What is broken on YOUR Toyota
Old Jan 27, 2010 | 04:32 PM
  #441
Lumpy's Avatar
Fuel gauges are over rated any way...
Old Jan 27, 2010 | 04:39 PM
  #442
myyota85's Avatar
in my case (under rated)
Old Jan 27, 2010 | 04:42 PM
  #443
bone collector's Avatar
87 pick up
Gas tank leaks
No E brake
Winshield Cracked
No radio
No Tach
No E locker
Not lifted
Old Jan 27, 2010 | 04:46 PM
  #444
peow130's Avatar
I cant remember if i posted in this lol.
Here goes..
Lights for heater controls went out.
heater control bezel is cracked..
speedo off by 10
gas gauge doesnt work until you're at 1/2 tank, or below 3/4ths..
something is whailing under the engine.. methinks power steering pump bearings..
possible timing chain slap
possible valves out of spec
rust holeno heat shield on exhaust, accidentally snapped bolts...
Old Jan 28, 2010 | 04:23 PM
  #445
Yota Yeti's Avatar
To do list:
- Timing Belt - (Not broken but found out it has 120k mi on it)
-Replace rear axle bearings
-Replace windshield
-Replace auxillary crossmember
-Replace main skid plate
-Replace right valve cover gasket
-Replace Cat
However, at 178k it gets me from point A to point B well.
Old Jan 28, 2010 | 05:29 PM
  #446
myyota's Avatar
My heater temperature control cable is broken, and my ARB is leaking air inside the front axle.
Old Jan 29, 2010 | 04:21 PM
  #447
sportrunner2001's Avatar
I guess I lied I also broke the front differential. At least I will get some new belts put in while its already there at the dealership.
Old Jan 29, 2010 | 04:31 PM
  #448
norcalyota's Avatar
he is throwing the code 71... o yay
and an exhaust leak that i thought i fixed, which is now coming from a different spot.
the rear is sagging
the heater does not work AT ALL... i mean not even luke warm heat.
the driver side locking hub does not like to go back to free from lock so i have to unbolt it and do it manualy...
Old Feb 3, 2010 | 07:47 AM
  #449
RebuiltRunner's Avatar
In a nutshell...
Old Feb 3, 2010 | 11:29 AM
  #450
peow130's Avatar
That looks like it'll buff out without any issues at all o_O
Old Feb 3, 2010 | 11:47 AM
  #451
yoder519's Avatar
what is broken on my toyota??? well lets see... on my 95, the rings lol
85- cruise control no workierusty bed rusty fenders. fron taxle needs rebuilt. has the original shocks, the list goes on
Old Feb 3, 2010 | 11:50 AM
  #452
kiyobrown's Avatar
Nothing!! Can you believe it? I am running out of projects....
Yoder- pull your cruise contol actuator out from under the hood. open it up. you will find cracks in the rubber diaphragm that hold a vacuum. Seal it up with rtv, put it back together, watch your cruise work again!!
I can't remember who posted that, but I ripped mine apart and lo and behold, it was cracked. now it works like new!
Old Feb 3, 2010 | 04:27 PM
  #453
Originally Posted by RebuiltRunner
Did you run in to a pole? lol I slid into a wall once.
Old Feb 4, 2010 | 01:58 PM
  #454
skyratcalls's Avatar
As of last night, lets add a head gasket!!!!! Ahh the smell of PBBlaster, just like grandmas house.
Old Feb 22, 2010 | 01:46 PM
  #455
95blackToy's Avatar
Well i just did the heads, clutch is slipping, whole exhaust has rust holes and leakes at the flanges, tailgait doesnt close, needs new seatbelts, power steering, thats about it
Old Feb 23, 2010 | 08:06 AM
  #456
clocklaw's Avatar
With my 1995 I think this thread title should be "What is broken on YOUR Toyota....TODAY???"
Submitted for your approval, the latest fun little adventure from my basket case:
The right bank of the exhaust manifold....slightly warped:
Old Feb 23, 2010 | 09:14 AM
  #457
cztheman64's Avatar
Doesnt like to start when cold.. and previous owner had 50w oil in the 22re, not quite sure why he did that.
Old Feb 23, 2010 | 10:50 AM
  #458
Richjrosa's Avatar
Wow this thread has been going for 6 years lol.. I'll add my list. My 97 has a small drivers side valve cover leak in the rear. It's not bad maybe I go through 1/2 a quart between oil changes and it burns off. I thought about getting it fixed but I figure when my timing belt etc needs to be done in 50K the cost of the two repairs will justify a rebuild 3.4 (at that time it will have 280K on it). I wish I has a local yoda wrenching buddy to work with I'd enjoy replacing the valve cover gaskets and doing the timing belt water pump hoses belts etc. The front brakes will need to be done this year. Just replaced the windshield added a rola roof basket and will be adding some AWC Raptor wheels soon. I also will be adding the transmission cooler I bought 6 month ago. Sigh.. I love my yoda!!!
Old Feb 23, 2010 | 11:11 AM
  #459
dark_fairytales's Avatar
timing chain guide broken and leaky axle seals, soon all to be fixed
Old Feb 24, 2010 | 07:46 PM
  #460
Pumpkinyota's Avatar
The entire wiring harness from my '79 is ripped out in its entirety, lying on my garage floor.
And the springs are flat. But only on the drivers side...
