What is broken on YOUR Toyota
Old Apr 22, 2006 | 03:47 PM
  #121
rugerm44's Avatar
New timing belt, tensioner,idler pulley,waterpump,all with 21,000 miles on it!Makes me wonder whats going to happem with 70,000 miles on it.Just to cheer me up.I go and look at all the recalls on ford,gmc and dodge and chevy.Why cant soemeone build one right the first time.Sometimes it feels like I bought a ford.Now the older toyotas 91 to 94 I think are having cracked steering linkage causing steering failure.That sounds good.But so dose the 05 gm trucks.They have a sub standard bolt on theirs that fails and have no steering either.Looks like a crap shoot no matter what you buy.
Old Apr 22, 2006 | 07:50 PM
  #122
surf4runner's Avatar
i hope all those repairs have been made from 2004
drivers window rail, window still usable
warped rotors
Old Apr 22, 2006 | 07:53 PM
  #123
KyleT's Avatar
1996 Limited 146k, i have replaced:
all front ball joints and control arm bushings, steering rack and endlinks, and the lift.
Problems:
drivers side rear seatbelt tensioner, both rear seatbacks rattle on occasion, clunk in the front end, and the stupid middle steering rack bolt is jammed in there and I have not been able to get it out and put a new one in. antenna fell into the fender, I need to permanently mount my Sirius radio tuner and antenna and mount my scanner and CB and antennas.
I do what i can, balancing school full time, working 40hrs a week and trying to go to the lake as much as I can. then messing with the truck.
Old Apr 22, 2006 | 07:59 PM
  #124
MossyRocks's Avatar
210k on the odo. give it hell every day and nothing wrong at all. Replaced plugs and wires a while back, orig. motor, orig. transmission
Old Apr 22, 2006 | 08:08 PM
  #125
FingerMan20's Avatar
-slight rust on the undercarraige
-grinding shifter due to cracked shifter seat (have parts)
-imperfect paint (will not be fixed, only worsened)
-girl I need to marry
other than that, im good..
Old Apr 22, 2006 | 09:48 PM
  #126
Jimmeh's Avatar
Just hit 265,40X today, and here is the list
-I think my front end is going under. Whenever I go over 60, it seems to shake a lot more then normal.
-Also, my tail pipe isn't connected to my muffler. It is just hanging there.
-And, I have an oil leak somewhere.
-My module for my back window is broken.
-My skid plate is dented.
-First gear grinds a lot.
-It doesn't always go into reverse on the first, second, third, fourth or fifth try.
-The lever that allows me to turn the cab light on is busted.
-The seats won't go forward or back without a hand underneath it messing with the little clips.
-The console smells like throw up.
-I just burnt out a bulb in my Fog Lamps.
-My rear windshield wiper doesn't even come close to actually touching the winsheild.
-E-Brake doesn't work.
I think that is it.
Old Apr 22, 2006 | 11:15 PM
  #127
FUZION's Avatar
door dents
dented bumper
rattling driver window
rattling front speakers
cracks on windshield
non retracting passenger seatbelt
my foglights sometimes work
ITS GREAT
:chicken:
Old Apr 23, 2006 | 12:00 PM
  #128
blzorro's Avatar
Whole passenger side font end is banged up, antena and and windshield wiper is gone, rear door wont open sometimes other than that this thing is Tip Top.
Old Apr 23, 2006 | 02:33 PM
  #129
jrallan26's Avatar
Lost a mudflap, going to order parts in the morning.
Also dont know if I am doing this right. I tried engaging my elocker and all I got was a "blinking" light on the dash. Dont know if it engaged or not. Never tried it.....
Was getting really bad gas mileage before. I switched the thermostat and coolant and now the mileage is a lot better.
Old Apr 23, 2006 | 03:52 PM
  #130
KyleT's Avatar
are you in 4-lo?
Old Apr 23, 2006 | 04:22 PM
  #131
Paul H.'s Avatar
Rear wiper will not lock in place, thats all.
Old Apr 23, 2006 | 06:45 PM
  #132
jrallan26's Avatar
I will give it a try...
Originally Posted by KyleT
are you in 4-lo?
Old Apr 23, 2006 | 08:01 PM
  #133
kcebes's Avatar
-rear o2 sensor bolts rounded off
-climate control backlight burned out (limited with the digital climate)
-antennea will not retract all the way. (about 3" sticking up)
Old Apr 24, 2006 | 06:35 AM
  #134
rentedmule's Avatar
177k km and here's my list!
rust issues on all corners, door bottoms, tail gate, muffler.
just spent $400 on rotted out fuel sending unit
serious rear window gremlin's and tailgate window switch has never worked
broken antenna
same climate control light issue as kcebes except mine goes out randomly
broken seat belt clip
Hey FUZION, I had a rattle in my driver's side window that drove me nuts for a whole year - I tore the door apart a bunch of times before i realized that the screws holding the armrest to the door had stripped out the little plastic thing they threaded into. I just replaced them with 5/16" screws and the rattle went away
Old Apr 24, 2006 | 07:54 AM
  #135
X-AWDriver's Avatar
114k and everything still works like it did from the showroom floor. My power antenna even still works. (knock on wood)
Old Apr 24, 2006 | 08:09 AM
  #136
shiftless89's Avatar
120K 17 years old and the only thing broke is my wallet
Old Apr 25, 2006 | 06:23 AM
  #137
1989toy4wd's Avatar
My poor truck!
-Needs Piston Rings
-Needs oil change
-Needs Trans Shifter bushing
-If not the bushing, then I need a new Trans or rebuild
-Engine Rebuild
-Brakes
-Paint
-Only rust is on the rear quarter panels about the size of a quarter
After I do all of that, I am going to put: new warn bumpers with front winch, lockers, gears, rebuild transfer case, rebuild hubs, lift 5 inches to clear 33's, put 33-12.50 r16 BFG mud terrains, 16X10 rims (Im thinking black), Dark Blue Paint, Full body off restoration! I am going to replace everything small that will go out sooner or later (fuel pump, fuel filters, air filters, alternater, etc)
I am going to school to be Automotive technician, so I will have the ability to do all of this stuff in.
Old Apr 25, 2006 | 11:25 AM
  #138
L33T35T 4Runner's Avatar
95 4runner: 114k miles
-power antenna doesnt work, but doesnt bother me since i only use my XM Radio. I disconnected it so now it stays down.
-some times at idle there is this weird black box on the passenger side near the firewall right next to the intake manifold that is making this strange rattling sound. no side effects though
85 4runner: 249k miles.
-truck needs some new leaf springs (i mean a lift?) and shocks. steering wheel is off to the left, even though i had it aligned. they said i need to repack my bearings and tighten my steering box.
-rust here and there
that's all i can think of
Old May 18, 2006 | 07:33 PM
  #139
deprunner's Avatar
power antenna................breaks about once every 3 years. finally unplugged it and only listen to sirius now
Old May 19, 2006 | 02:57 AM
  #140
OutdoorLiving's Avatar
1. Front differential had been regularly blowing a small amount of oil out the breather. Flushing the front differential and replacing the breather hose ultimately (but not at first?) fixed the problem. I don't know if the idiots at the stealership put in the wrong weight oil or if the (now) 6' breather hose corrected that problem.
2. Power antenna retracts about 2" into the housing instead of stopping flush at the top. Put a zip-tie around the top to keep it from going ALL the way down. It's never gotten stuck down there, but I prefer not to take any chances until I figure out what I'm going to do with it.
3. A *very* small (less than a dime) spot of rust on the bottom of the rear door (where the paint was chipped by closing it on something). Clean it regularly, but been too lazy to repaint it.
4. A small amount of body damage on the right front quarter-panel where previous owner hit something and the brush guard came back and bumped the panel. It won't ever get fixed and isn't much of an eye-sore -- but I'd still consider it broken.
5. One of my Hella driving lights burnt out and I've been too lazy to replace the bulb.
