RAD4Runner's 1986 4Runner dlx Build-up
#601
Outer Driver-Side Door Handle Link Clip Replaced
Thanks a lot for your help finding the correct parts, guys!
This is the correct part from dealer:
Yellow Snap/Clip goes into here:
Insert snap into opening on door handle:
Insert Link rod into snap:
Swing snap down to wrap around link rod:
#603
Staff
I have never been ablt to remove those clips with out breaking them. I just automatically assume I am going to have to replace them when I work on the door. I can install them in about 2 seconds but takes alot longer getting them out.
I missed the part where you were looking for clips. I could of posted that part number. I got it in my threads some where. I like to put some sound deadner in the doors when I have the panels off. It helps on the noise.
If you have a problem with the interior handle not opening the door easily, I have a cheap fix for that if you need it.
For a second I thought may it was the same truck you and your friend had but noticed the different interiors. It still would be like a step back in time. Bet he wishes he still had his.
#604
Yes I have peel n stick sound-deadening on door, then over that, insulating Ensolite. Had I known about the Frost King foam and foil like Chefyota used, I cud have used that, too.
I'm also converting the inner door panel to something more friendly to field tear-down.
(1) Will replace hidden fasteners with expansion nuts, finishing washers and screws,
(2) Already separated the main panel from the window sill vinyl,
(3) Will remove the velour cover and replace with spray and wipe vinyl. Need to find material for that... OR,
(4) Replace the board with plywood that has nice grain, stain and oil finish it. Better than a Lexus' fake burlwood! LOL! And I get to enjoy old-school wood finishing.
#605
Console Rear Window Control/Coin Holder Into Cup Holder
Hi folks,
Anyone out here interested in fabricating / modifying the rear window control/coin holder insert so, after switches are relocated, it can be used as a single cup holder? It would look very much like stock.
Anyone who might be interested in buying so fabricator ca tell us the price?
I have ideas but no equipment nor experience doing Fiberglas or fabricating work.
Switches removed:
Insert modification in process. Common coffee mug sits on the existing "bottom" of insert:
Opening in existing bottom would accommodate skinnier travel cup:
I would be glad to send you mine if you'd like.
Regards,
RAD
Switches removed:
Regards,
RAD
#606
Schematic/FSM in Smartphone
If you already have the PDF for your FSM or schematic, but drive your truck a lot but leave your computer a home, I recommend saving PDF's in your smartphone.
#607
Staff
That would be handy to have. I had a smart phone and went back to my old flip phone. Being half blind and a small screen drove me nuts.
I like the cup idea. Eventually I want to move my switches near the ashtray and that would be a great place for a drink holder.
#608
It is not difficult to relocate switches and it is easy to remove the black insert and replace with cup holder one.
#609
Staff
Seen somewhere that you was wanting to see some information on swapping out the Brake Master Cylinder. You have always been great about helping on my electrical issues. I dropped my phone in the lake and it will be a day or so before I get another one, but if you need help, I can step you over the phone on how to swap one and to bleed a MC.
I would get a disposable aluminum pan for baking for catching oil, a 10mm line wrench, ( a box end wrench with a cut out for slipping over the metal line) and a socket with 12mm (I think, will check to make sure) that holds the MC to the booster. It takes two people to bleed a system, one to open the bleed screw on the slave cylinders and one to pump up the brakes.
Most replacements don't come with the resivoir so you will need a 17mm or 19mm socket to move your old resivoir to the new MC. To bench bleed a MC, you can put it against a firm edge like a wall and a dowel or screw driver to pump the piston in the MC to get the cylinder full of fluid.
I would get a quart size brake fluid and while bleeding the lines, is a good time to get fresh fluid in the system.
#610
Thanks a lot, Terry.
I probably don't need a replacement booster, but just need to inspect what parts are binding. Feels more mechanical than anything else.
Meanwhile, guys, here's a couple of pics from recent posts by Philbert's friends. They do trail maintenance, etc in his memory...
B/R
-Ray
B/R
-Ray
#612
I had to replace my yellow clips recently too. earlier this year. who knew such a small piece could make getting into your 4runner such a pain in the butt.
#613
Concise Starter Relay Re-Wire OR Retrofit for 84-88 22R/22RE Simplified and QUICK
"Starter Relay Re-Wire OR Retrofit for trucks with NO starter relay and those with relays but wired wrong AT THE FACTORY" moved to Classics Thread for ease of finding.
NEW LINK IS HERE
NEW LINK IS HERE
#614
Safe Harbors: trusted Mechs and Shops Along 15 Fwy
Hi folks,
We plan to spend Thanksgiving in Las Vegas, then on Friday drive to Zion National Park, camp there and back to San Diego on Monday.
I do my best to keep the truck in tip-top shape but, like a good captain I want to know where safe harbors are ahead of time, in case truck happens to have serious unforeseen issues I could not handle with my multi-meter and toolbox.
Do you know of any trusted/good shops/mechs along the 160 mile stretch of Fwy 15 between Vegas and Zion here
How about the 330-mile stretch between SD and LV here?
If you do, pls comment with their location ad contact info. I'm sure it could also help fellow members traveling along same routes someday.
Thanks in advance and Happy Thanksgiving!
#615
OEM Brake Pads PN 04465YZZC0
A couple of online stores I contacted said that PN "04465YZZC0" has been discontinued. Do you know of others that may still carry it>
Also, some online stores list different part numbers for front brake pads that are supposed to fit the 1986 4Runner, like the one below (lists "04465YZZA8").
Should we stick with with "04465YZZC0"?
Is there a difference or are they physically same?
Thanks in Advance!
#616
Found Brake Pads on Ebay
Thanks for the inputs, guys!
Terry,
Thanks a lot!
I bought the one with link you sent on Ebay.
I hope this store got their inventory right this time.
Terry,
Thanks a lot!
#617
Staff
I use ebay a lot and if I have a question, some site you can find their number and they will verify it for you. Not in all cases, but if they have a site elsewhere, you can ask them and avoid them having to pay ebays fees and save a few more dollars. So far I have never had an issue with ebay. One issue I had was with Rock Auto but it was for a part that was not much so I just kept it.
I made that Vegas trip several time but don't know of any safe places. I would like to get back out there again someday.
#618
Service Tools & Supplies, 1986, 22RE, 5-Speed Manual
My notes for quick reference on servicing 1986 4Runner/Pick-up with 22R-E and Manual Transmission...
CHANGE OIL AND OIL FILTER:OEM Filter PN 90915
Oil filter wrench, 74mm, 3/8-inch drive
3-inch socket extension, 3/8-inch drive
Ratchet wrench, 3/8-inch drive
Combination wrench, 14mm, for drain plug
Container to catch draining oil, and other supplies
#619
Replaced Brake Pads
Dayumn! I did not realize how easy and simple it is to replace brake pads on the IFS First-Gen! (I don't know about the solid axles) However, unlike many service items, If I did not read the FSM before performing the job, I could have made a big mess.
NOTE: There is no floating/sliding caliper on the front brake system.
CAUTION:
(1) DO NOT REMOVE ANY SCREW ON THE CYLINDER!
(2) REMOVE ONLY ONE PAD AT A TIME ON EACH WHEEL. Piston on opposite side may pop out when pushing one piston back into cylinder
Inspect First (clearly visible as soon as you remove the wheel):
When slit is no longer visible, it means that the pad is thinner less than the required 1-mm.
Just pull out 2 clips and 2 pins, and the pads are ready to come out:
Use old pad to push piston back into cylinder.
(BTW, these Western Safety gloves with genuine leather palm and fingertips do "Fit Like Gloves" are a great value ($6 bucks a pair from Harbor Freight). An advantage I found is when exposed to petroleum based chemicals (like engine oil) leather does not get as sloppy as synthetic palms. I prefernot to buy made in China, but most gloves are, anyway.)
Use padded handle of tool to push piston back if still needed:
I used anti-squeal grease on the pads.
CAUTION:
#620
Cold! Or Not So Cold Hard-Start Issue came back
Hi guys,
At first hard-start went away for over a year after I fixed the CSI connector that was not properly seated. However, it came back and seems more persistent this time. CSI timer switch and CS injector resistances are within specs.
Seemed like a COLD-start issue at first. However, this time, I merely stopped at OReilly's to buy stuff (10 minutes max) and when I came back, got hard start again.
I will check AFM flapper as Terry suggests and also observe CS injector spray. I added comments to this thread.
