Gizler00's 85 4Runner Build Thread
Old Jan 28, 2014 | 04:18 AM
  #321
kornhuskerwizard's Avatar
Way to go Terry!!!! hey you guys stay warm today!! Gotta get to work now!!!By the way Mark hope you fixed your furnace!!
Old Jan 28, 2014 | 05:11 AM
  #322
Gizler00's Avatar
Thank you sooooooooo much terry. I am going to read through that link as well that you posted.
Where I am at now is:
The window goes up and down but only with the key in the tailgate. It will not work from the switch.
I have swapped in other relays, one behind drivers seat, and still no luck.
Swapped out the actual switch in the console and still same result.
I actually did the ground wire addition as per your advice a while back.
I had the cover off of the rear wiper assembly yesterday and the rear arm retract switch in there just does not look right to me. It almost looks as if there are pieces missing from it.
I will get a pic of it today. Its hard to explain. Almost looks like the plastic post just has a 1 wire connector on it. And the switch is moving but i cannot see how it is opening or closing a circuit.
Thanks a million Terry!!!
Chris.. So far so good with the furnace. Worked good all night.
Old Jan 30, 2014 | 02:05 PM
  #323
Gizler00's Avatar
Did some more house keeping with the runner today while I had the time.
I was having some trouble with the cable that releases the latch on the drivers side of the tailgate. It was hung up and not letting the spring pull latch back into place allowing that side to lock.
Here's the culprit.
I ended up soaking the crap out of it with some wd40 and then silicone grease I had for brake calipers. Worked really well and now slides nicely in the housing.
I also decided to grease up the gears and basically everything that moved. Name:  42F70B7A-9E54-4FD4-8D9D-B86C8C819F51_zpsdlxu4vki.jpg
I took some pics of the switch in the rear wiper assembly but am going to have to clean it up and make the photo brighter before I post it.
Still looks like it's missing something.
Old Feb 2, 2014 | 06:57 PM
  #324
kelvinb's Avatar
Mark, I have a similar issue with my rear tail gate window too. There is a ground or some switch in the back that if I pull it back the window works. I'll send you a picture tomorrow.
Old Feb 2, 2014 | 07:41 PM
  #325
Gizler00's Avatar
Sounds good buddy. I appreciate it.
Old Feb 2, 2014 | 11:48 PM
  #326
bcdan's Avatar
Nice build buddy! Cool runner
Old Feb 3, 2014 | 05:16 AM
  #327
Gizler00's Avatar
Thanks. I am trying to slowly go through everything on it when I get the time and money.
Old Feb 3, 2014 | 03:25 PM
  #328
rustED's Avatar
Nice work on the tailgate, I'm going to have to get in there and grease all my moving parts one of these days! Bookmarked the last page, a lot of good info, I need to get my back window operating again before summer, it used to work with the key in the tailgate, had to push in on it at the same time, now it's not working at all, figure I'll try to troubleshoot the wiper motor and defogger at the same time, but It's too cold to get motivated right now, ...maybe if the window was stuck in the down position, lol.
Old Feb 3, 2014 | 05:19 PM
  #329
Gizler00's Avatar
I love these 1st gen runners but I must say I really dislike the tailgate. That's the only thing I wish I could change about it.
If I had the money, I would just get a soft top and forget about using the window all together.
Old Feb 3, 2014 | 05:46 PM
  #330
Gizler00's Avatar
Here's the pic if the switch in the rear wiper motor. It doesn't look right to me like there's something missing. Sorry for te crappy pic. Name:  BEC1EA18-EB1C-4F99-ADFC-8F905E055D6E_zpscb3vbuvx.jpg
Old Feb 3, 2014 | 06:25 PM
  #331
Sorry i havent gotten around to get that switch yet Mark but i havent forgot!! As long as your window stays up until it gets warmer!!
Old Feb 3, 2014 | 06:35 PM
  #332
rustED's Avatar
I hear ya on that. I've been reading some DIY soft top build threads and am convinced that I can build my own for a fraction of the cost of a Can-Back. I've been putting together a price list of materials and think I can keep it under $400, which is still a lot of money, but it would be worth it just for the cool factor that you could say I built that myself, plus how often do you come across a good condition soft top on CL for cheap!
Sorry for the hi-jack, hope you figure out the wiper motor!
Old Feb 4, 2014 | 03:46 AM
  #333
Gizler00's Avatar
I wouldn't mind doing a DIY softop. I did come across a used one here on YT for a great price, but I hesitated and didn't buy it. Totally regret it now.
Old Feb 4, 2014 | 05:35 AM
  #334
Gizler00's Avatar
No worries buddy. She works with the key on the gate.
Hope we get some snow this time around!! Looks like you guys are in the 8"+ range for accumulation today. Its supposed to hit hard here around 2pm this afternoon.
Hopefully there will be snow piles to climb.
Old Feb 12, 2014 | 12:46 AM
  #335
Terrys87's Avatar
I one time found a thread about doing your own soft top, just cant remember where I found it. I will see if I can find it again later on.
2nd gen runner cables are an exact fit and an upgrade if you ever come across a set of them for our first gens. Just a better built cable.
My key switch for the tailgates don't work as my keys are so worn so never tried the ground wire trick on the tailgate. One thing I am eventually going to do to help keep dirt and grime out of my center console switch is to extend the harness from the console and mount it under the ashtray. There are slots there that I believe would hold the switch and give it better protection.
I am not doing any work on my trucks as well as it is just to cold. I am so ready for winter to get out of here.
Old Feb 12, 2014 | 05:11 AM
  #336
Gizler00's Avatar
I was reading a thread yesterday on how a fellow member on here used a Soft topper from a Ranger and or an S-10. He had to make minor alterations to it but it really looked great when it was finished. Said he picked them up used off Craigslist for 200$$ So I have been keeping a lookout for one.
I am ready for some warmer weather to get here also. I hate the salt all over the vehicles this time of year.
So My rear window works and works good but only from the rear gate key switch. I have the ground extended from the front switch, tried replacing the switch all together, tried replacing the relay, Double checked everything like the topper screw switch, holding up the wiper arm to contact the switch, and can only get the window to work with the key in the gate.
Now if I remove the ground from the front switch, The window does not work at all. Really trying to get this figured out so I can use the switch instead of getting out to use the key.
Also, My rear defrost wiring is not hooked up to the defrost on the glass. Could that be causing my issue?? I wouldnt think so, but who knows with this whole setup.
Thanks again Terry for all the help. Let me know what you think.
Old Feb 16, 2014 | 11:02 PM
  #337
Terrys87's Avatar
Most likely the rear defrost wire that connects to the grid in the window is rusted away or broken off. It wouldn't keep your window from operating. Neither of my defrost work because the cable is just gone and what is left is broken.
Can you hear your relay behind the drivers seat click when operating the switch? I think either your relay or the switch is bad. First I would try and take your switch apart and give it a good cleaning.
You will need to take the light bulb out of the switch first to get it apart. Then carefully separate the covers. The little piece of metal that toggles and contact the switch probably has that green corrosion on it as well as the little post the toggle contacts. These switches get dirty.
After cleaning your switch, see if you can hear the relay working. If not, I would bet you have a bad relay. I have found a link to rebuild the relay but I have never tried building it myself with parts from Radio Shack.
Old Feb 16, 2014 | 11:45 PM
  #338
Terrys87's Avatar
If you are suspecting your relay, check the bottom link for Radio Shack parts. Here is some notes I have kept that might help as well.
This is going to be my notes page for the window switch.
https://www.yotatech.com/forums/f128...runner-137310/ Link I found for 89-95 Runners.
https://www.yotatech.com/forums/f116...l#post51400485 Wiring colors.
https://www.yotatech.com/forums/f116...cement-209572/ Replacement Motor
http://www.4crawler.com/4x4/CheapTri...CommonProblems Common problems, Lots of Info
http://forum.ih8mud.com/79-95-toyota...ay-repair.html Cleaning Relays
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml Troubleshooting
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml This page says you can get replacement relays from Radio Shack. I will evetually try it on my old one to see if it works. Would be alot cheaper way to go. As soon as I can get some relays, I will post the results an how to solder/desolder. It is easy if you have never done this before.
Old Feb 17, 2014 | 10:47 AM
  #339
I took the relay from the 85 runner today.part number 85930-89101(toyota)165000-0451(nippendenso)Ill send it today.
Old Feb 17, 2014 | 05:29 PM
  #340
Gizler00's Avatar
Thanks for the info terry!! Always a huge help and very informative. I am getting a known "good" relay from Chris (kornhuskerwizard).
After I read what you said about hearing it click, I couldn't recall ever hearing it. So I double checked and it does nothing when I hit the switch.
