magnet18 1986 build thread
Old Nov 4, 2018 | 10:46 PM
  #261
RAD4Runner's Avatar
Alexman / Arlindsay and either 22RE Performance or LCEngineering have youtube videos that show how to apply the sealant on the half-moons.
Old Nov 5, 2018 | 05:21 PM
  #262
magnet18's Avatar
thanks Ray I'll check that out
So the evergreen kit came with a bunch of o rings... Can anyone ID them? I'm not sure what they're for
Also, i checked the fsm, and i searched... Couldn't find a good walkthrough on replacing the input seal, so hopefully that means it's so simple I'm the only one dumb enough to ask how, or I totally missed it
I assume I'm gonna need to drain the transmission and get new fluid, and it looks like a gasket for the front plate
Old Nov 5, 2018 | 06:19 PM
  #263
Melrose 4r's Avatar
5 Year Member
I think you are looking at injector Orings, distributor shaft and thermostat housing ring.
Old Nov 6, 2018 | 03:51 AM
  #264
Co_94_PU's Avatar
Lower left side rubber ring, could be the heater pipe. I don't exactly recall the measurements
Old Nov 6, 2018 | 04:41 PM
  #265
magnet18's Avatar
Got the injectors out to send out and got the lower intake manifold installed
None of the o-rings were the right size, so i used plenty of rtv for the water pipe on the bottom
Got the iacv off to test, hopefully between the iacv and injectors my hard starts will be resolved
Old Nov 6, 2018 | 06:21 PM
  #266
magnet18's Avatar
Re-use transmission fluid?
i put nice new redline synthetic fluid in 10k miles/2 years ago... When i replace the trans input seal, is it okay to catch it in a new clean container, filter/strain, and re-use... Or is that an insanely bad idea and I should eat the $70 and get new oil again?
Old Nov 7, 2018 | 04:06 AM
  #267
Melrose 4r's Avatar
5 Year Member
10k Miles,$70? Yeah I’d reuse it if it looks ok.
Old Nov 7, 2018 | 06:16 AM
  #268
RAD4Runner's Avatar
Second that.
I do not know what to use to strain, but when I was in the Navy we used a white lint-free fabric for wiping critical hydraulic parts. That would probably work.
Old Nov 14, 2018 | 09:04 AM
  #269
Melrose 4r's Avatar
5 Year Member
Makin' any progress there Magnet?
Old Nov 14, 2018 | 09:15 AM
  #270
magnet18's Avatar
Yes, haven't updated because ive been flip-flopping wildly between this, motorhome, and grad school
over the weekend i started in this and ended up on plumbing issues
Anyway, i got the transmission input seal replaced, and my injectors out to RCfuelinjection for servicing
I have all next week off work (hopefully), and refilling the transmission and getting this engine back in is on the to-do list. Along with insulating my floor, installing a woodstove, replacing a toilet, remodeling my bedroom, running a new electrical service, and possibly going back into work one day for a nasa meeting
Old Nov 14, 2018 | 09:20 AM
  #271
magnet18's Avatar
I also think my iacv is definitely stuck, 20 degrees and 70 degrees it looked like the same position, so hopefully disassembling, cleaning, and reassembling that will fix it
Old Nov 14, 2018 | 01:40 PM
  #272
Melrose 4r's Avatar
5 Year Member
I experimented with mine quite a bit. I put it in the freezer and at room temp and there was no observable difference in the amount it was open until I applied voltage to it. The orifice should be pretty much completely open when cold or room temp. There is an adjustment you can make to set the position. Then when you apply voltage you can see the bimetallic strip warp to one side. It's not a dramatic change. The spring does all the work. The hot water circulating through it just holds it warm for a period of time after shutting off the engine so the cycle doesn't start from the very beginning each time you start the vehicle. If you have the service manual there is some info in there but not very much.
Last edited by Melrose 4r; Nov 16, 2018 at 11:54 AM. Reason: I had it backwards, it's open when cold...that's what happens when I try to do forum stuff while I'm at work!
Old Nov 16, 2018 | 06:57 AM
  #273
magnet18's Avatar
Thanks for the info, mine seems to be stuck at about halfway, but ilI try hooking it up to 12V at different temperatures, before and after cleaning it
Old Nov 16, 2018 | 07:38 AM
  #274
gsp4life's Avatar
I opened mine up because it looked gross and I was convinced it was seized. The original grease in there was nothing but dry paste mixed with carbon soot. Cleaned with acetone and used Napa silglyde grease, which claims not to freeze, dry out or run up to 400°f.
Much smoother operation and mine definitely had a noticeable difference from 70°F room temp to 0° in the freezer. I believe it was more open when freezing, which makes sense if you think about it's function and operation. It increases air flow to the intake during cold starts.
Old Nov 16, 2018 | 11:59 AM
  #275
Melrose 4r's Avatar
5 Year Member
I had it backwards, open when cold. Closed when hot is correct, as GSP suggests above. What differed from the manual was that mine wasn't closing completely or nearly completely so I adjusted it to allow full closure...I think...open was more arbitrary...and you can't pinch the hose to test as the manual suggests because they are so old and hard.
Old Jan 13, 2019 | 08:36 AM
  #276
magnet18's Avatar
Finally back at this after a not so brief shift of focus installing a woodstove in the airstream
IACV actually seemed quite clean and moved very smoothly and easily, so leaving it alone for the time being
Old Jan 13, 2019 | 08:44 AM
  #277
magnet18's Avatar
Fresh fuel injectors back from RC fuel injection
Old Jan 13, 2019 | 01:43 PM
  #278
magnet18's Avatar
3 hours of progress today, got the intake put together and started on the maze of hoses and wires. I'm telling myself that of it all runs when I'm done I'll take the upper intake and valve cover back off and get them powder coated.
Old Jan 13, 2019 | 02:31 PM
  #279
old87yota's Avatar
Getting closer!
Old Apr 6, 2019 | 04:44 PM
  #280
magnet18's Avatar
Back at it today
New pilot and throw out bearings (those were both a blast, grease didn't work for the pilot, wet paper did, then some fun on the press for the throw out)
Got the transmission fluid filtered and refilled
New oem clutch installed
Got the engine mostly in place and I think lined up ok (, then the biggest hangup of the day was figuring out the dang bellhouse bolts. I'm still confused about why I have one nut for the starter instead of two, one bolt in a bag that says clutch slave bracket when the slave cylinder is totally mounted up... In general why i seem to now be missing a couple bolts when i bagged them all and still have all the bags
Tomorrow I'm going to back the engine up a bit and make sure the gap is even all the way around the transmission and engine, I feel like i could gently squeeze everything together now with the bolts but I don't want to mess up that new pilot bearing
Also need to dig through the electronic fsm to double check bolt locations and sizes for the transmission and starter, and lay out what I have to see what I'm missing
Then comes new spark plugs and all the connections and accessories
The other thing currently catching me up is the exhaust is disconnected where the tube meets the manifold and I'm having a hard time lining that up. Might need to remove manifold. Just a pita.
Pics to come
