What is broken on YOUR Toyota
#141
Both front CV's were so jacked that they were binding
, so I torched out the center section.
Tweaked the tinfoil front skidplate and pinched the trans cooler lines that the PO ran between the radiator and the skidplate.
Also, I'm having an issue with axle wrap but I have a fix planned.
, so I torched out the center section.Tweaked the tinfoil front skidplate and pinched the trans cooler lines that the PO ran between the radiator and the skidplate.
#143
1 Tail pipe fell off Fixed
2 Muffler blew up inside itself Fixed
3 Gas filler neck does not go all the way to the door (body lift) Fixed
4 bumpers at the wrong height (body lift)
5 Steering rod does not go to the power steering box (body lift)
6 Paint is of poor quality
7 Tailgate latch is broken Fixed
8 Loose belts Fixed
9 A/C is broken Need a working compressor. (pm if you have one.)
10 Carpet needs replacing
11 Need new weather stripping for the passanger door window
12 Leaking Tranny Fixed
13 Leaking brake line somewhere
14 almost every hose in the engine bay is leaking in one way
15 No interior Lights
16 Rip in the drivers seat Changed to 4 rips
17 Missing drivers side windsheild wiper arm Fixed
18 I need new shocks
19 My truck has a saggy butt
20 My oil pan leaks
21 Power steering leak Fixed
22 need new brake pads
23 Battery is held in by a Bungee Cord
24 windsheild wiper fluid container just sits there and is not bolted in
Why does my list keep growing?
25 I think I have the longest list
But I still Love My Truck
Updated 08/19/06
8 Loose belts Fixed
20 My oil pan leaks
Updated 08/19/06
#145
1. 2 2" cracks go up the sides of the rear spoiler.
2. rear defogger doesnt work
3. body rot next to sunroof and drivers rear window
4. driverside carpet has hole
5. rear speakers are rotting out
6. heater switch position 3 is same as 2.
7. Car stereo clips because its weak and overheats.
8. Drivers side seat has buttwear where I get in and out.
9. trailerhitch bolt fell out, Havent found a match yet
10. trans leaks
11. 3rd gear syncro gone
12. Valvecover leaks
13. Passenger rear shock started leaking
14. theres a cluck up front drivers side, Cant find it.
15. Power antenna stop working, Its broke off now.
16. Winsheild cracked
17. Window washer tank leaks/cracked.
18. cracked headlight
What I fixed since newyears
1. Rear ring & pinion +bearings
2. winch , Had bad ground
3. rear window releys
4. front breaks
5. front rotors and bearings
6. Alignment
7. Radiator
8. Waterpump
9. Timingbelt
10. timingbelt pully and tentioners
11. Both headlight bulbs
12. Had to do ISR mod since rubber TB tube cracking.
13. Sealed Throttlebody to manfold
10. trans leaks
4. front breaks
6. Alignment
7. Radiator
8. Waterpump
9. Timingbelt
#147
i'll start from the front
-leaking coolant from a crack in the radiator
-leaking tranny and transfercase
-tears in the drivers seat
-torn shifter boot blows hot ait on hand when its on the shifter
-no lid on consol
-missing passenger side rearview mirror
-dome light doesnt work
-exhaust leaks from the factory welds on flowmaster muffler
-no rear head rests
-leaking brake proportioning valve
-broken exhuast hanger
-no rear wiper
-tail lights faded to pink
-no lid on consol
-no rear head rests
-no rear wiper
#148
1989 pickup 4x4 V6 auto
-loose auto shifter (needs bushing)
-rattle in passengers side door
-bubbling drivers side cab corner
-rust hole behind the gas tank door
-drivers side window EXTREMELY hard to roll up or down
-need to change diff oil
-need to grease driveshafts
-dash lights extremely dim with dimmer all the way up (need new bulbs)
-no rust on chassis but i need to coat it before winter comes to keep it rust free
-brake pads
thats it for now
-brake pads
thats it for now
#149
Leaking oil pan
Some clips on the dashboard broken
Dashboard rattles at times on the passenger side
Tachometer reads zero RPM's sometimes at idle ???
After having the A/C on a while idle tends to become erratic
Dent in passenger side of bed
Sloppy patch job on the tailgate
Tailgate won't drop without pounding on the inside passenger side
The bed is beginning to corrode
Paint where stripes were is shinier than rest of the paint
I love the truck, but the flimsy dashboard on the 90-95 models should have really been designed sturdier. It's my only gripe. Maybe it has something to do with the truck being assembled in Long Beach@TABC instead of Japan?
#153
i just have an indent where a clock WOULD be, (if there was one)
#156
My front air mix control motor is broke.......$130 to replace....don't think so
My sway bar and steering rack bushings are shot, but will be replaced this week with poly bushings
thats about it..........
#157
84 extended cab
Whats broken on mine?
rear interior plastic is all gone because it was cracked and broken so i took it out.
valve cover leaks.
needs brakes done.
rusty dented bed.
heater only blows on high and it blows pine needles and crap at me.
drivers side seat is pretty worn out.
cracked windshield.
worn out suspension mostly in the front.
thats about it nothing real big to complain about. i love my truck and hopefully will never have to sell it.
valve cover leaks.
needs brakes done.
rusty dented bed.
cracked windshield.
#159
It has low compression on cylinder #3
The rear main leaks oil
the high-beam indicator does not work
the left light has a puddle of water in it
the right light has a hole in it
5th makes a weird noise
miscellaneous other engine noises
The fast idle is screwed up bad
I'm not sure how well the choke works
It idles kinda rough when cold
Surface Rust
Surface Rust
#160
Surface Rust
Surface Rust
