What is broken on YOUR Toyota
Old Aug 9, 2010 | 11:10 PM
  #541
awsumfn's Avatar
Bent my front diff housing on both side last weekend . We are trying to straighten it but if that does not work maybe it is time to install a Dana front axle assembly.
Old Aug 10, 2010 | 10:50 PM
  #542
az4x4runner's Avatar
Update:
-Exhaust leaks fixed.
-AC mysteriously working, discovered this when I was going to try and figure out what the problem was.
That just leaves:
-Cracked windshield
-Slow leaking Oil Pressure Sender
-Need mic for CB
Old Aug 11, 2010 | 08:04 AM
  #543
Windsor's Avatar
Sounds electrical.
FWIW, '93-'95 RX-7s shared a fuse with the A/C and the aux power jack ("cig lighter" for us old timers). When you popped the aux power fuse, you'd generally not worry about it until your a/c compressor would never kick in.
Old Aug 11, 2010 | 08:27 AM
  #544
Chedo2.0's Avatar
Originally Posted by Windsor
Sounds electrical.
My cig lighter doesn't work, do you happen to know which fuse it is? well where it is located I can't seem to find any blown ones on an 88 pickup by the way
Old Aug 11, 2010 | 08:59 AM
  #545
1981 yota's Avatar
well now i think my ic regulator or voltage regulator aint working right
Old Aug 11, 2010 | 09:58 AM
  #546
wiggins's Avatar
rust hole back drivers side
rust on body
rusted out door
blown speakers
window washer pump
A/C compressor
window regulator
whole rear end
front ball joint
cv boots
cv joints
blinker lenz
cracked grill
bumper bent
exhaust just fell off
thats about it
Old Aug 11, 2010 | 10:01 AM
  #547
Windsor's Avatar
Either the drivers side kick panel or under the hood near the battery (original location).
Also, some fuses blow but don't look like it with casual inspection. You might need to test them.
After looking at the wiring diagram, looks like the A/C has its own fuse on the Toyota 4Runners/pickups. There are a couple of relays and a couple of switches that need to be satisfied to make it go, though.
Old Aug 12, 2010 | 05:29 AM
  #548
Chedo2.0's Avatar
Alright, Thank-you
Old Aug 12, 2010 | 08:36 AM
  #549
93yotaSR5's Avatar
a/c blows hot air
windshield has chips in it
ps steering fluid leak somewhere
Old Aug 12, 2010 | 09:04 AM
  #550
19RUNNER86's Avatar
<-----see profile pic...
Old Aug 12, 2010 | 09:23 AM
  #551
85gijunk4x4's Avatar
for some reason my p225 75 15's rub???
Old Aug 12, 2010 | 09:27 AM
  #552
1981 yota's Avatar
19RUNNER86 that sucks
85 how do those rub?
Old Aug 12, 2010 | 09:33 AM
  #553
lol, i really have no idea maybe my alxe is about to fall of lol haha
Old Aug 12, 2010 | 09:35 AM
  #554
1981 yota's Avatar
i wouldent be surprised lol
Old Aug 12, 2010 | 09:38 AM
  #555
^^^^hahaha lol haha
Old Aug 18, 2010 | 11:33 PM
  #556
Yoddaman's Avatar
Where to start. Rust... everywhere, right side of the sway bar, back window wont go all the way up and the tailgate is held closed by ratchet straps. but i drive it everyday and love it
Old Aug 19, 2010 | 07:03 AM
  #557
laskt9's Avatar
Old Aug 19, 2010 | 07:29 AM
  #558
bmxmike's Avatar
blew up pinion bearing but geting fixed today
snaped leaf spring
stearing box as a small leak
Old Aug 28, 2010 | 11:15 PM
  #559
Yoddaman's Avatar
this is what i was going up
ended up shearing the passenger CV axle in half at the hub
Old Aug 29, 2010 | 04:18 AM
  #560
xxxtreme22r's Avatar
haven't posted in this one yet, so here goes:
front drivers side spindle bushing, wheel bearing or hub itself, have yet to tear it apart, but metal to meal grinding sound can't be good. lol
The fuel cut-off solenoid on my weber is busted. (wire broke off) so every once in a while it will diesel down when shut off.
spare tire which was driving tire, now has a busted valve stem thanks to some thick mud
fuel level sensor not working, so no indication of fuel level.
Oil pan gasket leaking pretty bad.
One of the wires in the connector for my windshield wiper motor is busted so I have no high wiper speed just low.
Although not actually broken, rear spring sag baaaadd riding on overloads.
Front CV boots are torn and probably CV joints are wore, but not actually broken yet.
One of the U-joints (probably the front one on the rear driveshaft) starting to clang a little. I got a spare driveshaft, will replace when that finally goes.
That's all I can think of right now.
