What is broken on YOUR Toyota
Old Aug 21, 2009 | 05:18 PM
  #381
*23's Avatar
*23
-driver seat shot.
-broken passenger side head light
-rear window switch and defrost
-no rear wiper
-blown brake line
-some one stole my stereo and chipped my dash trim up
-bald tires
-broken cupholder
-timing cover leak
-unstable steering stabilizer
-ok now i depressed.....
Old Aug 21, 2009 | 05:37 PM
  #382
874runnersr5's Avatar
-Rear quarters are bondo queen
- my tube bumper needs my old brackets to be welded in so its not loose as a goose
-windshield is cracked
-tail gate key doesnt work
-now my drivers side key is being a little bugger
- someone broke my sr5 seat lever
Old Aug 23, 2009 | 07:53 PM
  #383
fornesto's Avatar
*cig. lighter (the plastic pieces exploded - I just bypassed and popped a new one in elsewhere - What to do with the hole that is 78/100" or so wide?
*a/c dash vent (2/4 are broke inside - the louvers fell out)
*cupholders front and rear (there's something Americans just do better..maybe this is it)
*leather seat busted out to the left of my arse
*that little piece that covers the tab for when your transmission needs to get overwridden with a screwdriver to shift into D when it get stuck - it's lost
*the lights to 1/2 my stereo don't work - haven't in 6 years and 150k
*the stereo rejects CDs - just spits 'em out.
*the lumbar support button pops out a lot.
*my battery hold downs look a lot like a bungie cord... a lot.
Other than that, I'm in good shape for 240K
Old Aug 23, 2009 | 08:57 PM
  #384
v6854runner's Avatar
front windshield is cracked
stereo doesnt wanna play any type of cds
speackers are blown out
gauges dont work right
ac doesnt work
no seat belts
no rear wiper with no motor for it
sunroof bracket broke
oil leaks in transmission
back door wont open
driver side door cant lock
4wd wont work right
check engine light is on
rear anti theft light is on
steering column rod is broken
gas leaks by gas tank hose
the window roller is stripped so i have to use pliers to roll the window down
all this will be fixed soon on my 85 runner
Old Sep 8, 2009 | 07:54 PM
  #385
michaelross's Avatar
mine has dead aircon, oil leaks, is rusting already, broken car bra, window rollers not functional anymore, and dying shocks.. the tire's quite okay though.
Old Sep 12, 2009 | 02:19 PM
  #386
r8cfreak's Avatar
Originally Posted by Robinhood150
The only thing that doesn't work is the AC. Other than that there are minor things like the rear diff leaks slightly (which will be fixed when an ARB goes in) and a wierd engine tick.
i have that same tick if you find out let me know and ill do the same
Old Sep 15, 2009 | 10:55 AM
  #387
vandert's Avatar
A/C and my oil cooler leaks, and have a busted ball joint right now too. Other than that, she's great at 202k
Oh yeah, front right CV boot is torn, Windshield is busted, but today has been productive.
Got two upper ball joints, scheduled windshield for replacement tomorrow, and got the O-rings for the oil cooler at Toyota this morning for 11 bucks with my military discount
Old Sep 15, 2009 | 11:27 AM
  #388
toyota4x4907's Avatar
-Windshield
-rear pinion seal is leaking
-t-case output seal is leaking
-front cv-to-diff flange on both sides are leaking.
-front main oil seal
-burning oil I think (only reasonable explanation for oil loss, even though it hasnt lost any in a week)
-rear window comes off track 60% of the time when its going up or down. I know whats wrong, but I can't seem to get it to stay together
-passenger's side front suspension is about 1/2" or more higher than the drivers.
-weird starting problem, really random.
-massive blow-by build-up in the intake (taking care of that today)
-slight piston slap on cold start ups.
Old Sep 15, 2009 | 11:55 AM
  #389
Drgoodspd's Avatar
REAR BRAKEZ KEEP LOCKING UP......when i am at a stop, Rear brakez lock up until i gas it enough to "POP" them loose. When i am slowing to a stop they lock up in the last 2-5 feet!! gettin pretty annoying! I'm guessing it'z related to the E-brake. my buddy fixed it several monthz ago.....but it'z started acting up again!....Any ideaz??
Old Sep 15, 2009 | 12:12 PM
  #390
mokancraig's Avatar
My recently acquired 275k mile '94 4Runner has an engine knock, the rear window switch doesn't work (though works with the key), CD changer missing and the left front CV axle is bad...
Old Sep 15, 2009 | 12:13 PM
  #391
Windsor's Avatar
sometimes calipers get sticky, you may just need to get them rebuilt/replaced.
Old Sep 23, 2009 | 07:15 PM
  #392
CRF_450R's Avatar
2000 Tacoma, Ext. Cab 3.4
Freezer plug (currently being fixed)
Horn dosent work
ignition key opens passenger door but not driver door......
rubs when flexed
Rear U-joint was shot
tailgate is a pain to open
non matching tires
nowDented Shocks
dent in side where the chrome siding goes and its beg. to separate from the body.
no AC
No heater currently
Not geared
makes a horrible noise up front if i turn hard
need wipers
ty sound system
broken mirror
dosent shift as smooth/easy as my old yota
Old Sep 28, 2009 | 10:25 PM
  #393
jortiz2110's Avatar
Front passengar window wont go down!
Old Sep 29, 2009 | 01:41 AM
  #394
Camoyota86's Avatar
where do i begin???
-mis-matched gears
-3 oil leaks
-output seal on transfer case
-brake booster
-seats need to be bolted down
-have no seat belts
-need radio
-need to hook up oil pressure gauge
-cv boots torn
-need a quieter exhaust for hunting season
-needs to be cleaned up good
Old Oct 9, 2009 | 03:07 AM
  #395
Hurricane's Avatar
Bed and drivers front fender have been bondo patched, not too bad but not as smooth as I woulda done it.
Passenger side headlight has been rigged with screws and washers.
Battery tray is rusted about half out.
Some trim on the climate control is messed up.
One front marker is missing the light guts.
Drivers side window has a scratched area in the middle.
Drivers side window outer weather seal is gone.
Most of A/C is gone.
Most of emissions control is bad.
Mirrors are slightly mis-matched.
Carpet is the wrong color.
Shifter boot trim is missing.
The climate control vent linkage has a broken rod that turns heat to the floor.
Paint is a red-necked garage job.
Rear bumper don't quite fit, wrong brackets.
Engine smokes a little and ticks a lot.
Transfer case leaks a little out of the rear seal.
Passenger side frame has a few rotten holes near the bottom under the cab mount.
Passenger side wiper arm is set a little high at resting position.
Front tires are mismatched tread pattern and only about 15% tread left.
Rear tires are 60% tread left but are deadly recalled Firestones.
I may have forgotten to list a few things.
This truck is a real gem
The list of what is not "broke" would be shorter.
Old Oct 12, 2009 | 12:02 AM
  #396
Drgoodspd's Avatar
QUESTION : doez anyone have a ventvisor (one) for the front passenger side on a 3rd gen 4runner? mine broke...and i need only that one....kinda frusterating.
Old Oct 12, 2009 | 12:25 AM
  #397
yotaman90's Avatar
Truck-
1.Could use an engine rebuild
2.Input shaft on rear axle leaks
3.Has a sick exhaust leak at the muffler
4.Needs a new passenger side tie rod
5.A/C doesn't work
6.Blower fan won't work on low
7.Interior light won't turn on when driver side door is opened, passenger side works fine
8.Needs a new steering stabilizer
9.Needs paint
10.Carb could use a rebuild
11.Needs new u-joints
12.Needs new front bearings
13.Needs new front brakes
14.Half-moon gaskets in head/front main seal leak
15.Horn works when it wants
4runner-
1.Rear defroster needs to be fixed
2.Needs new front brakes
3.Small oil leak from driver side valve cover
Old Oct 14, 2009 | 04:59 PM
  #398
yotaman90's Avatar
Originally Posted by yotaman90
Truck-
5.A/C doesn't work
9.Needs paint
4runner-
Update: fixed rear defroster on 4runner today, works great!
Old Oct 14, 2009 | 10:38 PM
  #399
mudman6060's Avatar
Oh dang....where to start lol
well for starters when i bought the truck i had to put a new fuel filter, fuel pump, and main relay to get it runnin (bout $200). then i had to buy a TPS (bout $165) bc it was idlin horrible. then put exhauston it ($20...helps when yer buddy works at a muffler shop lol). then i had to get a slave cylinder (bout $15) so i could actually get the truck into gear and drive it.
sooo....NOW....1. the dim lights don't work 2. it doesn't have a radio bc the wirin for the radio is a big cluster 3. one of the reverse lights is out 4. need a new battery 5. needs alignment 6. tires need to be balanced 7. need to redo the rear bumper and raise it up to give me more clearance in the back 8. #4 cylinder is leakin out where the spark plug screws in 9. the antenna is broke...but apparently that's an easy fix 10. there's some clangin sound when i hit a bump 11. parkin break doesn't work
......aaaaand i think that bout covers it lol
Old Oct 23, 2009 | 01:46 AM
  #400
4runnerLT's Avatar
Hey im new to this forum, i just bought a 2000 4runner LT, and the auto door lock doesnt work, on both the remote and the switch inside. It unlocks but just wont lock, have to lock it manually. Ive been doing some searching, and it seems like alot of people are having the same problem, and noone found a solution. Im thinking it could be a bad connection, and dont know where to look. Please help!!!!
