What is broken on YOUR Toyota
Old Apr 20, 2010 | 07:18 AM
  #481
swaysidelife's Avatar
My thermostat seal is leaking... bought one yesterday for $3.00 easy fix.
Old Apr 20, 2010 | 07:43 AM
  #482
And i have a broken radiator bracket.
Old Apr 20, 2010 | 07:45 AM
  #483
Seanwain's Avatar
Originally Posted by Copenhagen
I really do not appreciate the tone of some of these replys here.
I do not consider myself to be "crying" or whinning. I consider myself to simpily be trying to state my experiance with the 3.0, in the hopes that someone else will not have to endure the same thing.
If there was something positive to say about the 3.0 I think someone would have already done it. It is my belief that you will be hard pressed to find many positive comments about the 3.0
In fact, I did say something positive. I said the 22RE is a better engine.
To be honest, if I had the money and the "want to" left to do it, I'd probably consider trying to put a 4.3 Vortec in there. That engine has a load of power, it would spin the 4 Runner sideways.
But I've put all my eggs in the same basket so to speak. And, now I'm broke I've got about $3500 in this thing, that is pretty much wasted.
I have the same feeling you get when you put a dollar in the coke machine and it takes it. Your like "Man!" And there is nothing you can do about it...it's just gone.
If I had read a post like mine, I would have known better than to buy a 3.0, I would have bought a 3.4 and did the swap. But I did not know.
Hopefully someone else browsing on here will see some of my posts, and they will know that is what they need to do.
It is probably what I am going to have to do.
Or either try and sell the thing for $1000 dollars and walk away from it. There is no way I'll get $2000 for it, I've been running it on craigslist, had a few lookers and no one is interested in it.
So, I'm just stuck with it. Or I'll have to take a big loss on it and get something else.
91 3.0, 320,000 miles has never left me stranded still has the original head gaskets with the exception of a few oil leaks it has been a GREAT motor!
Old May 13, 2010 | 06:24 AM
  #484
vanderwiel's Avatar
power steering leaks
muffler is ripe
pulls to the left when you get on the brakes
Old May 13, 2010 | 01:12 PM
  #485
clocklaw's Avatar
My 1995 4runner died two weeks ago on the interstate....don't know what's broke yet but hope to work on it this weekend.
Old May 13, 2010 | 02:53 PM
  #486
Agent Orange's Avatar
Front axle seals leaking, clutch slave leaking, rear wheel bearings almost toast. Nothing that can't be handled, but all a pain
Old May 13, 2010 | 02:56 PM
  #487
Teuf's Avatar
Oil pump seal leaks, Horn no work, dome light did not go on today, front passenger disc pads rattle, rattle from tailgate i think.
Old May 13, 2010 | 03:51 PM
  #488
camo31_10.50's Avatar
hmm where to start
motor is out of the runner waiting for oil pump, water pump, timing belt and tensioners.
before i pulled the motor, rear window did not go down, truck would not start..i was fiddling around with the rear window wiring at the bottom of the tailgate (was trying to get the window down to unlock the doors so i could get my keys ) and i was supplying 12v to the wires trying to find the one that makes the window go down......heard some fuses or relays blow up towards the front of the truck, guess i effed up
so gotta figure out the electrical problems, get the motor back together, and after that i should be fine
not many problems, just a few big ones LOL
the stereo is a problem for sure, gotta install my head unit, and my 2 type-R 12's
Old May 13, 2010 | 05:24 PM
  #489
michael1963's Avatar
I don't know about all you guys in the states, but up here in Canada, a lot of our 4Runners have a crack on the top of the dashboard right between the tack and speedo that runs from the tip of the dash right down to the windshield. Man that drives me nuts!
Old May 13, 2010 | 06:18 PM
  #490
Matt4Running's Avatar
Non working moonroof(broken cable)I replaced a fried alternator today,took me 2 hours.Brake and battery lights are off now.All is well,Im so frickin happy hehehe.
Old May 15, 2010 | 07:38 AM
  #491
sportrunner2001's Avatar
I have a bad seal on the front pass. side (real bad)
hitch is almost completely rusted out.
Rotors are really warped.
Old May 15, 2010 | 02:37 PM
  #492
Sportrunner,you got all that wrong on an 01?
Old May 15, 2010 | 03:04 PM
  #493
BIGBOCK's Avatar
Welp, here we go:
86 4runner - antifreeze leak due to previous owner jerry rigging heater hose/tube after he broke the top bolt off and then decided to silicone the crap out of it. Better I found it now than on the trail. Looks like a new timing cover without a broken bolt in it is in order.
98 4runner - radio antennae motor broke, drivers side vent broke, drivers side window wont roll down (something electrical) after father in law broke the switch housing. Replaced master control for window but no workie...
Outside of that my 4runners are kickin butt!
Old May 15, 2010 | 03:42 PM
  #494
streetlancer's Avatar
Gas gauge doesn't work unless full, horn no worky, A/C needs recharge.
Old May 15, 2010 | 04:44 PM
  #495
Blue_petersen77's Avatar
Not a damn thing now lol
Old May 15, 2010 | 04:46 PM
  #496
Teuf's Avatar
lol same on mine Gas gauge n horn
Old May 15, 2010 | 04:56 PM
  #497
1981 yota's Avatar
well lets see here driver side window wont go up
no horn
i have 3 1/2 sparkplugs
thats about it for the moment
Old May 16, 2010 | 09:37 AM
  #498
rowdy235's Avatar
Tacoma:
needs new belt
new front brakes soon (squealing occassionally and pulsing)
new tires soon
P/S Dome light switch don't work
missing P/S trim piece
hole cut in front of bed (NO idea)
Clutch is getting *knock on wood* a little soft
Weird vibrations/pulsations I need to get looked at asap, probably bad shocks
Too much to list on the jeep
Old May 16, 2010 | 09:55 AM
  #499
Sadly I do. I broke the front diff earlier this year in some hard snow and they overlooked that seal because the other side was snapped off.
The rotors have never been done before and I used to whip the E-brake a lot. At least it isn't like my dad's F-150, he has to mill them every 15k for some reason.
And I can't explain the hitch. I have to get the rust of and repaint it when school's out.
Old May 17, 2010 | 11:11 AM
  #500
sethb's Avatar
Let's see...
- antenna doesn't go up or down
- there are about three small holes rusted through in my muffler (i think that's actually the only reason I passed the CA smog... skewed readings due to less exhaust leaving tail pipe?)
- front dif is def leaking a little bit
- brakes are soft, like really soft and on a hot day they make this weird whistle when i first start her up and press the pedal
- my paint is faded to s#*!
- my steering wheel is cocked to the right, i know it makes no real difference, it's just annoying to look at
- I'm pretty sure the back passenger speaker is blown
- and one of the PO's cut out the middle lap belt in the back seat, like literally cut it out. It's still mounted to the floor and every thing, but it's only about a foot long now...
I could probably keep going but my head hurts after thinking about repair costs for all of this. I love my 4runner, and I knew what I was getting into when I bought her, but fml, i need more free time!
