What is broken on YOUR Toyota
Old May 13, 2009 | 06:14 AM
  #341
saitotiktmdog's Avatar
Tranny is on its way out. We shall see how long it can hold on. So if anyone has one for a 1994 pickup let me know. I wonder if it is turbo related (more power)
Old May 21, 2009 | 07:12 AM
  #342
fulk112's Avatar
Originally Posted by KING
If you're speaking about an axle seal, then no.
It looks like a brake line because the grease is accumulating in my rim.
I too have a leaking substance accumulating inside my passenger rear wheel and i pulled the drum off and i found a leaking axle seal, so it COULD be and axle seal or a leaky wheel cylinder
Other than that I need a timing kit ASAP, i broke a shock the other day( already fixed that), And I need to tighten my front wheel bearings up, idler arm and pitman arm are starting to have some play, and my low beam headlights dont work (cant figure out why)...... I think thats it for this week. Oh and my horn only works when the wheel is turned past 45*! Just spent $470 on new tires!
Old May 22, 2009 | 01:24 PM
  #343
jonwilly's Avatar
It isnt so much of a fix but i like these rims but i know nothing about them. I have different ones with the clear chipping off and now i got splotchy rims so that y i am looking to put something on that i like.
Old May 22, 2009 | 01:32 PM
  #344
874runnersr5's Avatar
my rear window key switch wont go down.. other than that shes running like a champ
Old May 23, 2009 | 08:16 PM
  #345
Windsor's Avatar
Originally Posted by Windsor
Toyota said that they can't supply a switch, no stock in country.
Fortunately, one of our lovely junkyard vendors hooked me up, for free (added to an order I had just placed).
I compared the switches, the old (broken) one is boned, the switch pin doesn't come all the way out. Either some serious cruft got inside there or something broke.
Anyway, it's fixed, my light works now. I recently replaced the oil pressure sending unit, so now my oil gauge works, and I got the 4Runner back from the transmission shop today.
After I get this wiring love done, I'll have to look for something more to fix.
What's done:
  • Wiring work done, I'm quite pleased with that
  • CB Radio installed
  • Spiffy compass/external-temp/auto-dimming mirror installed
  • Funky factory shift boots replaced with fresh hand-sewn leather goodness
  • Fabricated new skid for the tailgate spring, no more crunching sound when I drop/raise the tailgate!
  • L-shaped trim on passenger side replaced, although it needs a good cleaning, looks like it sat in the junkyard for a few years
What's left:
  • Redo wiring for temp probe on mirror
  • Install speaker baffles behind the 6.5" speakers in doors and cargo area
  • Install spiffy boat-style pivoting cupholders
  • Install electric lock solenoids and security system
  • Find another late-80s 4-spoke alloy rim and replace spare tire
  • State inspection (whups!).
Old May 23, 2009 | 08:28 PM
  #346
Windsor's Avatar
[*] Fabricated new skid for the tailgate spring, no more crunching sound when I drop/raise the tailgate!
OBTW, for those who are curious about this, look underneath between the tailgate and spare tire. If you see two broken bits of plastic bolted to the body with a nice rub mark in between, yours is broken, too! Another good sign is the telltale "crunchcrunchcrunch" sound you hear when you drop the tailgate.
Here's what I did...
Start with 2x2" angle-aluminum (you can get these at Lowe's):
  1. cut a 7" long piece
  2. cut off chunk to clear front mount
  3. cut off corners to clear body contours
  4. drill two holes for the mounting bolts
For the skid surface, I used 3/16" High-Density Polyethylene ("HDPE", you can buy 12"x12" sheets of these online):
  1. cut 7"x2"strip
  2. drilled two holes to align with aluminum bracket created above
Slapped it all together, voila!
(maybe I should pull it apart and take some pics..)
Old May 23, 2009 | 10:32 PM
  #347
Jay351's Avatar
Originally Posted by Jay351
Fixed:
-Clutch start switch (PO jumped the wiring so it could start with the clutch out)
-leaking valve cover fixed
- e-brake fixed (new rear section to go with the 1yr old front section)
To fix:
- TPS wire needs to be fixed
- Rust
- Dents
- weld in new rear crossmember
- Fix A/C
- rear u-joints getting a little old
- Reinforce marlin front bumper for winching
- flush heater core
- replace sagging door hinges
- replace drivers side door seals for door and window (VERRR tight!!!)
Yay, I just need some money and motivation!
I need money!!!
I replaced the door hinges (drivers side only, passenger side is pretty good)
I got all the parts I need to pull the intake and redo my TPS wiring, hopfally get on that in the next week or two..
Old May 23, 2009 | 10:38 PM
  #348
gary96360's Avatar
need to find where this high pitched squealing is coming from. and my front diff is leaking like crazy. better fix it before it gets ruined from lack of oil.
Old May 24, 2009 | 10:39 AM
  #349
FJHammerHead's Avatar
I've had a lot of things going wrong recently, however my currentl problem is with the rear window. The window will go up and down with the key. But when I use the switch, the window will go down when I press UP on the switch. Replaced switch and it does the same thing. So, I don't know.
Cruise Control doesn't work. Light comes on, but no go.
REPLACED;
Rear axle seals
Front & Rear brakes
02 sensors
Catalytic Converter
Tranny service
Three sensors in the tranny
Replaced broken headlights and corner lights
Changed differential fluids
Old May 27, 2009 | 08:12 AM
  #350
yzrider273's Avatar
-my driver and passenger windows suddenly stopped working (faulty ground wire i hope)
-my back window was replaced with plexiglass (grandfather thought it would be funny to hit a golf ball at my truck...)
-leaking valve seal
-valve tick....
and thats about it
Old May 27, 2009 | 04:42 PM
  #351
Xeo's Avatar
Xeo
-both passenger and driver side fenders have holes the size of my arms (rust)
-Both of my CV boots are cracked the outside ones
-Leaky Valve Cover Gaskets
-Left Rear Brake Cylinder is leaking (truck stops all that matters lol )
-Giant Hole on the Right Rear fender wall
-Entire Rear Bumper and fenders are rusted out
-Cracked Windshield
-Craked Intake Tube
-ADD doesnt work (the light is always on)
thats about most of them
Old Jun 1, 2009 | 11:55 AM
  #352
Windsor's Avatar
Angry
What's left:
Add to that:
* Fix A/C (it went out last weekend).
Old Jun 1, 2009 | 11:59 AM
  #353
scuba's Avatar
Rear passenger lower shock mount, Probably soon drivers rear lower too..yay !!
Old Jun 1, 2009 | 12:45 PM
  #354
firemaniac's Avatar
Oops wrong thred
Old Jun 5, 2009 | 08:56 PM
  #355
korn111685's Avatar
cv boot
smog pump
axle seals front and rear
carb
shock bushing
***but over all runs like a top...lol ok i lied a little. small issues, one at a time.
Old Jun 21, 2009 | 08:29 AM
  #356
Gator's Avatar
My Drivers front running light is missing (fender got hung on a creek bank and popped it out)
Dash wiring is messed up (shorted wires from CB install)
Running lights don't work (needs relay for rock lights so it'll quit popping fuses)
Transfer case shift linkage needs to be bent back to proper location (got bent while high centered on a rock)
Body damage from trees / rocks
Probably going to need new bearings up front (waiting on SAS)
Brakes are a little spongy (probably due to bearings)
Windshield is cracked
AC needs recharging
AT Temp light keeps coming on when trail riding / rock crawling
dash pad cracked on Drivers side
Old Jun 21, 2009 | 09:15 AM
  #357
ajoebob's Avatar
lost my master cylinder yesterday
my oil pan gasket is leaking
need a different air filter
Old Jun 21, 2009 | 09:26 AM
  #358
LTrunner's Avatar
my IFS in general
Old Jul 5, 2009 | 03:27 PM
  #359
Vicfire's Avatar
My centre bearing on my driveshaft is done, A/C pump went recently other than that she's all good. "Knock on wood"
Old Jul 5, 2009 | 03:37 PM
  #360
Drgoodspd's Avatar
ventvisor on the front passenger side fell off....
