the dragons 88 runner buildup/rebuild
Old Aug 8, 2013 | 07:00 PM
  #881
Cyberhorn The Dragon's Avatar
Yeah my guess is still that it does... I believe you need a vice some leather and pipe wrench.
Originally Posted by Terrys87
The shifter and tcase handles both unscrew.
THANK YOU! for all i knew it was a press fit an id have to take it to a vice an pop it off
Old Aug 10, 2013 | 04:31 PM
  #882
well i didnt get to the trans boot but i did get my bumper ends and put my rear bumper on thats a job by yourself i can tell ya
the bolt plates as you can see one fought me one didnt... an i mean it popped an was loose took nearly nothing to take it off the other fought me all the way
drilled the holes out for carriage bolts
and so heres the before
and after YAY looks a 100% better
did realize my drivers side is still tweeked a bit as the gap is nonexistent tween the corner an the marker more adjustments in the bumper needed.
and the back breaker shoulder twisting nice lookin rear bumper ow my arm...
Old Aug 10, 2013 | 08:06 PM
  #883
ChefYota4x4's Avatar
Nice work man! Very big improvement!
Is that a new bumper? Looks mint!
Old Aug 10, 2013 | 11:59 PM
  #884
only the front bumper caps are new the rear is polished primed an painted after all the welding done to fix the issues it had when it came with the truck
kris joked the rear hunkered down a couple inches again due to the weight put back on her rump but looked a LOT better with the bumper ends an rear back on
Old Aug 11, 2013 | 09:15 AM
  #885
It does! ...Look LOTS better with those that is.
Old Aug 13, 2013 | 03:28 AM
  #886
Terrys87's Avatar
To get the end caps off, just put them on the way the factory does and got for a drive down the road. That is what I did one time and those metal clips came right off. grrr, That is the reason I just do the carriage bolts now. The rear bumper does make the back end look more complete as well.
Once you get the rear quarters done, you have the outside completed. A long ways from where it was. What do you have left to do now? Your truck has transformed quick. Great job!!
Old Aug 13, 2013 | 12:37 PM
  #887
Redeth005's Avatar
Dude that front bumper side plastics idea was genius. And best part about it is that it looks like it was meant to be that way! Great job Mr. Dragon.
Will you do great work with painting man. A lot of the parts that you're refurbishing look mint after you're done. Awesome dude!
Hey btw I got a story for ya haha. Today while checking a tenants badge I noticed the dudes legal nast name is "DragonSlayer." Wow..... I was like whaaaaa??? I gotta tell William about this. I didn't believe it at first but then he pulled out his CA I.D. and it read Peter Dragonslayer lol
Old Aug 13, 2013 | 02:57 PM
  #888
oh still got plenty to do L trim on the top are rusted bad have to clean an rebuild them (the free L trm from a guy in AZ for shipping has died as many deals have) sand the top smooth an repaint - brakes the system pulses bad when ya brake hard one of the rotors has a hot spot an it isnt improving but got rotors an calipers from mark so is just pads an the urge to get it done the rear brakes are part of the rear end refurbishing got the backer plates and ebrake levers ect zuk springs need to get the tool to pull the backing plates an bearing seal assembly remove the rear axle get it cleaned up change the rotted bushings in the springs with polyurethane ones have to do it eventually as the backing plates are rotted out - sand blast scrape rust an layers of failed undercoat off an prime paint an undercoat again
new tires..
exhaust system next month i hope! had to loan people $ for gas yesterday
well i got the idea from terry so its his credit i did it to keep them on the truck LOL
paint can make things look like new an its better than replacing parts that arent broke
oh that introduction would go well mr dragonslayer this is dragon dragon this is AHHHHH preemptive strike!
Old Aug 14, 2013 | 07:09 PM
  #889
Yota621's Avatar
Keep up the good work!
Old Aug 17, 2013 | 01:15 PM
  #890
well today i went out an sprayed pen oil on the shocks nuts an ect on the rear of my runner also ordered the polyurethane shock bushings for the sensatrack shocks i got from mark
i grabbed one of my rear shocks an it wobbles an rattles on the bolt i hope i can rescue the flat washers an not break any nuts or PLEASE not the mounting stud!
will have the mapp torch ready for this one
with how the rear bounced after putting the bumper back on i have to fix the shocks waiting is not an option
Old Aug 17, 2013 | 02:04 PM
  #891
Nervo19's Avatar
Are poly shock bushings all one size or do they vary according to shock or vehicle maker? Do you have a link to what you ordered? Is there a different size from back to front?
Great idea on bolting the bumper ends. When I had my '88 back in the late 80's/early 90's and lived in the city I kept having them stolen. PITA before the internet to get to the dealer during work hours to get replacements.
Old Aug 17, 2013 | 05:06 PM
  #892
mark was able to include one half of a a bushing an i got the I.D. measurement from that to be honest they dont say the O.D. measurements but make it apparent on the ID
they do vary in their internal diameter !/2-5/8-3/4 the 3/4 is dead on for our 19mm theyre a two piece hourglass shape which gets squished in the shocks 'eye ring' around the mounting stem/bolt by two washers on either side
most with trucks wanting a lot of flex do helm joints at the ends of longer shocks
front shocks are different they use a stem an pressed in bushing the stem end you can easily get a poly replacement an ive got a set bookmarked for mine the other end is more problematic its a pressed in bushing with a metal sleeve i "think" they have poly replacements for them as well
heres the rear shock bushings you need 2 'sets' per shock top an bottom
http://www.ebay.com/itm/330973433392...84.m1497.l2649
the tops of the front shocks are these bushings "NOTE" i havent confirmed the measurements that these are right i just eyeballed them i dont need my front shocks 'yet'
http://www.ebay.com/itm/111126803772...84.m1423.l2649
they also carry poly tierod end caps swaybar stuff it is summit racing stuff
Old Aug 17, 2013 | 05:44 PM
  #893
page with poly bushings measurement sizes for shocks ends types ect ect
http://www.energysuspension.com/univ...-bushings.html
Old Aug 18, 2013 | 12:24 PM
  #894
Nervo19's Avatar
Thanks. I found a really good way to press them in:
Old Aug 18, 2013 | 12:37 PM
  #895
thats cool! great idea thank you!
Old Aug 19, 2013 | 06:17 AM
  #896
bbrideau's Avatar
Never thought about poly bushings for shocks, other than longevity of life in the bushings what other benefits do you get from them? Better response from the shocks?
Old Aug 19, 2013 | 09:28 AM
  #897
yes indeed
Old Aug 19, 2013 | 09:54 AM
  #898
Nice work, Will. Love seeing you at it when you're able. .. Just be careful bud (I know, derrr! Lol).
Best to ya!
Old Aug 20, 2013 | 12:12 AM
  #899
Terrys87's Avatar
Great video and idea Nervo19.. Simple, cheap and effective.
I have never looked into polybushings. Something I need to learn about. I guessing you just use them over the stock bushings??? A better all around improvement? You find them at parts stores?
Old Aug 20, 2013 | 12:28 PM
  #900
well they improve the shocks response to movement as they dont flex as rubber does i honestly dont know about finding them in parts stores i didnt check but i likely will when im hunting parts for the truck i knew i needed a full set for the rear shocks an went looking any performance shop should in theory be able to get them i just went to summit racing via their ebay listings so i could use paypal
i used a few on my 79 chevy street racer/sleeper truck to improve the front end which was sloppy when applying horsepower to pavement the A arm control bushings an stablizer bushings kept the front end on the pavement
