What is broken on YOUR Toyota
Old Jan 27, 2009 | 09:06 AM
  #321
Plumbrbob's Avatar
My 79 is in constant destruction! but its like new since everything keeps getting modified or replaced, thats what i tell myself so i sleep at night
Currently:
bent steel brake lines on rear axle those pesky branches
leaky & mud filled radiator I keep it toped off
killed my aux battery keep on winching with jumper cables then
leaking power steering pump making a super mess
rotten exhaust piping/muffler, brackets now gone tie wire holding it up for now
side marker lights broke lens and I don't care
tach in my SR5 cluster quit working
winch cable is kinked my buddies first time forgot to mention that to me!?! he owes me lots of beer now
leaky door seals and muddy window innards make it sticky
front drive shaft u-joint is got some play now chimpsy china crap again
transfer seal spiting oil "typical"
leaky Weber want a rebuild get in line you bastard
windshield fluid nozzle broke off no squirters anymore
windshield wiper arm splines stripped on the transmission side Damn trees
Tool box wont stay closed without a strap Damn trees again
Flat bed fenders are bent Those pesky trees again
Front bumper is tweaked a little pulling out full size Chevy blazer WHY I did that I dunno just to make him feel bad I bet. after I pulled him out I ran that mud pit like it was nothing
mud flap fallen off again I tie wired it
probably more but don't want to think about anymore
I Take it one repair at a time, and dont let my wife know about how much is really broken.
Old Jan 27, 2009 | 09:13 AM
  #322
SMOD's Avatar
My power antenna is broken. I just replaced my power steering pump and it was leaking.. so I took it out and replaced some seals and it still leaks a little bit. (I think I got a bad remanufactured pump).
Back windows take a long time to roll down.
Very back window sometimes doesn't work.
1 broken CV axle
Valve click (valves need to be adjusted)(I don't have the money. It's like $600)
Front tires are bad.
Old Jan 27, 2009 | 09:15 AM
  #323
SMOD's Avatar
Originally Posted by Tubbyfatty
Naa, she just needs a bit of polish. lol.
I want one of those stickers that says ll'Buffout
lol.
Old Feb 10, 2009 | 09:44 PM
  #324
Dieselfuel12v's Avatar
driveshaft talks to me
Oil pressure drops low at idle
pops out of reverse and scares the crap out of me
not broken, but my braklines need to be extended badly
But i'll keep fixing it until I break something else.
Old Feb 24, 2009 | 02:47 PM
  #325
bipolarandproud's Avatar
Well, I fixed the oil leak .. Now, I went to put on a new exhaust gasket and one of the studs broke off on the bottom part of the manifold . So.......
1.Exhaust leak
2.Dented tail gate
3.Needs a tail light Relay .
Old Feb 27, 2009 | 06:03 AM
  #326
skyratcalls's Avatar
Timing chain, timing chain cover, distributor cap, coil wire, dash pot, tps, ac, wiper blades. I love my little 92. Oh, by the way, the oil gets thrown out of the rear wheel because of centripetal force (m*v*v/r) centrifugal force is an imaginary force.
Old Feb 27, 2009 | 02:40 PM
  #327
Ohio4R's Avatar
My passenger rear axle seal is leaking, I wish i could get rid of the the spacer lift up front and replace it with a coil-over, some of my valve stems leak.
Old Feb 27, 2009 | 02:56 PM
  #328
j0hNnI's Avatar
cracked brake line leaking heavy fluid
bad clutch
transmission has trouble going into 4th gear without double clutching
missing one wiper
exhaust is cracked in multiple areas
front differential slips
hubs are rusted into the locked position
starter is starting to go out
cd player is kinda sketchy
but the engine runs good
Old Feb 28, 2009 | 06:25 PM
  #329
JasonWin's Avatar
Hmm lets see...
My good truck:
Engine runs weird I believe the timing is off, gets gutless and sputters somewhere between 2000-3000rpm (depends on the gear) and it's not charging properly (if at all)
New DD:
Engine will randomly lose power sporadically turning the CEL on but never for long. Not to worried about it since it'll become a parts truck in a few months anyway.
Old Feb 28, 2009 | 09:50 PM
  #330
95yoda's Avatar
My 82 has nothing wrong, except I do have to adjust the E-brake.
Old Mar 11, 2009 | 08:49 PM
  #331
Windsor's Avatar
Originally Posted by Windsor
I dug into it. The (4x4) switch is broken. Sounds like a trip to Toyota dealership.
Toyota said that they can't supply a switch, no stock in country.
Fortunately, one of our lovely junkyard vendors hooked me up, for free (added to an order I had just placed).
I compared the switches, the old (broken) one is boned, the switch pin doesn't come all the way out. Either some serious cruft got inside there or something broke.
Anyway, it's fixed, my light works now. I recently replaced the oil pressure sending unit, so now my oil gauge works, and I got the 4Runner back from the transmission shop today.
After I get this wiring love done, I'll have to look for something more to fix.
Old Mar 11, 2009 | 09:44 PM
  #332
gary96360's Avatar
umm some surface rust that needs to be fixed soon on the front fender. and thats it lol
Old Mar 14, 2009 | 08:36 PM
  #333
Jay351's Avatar
Originally Posted by Jay351
Fixed:
Number 6 cyl spark plug
Steering colum cover
re-wired lights.
New list of crap to fix:
-fix rust
-fix dents
-clutch start switch
-VC (tps) wire is broken somwhere along the harness (woooo!)
-leaky passenger side valve cover (got the gasket)
-E-brake is a little sticky
-Weld in new rear cross support (rusted)
-Get a/c working (for next summer)
Well, thats a good sized list for the new year
Fixed:
-Clutch start switch (PO jumped the wiring so it could start with the clutch out)
-leaking valve cover fixed
- e-brake fixed (new rear section to go with the 1yr old front section)
To fix:
- TPS wire needs to be fixed
- Rust
- Dents
- weld in new rear crossmember
- Fix A/C
- rear u-joints getting a little old
- Reinforce marlin front bumper for winching
- flush heater core
- replace sagging door hinges
- replace drivers side door seals for door and window (VERRR tight!!!)
Yay, I just need some money and motivation!
Old May 9, 2009 | 01:22 PM
  #334
almond_oxide_21's Avatar
Turbo is broken so it burns oil.....A lot......
Interior needs a major deucheing. Hood looks pinker than the red of the truck.
Needs a tranny flush.
Old May 9, 2009 | 06:15 PM
  #335
Plumbrbob's Avatar
Currently:
Thought I would update, well allthe above is still broken but the list has grown
I cant keep a running motor in my truck
electrical system has a gremlin
rear brakes no longer work
exhast system fell off
both fenders are super dented
over flow bottle has a leak
man this is depressing maybe I should part this thing out
NAH
Old May 9, 2009 | 06:21 PM
  #336
Plumbrbob's Avatar
the things i fixed since I made that list in JAN.
replaced birfeild
replaced steel brake line on SFA
replaced steel line for clutch cylinder
replaced lower radiator hose
replaced front drive shaft
replaced front pinion shaft
replaced front u-joint
replaced rear u-joint
replaced SFA inner seals
replaced trunnion bearings from broken birf
replaced wheel bearings driver side
replaced transmission and transfer case
replaced motor 4x so far
replaced fuel filter
who knows what i blocked out from all the wreching trauma
man no wonder I am always wrenching on my yota
Old May 9, 2009 | 06:29 PM
  #337
toyospearo's Avatar
At the moment my truck has nothing in the front end underneath the motor
Old May 9, 2009 | 06:34 PM
  #338
Plumbrbob's Avatar
yup been there have fun
Old May 9, 2009 | 06:39 PM
  #339
Plumbrbob's Avatar
oh yea jsut remembered some more broken stuff
my winch is broken wont pull a load
off road lights relay took a poop
RH turn signals dont work anymore
starter relay took a poop
battery isolator took a poop
another red top optima took a poop
cd player wont eject the pantera CD
AM/FM antenna cable broke
CB antenna cable broke
man i am gonna shoot myself
Old May 13, 2009 | 06:06 AM
  #340
racingcameron66's Avatar
i got two dents in the rear bumper lots of squeks on tha inside, dent on the driver side under the1/4 glass, no horn, and that toyota tickin 2.7 haha and i could use some new tires and my antana got ripped of in the carwash
