What is broken on YOUR Toyota
Old Nov 19, 2007 | 07:47 PM
  #181
crolison's Avatar
Broken antenna, just ordered a new one
I drilled into it while installing my snorkel this summer.
Old Nov 19, 2007 | 07:58 PM
  #182
camo31_10.50's Avatar
ok now then...my truck is 27 yrs old...(1980 S/B 4x4) it as its list of problems that usually gets bigger every month
so far..worst is transmission
front AND rear mains
clutch, input shaft bearing, T/O bearing
needs rebuilt carb
needs rebuilt motor
needs body work (was rolled onto the driver side by previous owner it looks decent...but could definately look better)
needs paint (am in the process right now)
needs seats
needs STEREO!!!
needs electrical stuff hooked up..(lights mainly)
needs to be rewired baddd
and thats about allll i can think of right now...(wow not as much as i thought)
Old Nov 21, 2007 | 02:16 PM
  #183
Bdog's Avatar
the little thingy.....
that is the hinge on the ext. cab vent window. I don't know how, but it is real aggrevating.
Old Nov 23, 2007 | 07:51 AM
  #184
devldogs55's Avatar
Well.. nothing broken where it doesn't work - just needs to be fixed still though.
1. Passenger outer CV boot leaking
2. Putting 4 new shocks on (2 leaking - still stock)
3. Rear window is VERY slow.
4. Slow oil pan leak
5. Front diff leaking slowly
6. Front driver's tire rubs when I turn left - need to do some trimming
7. My exhaust is rusty all over the place - want to replace it
8. Car pulls right when I brake hard
9. Tranny pops out of 1st about once a week. (I think I know what it needs)
10. Don't know if the tranny fluid has ever been flushed
My truck is in the shop right now for a HG job. Putting on a new timing belt and some new drive belt pulleys. My valve cover leak will be fixed - it was pretty bad. My power steering leak was worse and it'll be fixed. Just fixed my power window problem - just buffed the contacts on the rocker switch.
Old Nov 25, 2007 | 11:23 AM
  #185
magicninja's Avatar
I need to do my rotors
After my accident, and before i found out about all the nice aftermarket bumpers, i bought a cheap oem replacement one and the back side is rusting after only a year
i need grill end pieces and a left side corner marker
both fenders are kinda crunched from the accident
one idle pulley needs to get replaced and screams when i go past 3000 rpm
im starting to get suface rust on the front end
Old Nov 25, 2007 | 11:35 AM
  #186
infiltrator's Avatar
-ac needs hose and recharge
-need new rotors and pads all around (sounds like someone dies when i brake)
-need (and want more of) shocks
-back springs for sag
-needs new joints all around
-spark plugs
-tranny needs attention
i dont have anywhere close to the money i need for all this...
i need a new damn job. any ideas?
Old Nov 25, 2007 | 11:52 AM
  #187
KegKiller's Avatar
Just had the dealer look over my 93 to see what it would take to get back to 100% Seems that it'll take a page of parts, and a total of at least 3 grand. Needs a water pump, timing chain, oil pump, and aux air valve.
Old Nov 25, 2007 | 12:18 PM
  #188
Belize Off Road Team's Avatar
A/C, no rust, no problem motors, no loose anything, engine runs like new, a VERY peppy accelaration time, no dents, nothing bent, other than factory saggy ass of which i replaced anyway, my truck might as well be new, i have had my TOYOTA dealers in Canada all say to me that mine is the first SURF in mint condition they have seen.
Old Nov 25, 2007 | 08:34 PM
  #189
notanymore's Avatar
well my truck is getting really bad gas milage like 14 on the highway and a cel but other than that im happy with it.
Old Feb 21, 2008 | 07:06 PM
  #190
87toy.'s Avatar
oh god, when i got it
1.heater controls were busted, old owner got mad. try driving with no defroster in the rain. Fixed
2.heater control valve stuck almsot closed, at certain rpm's i get the running water sound.
3.rusty on the top of the window, when it rained it driped on my nuts or ran down the side of the window and behind the dash, pool on the floor. fixed
4.no rear window, shell rattled like a mofo. got a slider now, no stupid shell.
5.clutch needs to be repalced, master cylinder leaks onto the floor. fixing monday thow
6.valve cover leaked, fixed that the other day
7. got ty millage, new plugs cab n roter, air cleaner fuel filter and wires somewhat fixed that, carb rebuild next, runs good thow
8. Ran hot, almost overheated a few times, restored radiator, new water pump hoses and 2 fluhses later it runs cool. (old water pump fins were almost rusted off)
9.needs new rear drums, pulsates, needs a paint job, imagine a sun burn on a truck, when it peals.
10. this is bugging me the most right now, no tinted windows or day night rear view mirror.
and a$$holes who think high beams are always needed, in big trucks, and those stupid ass h4 lights on bmws and high end cars, people are f'in blind!
i think im done, ohh, having to bend down to change the station or volume, need a cd player with a remote.
Old Feb 21, 2008 | 07:14 PM
  #191
WSUWESTON's Avatar
Motor smokes
sunroof leaks
carb won't idle
vacuum leaks
hubs need to be rebuilt
brakes going bad
Old Feb 21, 2008 | 07:51 PM
  #192
24Runna's Avatar
Rust over rear wheel wells
Poor MPG
Burns oil
Center console lid hinge
Rust on frame
Old Feb 21, 2008 | 08:15 PM
  #193
flatland4runner's Avatar
My winshield washers dont work, and I have have only 1 speed on my wipers. Annoying
Old Feb 21, 2008 | 08:20 PM
  #194
NwRunner's Avatar
the person who drives it haha.
and the cigarette lighter, but thats my fault ><
Old Feb 21, 2008 | 08:31 PM
  #195
87toy.'s Avatar
mine too, but i jsut got a new washer bottle, and i have fast and faster, eventually ill make it intermitten, i have the switch already
Old Feb 21, 2008 | 09:40 PM
  #196
olsy1984's Avatar
just got my truck the other day, only thing wrong is a very small rust whole in the bed, easy fix....just need a welding machine
Old Feb 21, 2008 | 09:46 PM
  #197
strykersd's Avatar
86 4runner, just the usual broken parts
-plastic piece which helps lower the tailgate
-automatic power antenna motor
-cracked dash
Old Feb 21, 2008 | 10:10 PM
  #198
nonamer's Avatar
-Nice patch o rust on the front fender
-Semi rusted bumper
-Need a pair of needlenose pliers to get my back seats down
-Wheel well liners MIA
Old Feb 21, 2008 | 10:11 PM
  #199
nick_8787's Avatar
Bent my antenna back to the windshield last weekend in the mountains now it wont go all the way down. It just sits there halfway extended mocking me.
Old Mar 10, 2008 | 04:53 AM
  #200
3w41d's Avatar
Rear diff is rusted and leaking
warped rotors
rattles everywhere
