KawaZX636's 1983 Toyota Pickup Restoration
Old Aug 15, 2016 | 01:18 PM
  #1441
Reluctanse's Avatar
Any word on a new project?
Old Aug 18, 2016 | 09:50 AM
  #1442
kawazx636's Avatar
Not yet. Bought and sold a 76 Ford Bronco that I'll probably regret selling since it was in such great shape and a good start to a restoration, but it's hard passing up $6K in free money just for owning a vehicle for a few weeks. Still looking though. I don't have much time now with a one and four year old running my life so I'm in no rush.
Old Aug 18, 2016 | 11:46 AM
  #1443
jakey poo's Avatar
Any pics of the bronco?
Old Oct 18, 2016 | 12:13 PM
  #1444
1983yota69's Avatar
Such a nice build
Old Nov 1, 2016 | 05:22 AM
  #1445
Honger's Avatar
Man... it has been forever-and-a-day since I've logged in to YT. Somehow hit this build thread in a Google search and have been riveted by the build. Great job! Amazing craftsmanship.
Would love an update on how the AC install is going for the second owner.
Old Nov 1, 2016 | 05:36 AM
  #1446
Honger's Avatar
And yeah, I want to know what your next Yota is gonna be?
Old Nov 2, 2016 | 08:21 AM
  #1447
1983yota69's Avatar
Hey man, what size lift and tires are you running on your 83
Old Nov 13, 2016 | 11:29 AM
  #1448
80s Rule's Avatar
The A/C install went great and is working wonderful. Very easy to use and cold! It is from Vintage Air and uses electronic controlled vents so I dont have to use the old cable type adjustments. It is expensive but I do recommend it.
Garry
Old Jan 23, 2018 | 08:37 PM
  #1449
YOUNGIAM's Avatar
Nice build. I always regretted getting rid of my 82.
Old Jan 24, 2018 | 03:01 PM
  #1450
YotaRick27's Avatar
I was like "man this is a sweet thread" then I came across the lost battle with the angle grinder... Chills... But the build looks awesome, Nice work.
Old Jan 31, 2018 | 06:25 PM
  #1451
95yoda's Avatar
what page was that on? Angle grinder injuries are bad.
I read through almost all of this thread and missed it I guess.
Old Apr 19, 2018 | 02:36 PM
  #1452
MVP's Avatar
MVP
Just wanted to give my $0.02 and say thanks for documenting your build in this thread. I am going to learn a ton from it. I'm a 3rd Gen 4runner guy so going to have fun building my '83 pickup.
Old Jun 5, 2019 | 11:33 AM
  #1453
Soto's Avatar
Amazing restoration! This thread has definitely inspired me to finish my 83 Toyota Pickup. I really liked your method for fixing the rust on the floor pan. Is there anywhere to download your SketchUp files? My 83 has some serious rust damage in the same areas as yours and I think replacing the entire floor would be best. Again amazing restoration! I will be referencing your thread throughout my build. Cheers!
Old Jun 5, 2019 | 12:53 PM
  #1454
Lons81's Avatar
Haven't seen Dave around for awhile, but I do have his layout drawings for the center console, body mounts and the center arm rest. You'll just have to follow him in this thread for particulars on how he did the floor pans and process he went through.
For the layout drawing, email me at praisegig@hotmail.com I will send them to you in .PDF file format
Old Oct 11, 2019 | 11:14 PM
  #1455
85.4Runner.702's Avatar
FOR SALE!
Good evening all. Just as a general FYI, just saw this beautiful truck in person on display in Las Vegas for the Mecum Auto Auction (lot S19).
Even after 75 pages, there is nothing like seeing this truck in person.
Looks like a few changes have occurred:
* Leaf springs are now 3" Rough Country
* converted to high steer
* 285/75R16
Unknown if anything else has changed. The fact tag and online description simply stated "frame-off restoration".
It is scheduled to cross the block early on Saturday. Oct 12th. Since this a Mecum Auction, not sure if there is a reserve or not.
I am not affiliated with Mecum, nbcSN, the owner, or previous owner(s). Just a Toyota Owner/Lover and someone who can appreciate excellent work.
-Toby
End of Line
Old Oct 12, 2019 | 03:06 PM
  #1456
84 yota dude's Avatar
Too much wheel and tire for me for the stock look. But that is one good looking rig! Beauty
Old Oct 13, 2019 | 07:02 PM
  #1457
Ivans’s's Avatar
5 Year Member
2 hour 53 minute mark...
Old Oct 26, 2023 | 05:19 PM
  #1458
newschoolers's Avatar
so how did you actually end up getting it off?
im one MFer away from pipe wrenching TF out of it till it is ruined
Old Oct 26, 2023 | 05:25 PM
  #1459
Originally Posted by kawazx636
Waiting on a drive shaft that I scored off eBay so I can replace that yoke that I broke. For now I'm just doing some odds and ins while I wait for some parts to get in so I can get everything ready prior to throwing the chassis in storage. I put some cheapo gear lube in the tranny, t-case and differentials just to coat everything and prevent any corrosion in the event that some moisture got in there while it was opened up. I'll replace it with some good stuff before I finish out the build. I've also worked back through all the nuts and bolts and re-torqued everything to be sure that I didn't miss anything.
So last night I was sitting in the garage bored and decided to pull out the shifters to install them before the chassis goes to storage. Of course they couldn't go back on without a fresh coat of powdercoating! Sooooo.... I was trying to separate the t-case shaft from the shifter ball when I realized that they were pressed together with some sort of rubber bushing. Well, I boogered that up good so I decided to come up with a fix that I think will make it a little easier to separate in the future.
Here's what it looked like originally (you can see the rubber bushing in there):
Attachment 155636
After some cussing, reaming and temper tantrums, I got the two pieces separated. The shaft attached to the ball wasn't originally threaded so I grabbed a 1/2" x 20 die and cut some threads on it (Die fit the shaft diameter perfectly). Also went out and grabbed a 1/2" x 20 nut to weld into the shifter shaft:
Attachment 155637
You can see how it's going to go together here with the nut going inside the shifter shaft so the the ball shaft can thread into it:
Attachment 155638
I welded the nut to the inside of the shifter shaft. Don't make fun of my crappy welds; I ran out of gas when I was doing my frame and I probably bought the worst flux core welding wire ever! I'll clean it up with the grinder before I powdercoat it.
Attachment 155639
Here's the ball installed in the t-case socket:
Attachment 155640
ANNNND the shifter shaft and knob just thread right on:
Attachment 155641
I'm pretty satified with the result, although I'm not quite sure why Toyota designed it the way they did since you can't remove the shaft to replace the spring and retainer caps if you need to. I suppose that's one way the stealership makes money...
Old Nov 13, 2023 | 05:22 AM
  #1460
ajpuleo23's Avatar
The tale lives on
https://bringatrailer.com/listing/19...4x4-pickup-29/
if the seller is on the site… (which I doubt) they should have linked this thread. Considering its one of, if not the best documented restorations of an 83 on the web. As a fellow maryland-er (and salisbury grad...) I'd like to see it come back east.
Cheers
dropzone
1546
Mar 23, 2021 09:06 PM
captainslow
Oct 14, 2017 02:18 PM
Snoqualmie
79
Aug 16, 2013 01:38 AM
schmooot
Jul 25, 2013 07:05 AM
