) Wired Wrong:
I am puzzled, however, because while 1989 V6's are wired wrong https://www.yotatech.com/forums/"https://lh3.googleusercontent.com/QTko5RDrc1veqOBwdJtvhGT5tNboIqKrY57DBE1rZAdWkbG_-gbvHQiE73SwuUvw8xEPM5drMVMlPsSIjt3pMVrKKGeKfaPMnrI OQjwAx-BCK4eg5btc2AFaUQ50pW0nvvDUErM00j5ZlfI5h_wbgtxUc3qM LjWWb24oVgA8mACTFgEksgfWxuczZHMI-MKuR5RsmWeRMEVch6YnEh2dzFlABn5sYdPIcO3pql6M_udz-kSx-RSiBvNK-8rxLOHCo2xWFjKyNaiU0YCNBd139N7AmIKjF5Yo9gkClKxBd6y djdRiqPZZTZOXJls2ASSFu777x8AlXwp0C8l3U7D02iX9LpRp0 ZoxU6sMklLvkTsXzFM-RAGAFI-10IgpOUqdyrKSOblZvzLUqps9-LvklRGdQJCvDMkMz5Qmt_Se7Ofri6I0zvDUr-Nswxn7dA5ynBQZEraChxyPnvodeHmmOMapZuscniT3n7t593ew i5kCW6tAcaAOOTrhKfMliA4Qi27E6qCKngwipzNzcizyQLms--Q7_rqWbXTm3sRyj11Y7GdUzSjfyeDMRLrgb0MYGFuLSRbqrpZp 0GDdzPlytals3hIDZVItKRHRJHZl6iOD48N0RfbY=w1024-h609-no""]this schematic[/url] of a 1988 V6 3VZ posted somewhere in the forum shows correct wiring. Perhaps the 1989 engineer did not know of the correction and re-used the wrong schematic?
HERE's HOW TO FIX IT:
1) Verify that the starter solenoid, contacts and motor are good (THIS WAY), AND...
repeat: AND, not OR.
2) Fix the starter relay problem THIS WAY.
keywords: clicknocrank, clickonly, no crank, clickonlynocrank, wiringflaw, affectedmodels
#1011
Just make your own starter relay like this.
Current Flow here:
The 3rd case here.
#1015
#1017
Mount Rainier is such a beautiful place!
One day I hope to climb to the summit. I need to get in shape first!
Love camping around the base of the mountain where there are some great campgrounds amongst the trees.
#1018
my write-up for the belts is in this thread: t4r upkeep thread
simple to do with basic tools. a cut-off/grinder will help.
#1019
Mine came from a '92 Toyota pickup. They have plastic covers over the reels. Be sure and get the bolts too. The roll bar is tapped to accept the bolts perfectly.
#1020
Even after I cleaned my starter relay contacts, and after months of being able to start with no issues, the "C.O.R. Click-only" problem struck again. I reviewed the schematic and found the electrical engineering blunder explained here.
Below is the clean and robust fix for the starting (cranking) circuit wiring flaw. No additional or replacement parts, except for wire and an optional kill switch.
AFFECTED MODELS:
May 1986 to 1988 4Runners and trucks with 22R-E
1989-1992 4Runner V6, and 1989-1990 Pickup V6 Thanks, DrCreosote, for sharing your schematic.
Would appreciate if members with different year-models could verify theirs as well.
NOT AFFECTED MODEL:
According to this schematic, the 1988 4Runner, V6 3VZ does not have the wiring error.
Trucks made before May 1986 may not have the starter relay so this does not apply.
1986-1988 trucks/4Runners with auto transmission do not have starter relay, either. Click-only problem may also occur on them.
Examples:
Those made earlier than May Like richiegrich's Feb, and KidV's do not have starter relay.
For these models, I highly recommend adding a properly-wired starter relay.
Schematic of flawed stock wiring below shows that:
To verify if your stock wiring needs this fix refer to this with notes on how circuit without flaw should work:
To correct:
Cut wire to pin 4 of starter relay here:
Picture here:
Insulate end on harness. This will not connect to anything anymore.
It should like this now.
To find Pin3, look for terminal of 40-Amp fuse that connects to 80A Fusible link. This is terminal 4. Terminal 3 is the opposite terminal. To verify that you have the right Pin3 of FL, measure voltage there. With 40-Amp fuse installed, you should get 12V. Remove 40-amp fuse, you should get no voltage.
Connect (crimp or crimp PLUS solder) wire from Start relay Pin 4 to Terminal 3 of FL.
Fusible Link is in this fuse block:
Terminal 3 is accessible from bottom.
IIRC, this picture shows Terminal 3 removed so I can tap into it.
Verify it is Pin3, such that when you remove FL you do not get +12V, and you get +12V when FL is re-installed.
When you make a tap, make sure you have both mechanical & electrical integrity (i.e., crimp OR wrap around existing wire then solder).
It would be nice to insert a kill switch in wire between FL and start relay. Hide it and don't post where you put it here (duh!). Bonus is that kill switch will interrupt power in the extremely rare case that starter relay contacts get welded in closed position. Final circuit should look like this- [size="3"]simple, robust[/size]:
NOTE: An alternative, so you would not need to dig into fuse block, is connect Pin 4 of starter relay to a AWG 12 wire to a fuse directly connected to battery positive.
UPDATES:
Terry fixed his here
Stanz related repair where he replaced the broken stock starter relay with a 40-Amp aftermarket one is here.
Another one fixed:
AFFECTED MODELS:
NOT AFFECTED MODEL:
Examples:
- High current (12-Amps) to energize starter solenoid passes through ST1 contacts of ignition switch. This puts unnecessary stress on switch contacts, cause pitting, high resistance, too much voltage drop (solenoid not getting enough voltage), and defeats purpose of adding the relay in the first place.
- Because solenoid contacts do not completely close, they will be arcing and/or heating up unnecessarily (like bad connection between power cord plug for electric flatiron makes plug and wire hot), hastening their demise.
To correct:
Picture here:
UPDATES:
Another one fixed:
When I was installing the new wiring, I noticed that when the 30 amp fuse was in place the COR clicked, with the key in the OFF position. When the fuse was removed, the COR clicked 'off'. So it seems i have constant voltage to COR now. Not sure if this mod is supposed to do that or not.
After the truck sitting for a week, I went out to start it and the battery is DEAD. No lights, radio, nothin. I'm not much of an electrician, but i followed RAD4Runners instructions as best i could, and i've triple checked everything and as far as i can tell its wired the way it says. Did i miss something? is there another issue? Any help is appreciated. Yotatech has helped me out countless times before.
