What is broken on YOUR Toyota
Old May 27, 2010 | 02:19 PM
  #501
Mtnangie's Avatar
I need a new engine and now i'm taking the bus to work...(that should make you feel better!)
Old May 30, 2010 | 01:13 PM
  #502
coastsurf's Avatar
bad knock sensor
recent rollover damage
cut the top off destroyed front fenders
no doors
stock tires
i need to figure out where the knock sensor plugs into the ECM
Old May 31, 2010 | 09:24 PM
  #503
Zolgar's Avatar
Drivers side door switch doesn't register. (fixed with a couple of rare earth magnets)
Drivers side wing-window latch broken (fixed with cable ties)
Driver and passenger seatbelt buckles flakey. (they work, you just have to .. finesse them make sure they're working!)
Oil gauge reads low, perpetually.
Need new balljoints.
... for a 14 year old truck with 241K miles, not a hell of a lot!
*edits to add* Stock radio was bad. still trying to get a wiring harness rigged for my aftermarket. For now my radio is a pair of computer speakers and an MP3 player.
Old Jun 3, 2010 | 06:20 AM
  #504
3x0dyz's Avatar
1988 pickup 4x4 w/ 3VZ-E
this truck is 100% original with 271,717.8 miles on it.
original evrything except the seats, which are now buckets
my problem is an excesively worn cam lobe. (just one the others are fine) so i have a very obnoxious lifter tick. and no a/c or stereo. and i thnk the bushing were shifter meets the gearbox is worn away, shes picky wen i put her in first. ok i lied the other side of my pic is the bad side. my fender and door are smashed on the passenger side. friggin' blazerz!
Old Jun 7, 2010 | 12:41 PM
  #505
dtfitz07's Avatar
1989 4runner(Muffin)
SAS finish
Old Jun 7, 2010 | 12:46 PM
  #506
Chedo2.0's Avatar
Need a new fuel pump assembly, radio isn't getting any juice and exhaust leak. oh and I need a bed haha
Old Jun 8, 2010 | 01:37 PM
  #507
93yota93lude's Avatar
exhaust leak!
engine ticking getting louder
and clutch slippin (but still wheels nice in 4low) hahahahahahahaha yotas are awesome!!
Old Jun 8, 2010 | 02:48 PM
  #508
tj884Rdlx's Avatar
Originally Posted by michael1963
I don't know about all you guys in the states, but up here in Canada, a lot of our 4Runners have a crack on the top of the dashboard right between the tack and speedo that runs from the tip of the dash right down to the windshield. Man that drives me nuts!
if it's the same type of split/crack i have, there are a few fixes for that.
Old Jun 8, 2010 | 03:01 PM
  #509
myyota85's Avatar
head gasket
Old Jun 8, 2010 | 03:06 PM
  #510
tj884Rdlx's Avatar
broke stuff today:
headlight bezel broke
front valence mangled
front bumper bent
RF signal lens cracked
RF turn signal losing continuity intermittently
tailgate dented
rear bumper bent
RF fender dented
rear wiper washer inop
driver's recline and lumbar controls inop
dash split
cig lighter NLA
ashtray NLA
rearview shaky and stripped
hardtop cracked and leaking
this list is short because i sacrificed my wallet to the Gods of Yota over the last 2 yrs. but the "wish list" of improvements, rather than repairs, is still waaay long.
Old Jun 8, 2010 | 03:13 PM
  #511
Teuf's Avatar
Dash crack, direct from the factory.
Old Jun 9, 2010 | 10:54 AM
  #512
DirtyOregonKid's Avatar
Idle issues. can't locate engine ground. timing may need to be set back a touch as I think the PO advanced it too far. need to retrace all the wiring because the PO was sloppy. I've had this truck for less than a week, I'll find more broke stuff.
Old Jun 9, 2010 | 05:51 PM
  #513
Chedo2.0's Avatar
update, Fuel pump assembly came in (didn't fit quite right but made it work) Got all the lumber for the bed.. doing that tomorrow. Exhaust leak left needs tires and fuses for the radio most likely need to be replaced.
Old Jun 10, 2010 | 01:49 PM
  #514
87rustbucket's Avatar
Just went to fix my starter and found that my mint rust-free frame is cracked! I also broke the 4wd side of my t-case the other day, Awsome....
Old Jun 10, 2010 | 04:00 PM
  #515
Jazdude64's Avatar
My digital clock doesn't work-removed the dash-there is plug coming from the wire harness for it. I called the previous owner and she said it never worked. A friend & I field stripped the dash and could not find any wires unplugged. There simply is nothing to hook up to the factory clock! We are stumped.
Old Jun 10, 2010 | 08:21 PM
  #516
tj884Rdlx's Avatar
do you mean the female connector on the back of the clock is still there? that's great!
so just hard wire that puppy in there. 88 FSM indicates 4 wires, pin 4 is a red/green to ACC + (cig), pin 3 is Black/white to your constant +(dome), pin 1 is white/black to ground (body), and pin 2 is green to your tail light fused circuit (dimmer).
enjoy that new clock!
Old Jun 11, 2010 | 04:23 AM
  #517
Lysmachia's Avatar
Everything is broken on Tippy....
Old Jun 12, 2010 | 12:22 AM
  #518
808toy_soldier's Avatar
blew my motor in one of hawaiis famous soft sand beaches YOKOHAMA bay ... but i dont feel to bad its more i can do to my truck
Old Jun 13, 2010 | 04:03 PM
  #519
BlackFlatty's Avatar
-Very annoying electrical gremlin with right turn signal and brake lights
-low idle at warm startup
-sloppy body + motor mounts
-as previously posted, no naked girls
other than that, it's a solid rig
Old Jun 24, 2010 | 05:46 PM
  #520
Windsor's Avatar
Sigh. Right tailgate latch does not lock. The fork free-pivots.
I guess I'll have to fiddle with it this weekend to see what broke.
Fortunately it does not affect the window operation.
