What is broken on YOUR Toyota
Old Sep 22, 2011 | 09:18 PM
  #741
russ wharton's Avatar
Originally Posted by 85gijunk4x4
do i win?
i think you do but not just a win i think that was more of a massacer .... how do you drive that thing?
Old Sep 22, 2011 | 09:29 PM
  #742
ChefYota4x4's Avatar
W56 4th Gear Syncro.... and once in a while the others gimme guff! But never the "GRRRRRRRRRRttttttttttttttttttttttttNNNNNNNNNNdddd ddddddd" like 4th! hahahaha.
Old Sep 23, 2011 | 01:26 AM
  #743
SoCal's Avatar
Originally Posted by jbuck07
my horn doesnt work. any ideas on an easy replacement one?? and my brakes barely work....
What comes first Brakes or Horn?
Old Sep 23, 2011 | 09:49 AM
  #744
I DO have a solution for the Horn.... First, pull your grill(most likely, .....pretty sure I got mine from a 93 4Runner).... Check out the connector(doesn't matter much, as you can splice/solder the new one in) and then go to the Pick-Your-Part, and grab one off a Toyota Pick up or 4Runner.... I paid 5$ for mine(Dealership is like 80$).... and it works fantastically! I noticed that the Camry and Corolla and otherwise Horns were very similar if not exact... But I brought a lil charger and "beep".... and Cashier, and Home, and install! lol. It's actually in my build thread somewhere, hahaha.
Brakes? DON'T SKIMP! Pads and Shoes Brand and proper installation REALLY DO make a huge difference....
I will be hitting the Yard today or tomorrow(time allowed) and so I will keep my eyes open for one.....
Old Sep 23, 2011 | 11:30 AM
  #745
fissure333's Avatar
pass door handle won't open the door from the outside.
if the pass window is rolled down you can't open the door from the inside.
i'd fix it but i like messing with people and watching them fight it
Old Sep 30, 2011 | 12:08 PM
  #746
Tacomolas99's Avatar
I switched to a 1999 Taco 3.4 4x4 four months ago, and this is my first post since then. Barely anything is broken on this thing compared to my 1992 4runner. I've been extremely lazy with updating my profile, both with pictures and asking a mod to change my username to be both more accurate and less obnoxious. (Don't worry, it won't be r9e9d.....) ANYWAY, back to topic;
Center console lid is only held on by 4 circles of velcro
Parking brake cable recently snapped free
One of the power outlets is missing its little black plastic cap
The cruise control on-off button on the stalk is a little sticky
Driver's seat trim (the plastic that the recline lever pokes through) is off the screw (a washer will fix that).
Just topped 178k recently and that is a refreshingly small list of problems. I loved my 4runner but I do NOT miss it.
Old Oct 6, 2011 | 01:07 AM
  #747
91muddog's Avatar
RF Shock!!!!
Old Oct 6, 2011 | 05:30 AM
  #748
Jkelley429's Avatar
1. wont stay in 1st or 3rd gear- fixed
2. tailights dont work- fixed
3. instrument panel lights dont work-sorta fixed
4. speedometer off 10mph(whos isnt?)
5. CV boots tore
6. 2 rods knockin
7. valve tick
8. no e-brake (found that out the hard way)
9. sporadic idle when brakes applied
10. drivers side fender, door, and bed dented from 4-wheeling accident (who put that tree there?)
11. right turn signal doesnt work-fixed
12. 12v power outlet dont work
Thats all i can think of right know, but im sure theres more.
Old Oct 6, 2011 | 05:31 AM
  #749
richard212's Avatar
just re built my front end ball joints tre's idler arm everything now its time for the rear (leaking rear pinion seal)
Old Oct 31, 2011 | 02:00 AM
  #750
hbom's Avatar
1997 4runner V6 auto (USA)
- Leaking diff seal, the second.
- Broken clock, lucky the radio has one.
- Head gasket is going... sealed for now.
1995 Toyota 4runner V6 Auto (Australia) - bought last week.
- Broken fuel filler handle.
- Missing fuel cap holder.
- Leaking some oil (haven't gotten that far yet)
- Broken antenna
- Need new stereo (I love the USB stick radios).
- Faulty rear window switch.
- Small exhaust leak.
- Loose suspension.
- Missing skid plates.
- Could use: Tow hitch, off-road lights, better jack, better tires.
- Rear differential pinion seal leaks. I hope this and a top off will fix the 80km/h + hum. I doubt the oils ever been changed....
And today, while working on the differential: I broke the tip of a screwdriver into the drive pinion nut while trying to "un-stake it." So now, I'm charging the drill to try to get that out. Then if all goes well, I can get out the pinion bearing and oil seal for replacement. Then, put on a new nut to the right torque with no torque wrench, and stake it.
So I'll be back in a couple of days looking for a rebuilt differential.
Old Oct 31, 2011 | 02:46 AM
  #751
91muddog's Avatar
The driver!!
Old Oct 31, 2011 | 08:14 AM
  #752
Originally Posted by 91muddog
The driver!!
HMMMMmmmm, ...... eh? lol. Are we talking 'brokededed' in the organ above your shoulders?... or just that you got NO CABBAGE? hehehe. If it's the latter..... RIGHT THERE with ya! lol
Old Nov 4, 2011 | 04:14 AM
  #753
93Xtra-Cab's Avatar
My cup holder is broke. I tried to put in a bottle of water, but if just fell through xD Fixing it today!
Old Nov 8, 2011 | 03:01 PM
  #754
bassbro1's Avatar
'96 Taco SR5 4x4 5VZ-FE V6
Hmm, my cruise control doesn't work, but don't care.
It shifts hard (apparently the last owner replaced the clutch) and I really don't want to find out what is wrong but it needs to be done.
Bumper is tweeked upward.
It was pulled behind a motor home and they didn't shield the front end so it looks like it was blasted with gravel for 150k miles.
There is a lot of thick oil deposits under truck, but can't really see any leaks at this time.
I just replaced the water pump and timing belt and thought I would save money and not put any cam seals in (boy was I wrong). Now I need to go back in asap to fix.
Oh yea, it has over 427k original miles on it, and is basically a ticking time bomb for problems.
Other than that, its a great truck.
'88 pickup 2wd (driving while I get '96 fixed) (my workhorse)
The heater face plate is brittle. It contains several holes where fingers go through.
Light on right side of instrument panel is out. Can't see fuel gauge at night.
Front grille rattles bad. only held on with 2 screws. all self locking tabs broken.
Needs new muffler and pipe from header- back. pipe and muffler look like Swiss cheese. sounds like a farm tractor.
Gas pedal needs to be pumped over 5 times to get started in the morning.
Front suspension is shot.
226k original miles on 22R
Shucks, it drives like a champ though!!
Old Nov 8, 2011 | 04:06 PM
  #755
michael1963's Avatar
The power steering gear box is leaking pretty bad but, I have one being shipped from 86 SR5 4X4 (Joey) at The 4Runner House in Texas. Can't wait to get her back on the road.
Old Nov 9, 2011 | 06:22 AM
  #756
Night monkey's Avatar
I did the dumb mistake of unscrewing the 2 phillips screw on top of the air cleaner
Old Nov 9, 2011 | 08:08 AM
  #757
joobow's Avatar
Only thing wrong with my truck is I can't get my 4wheel drive to engadge
Old Nov 9, 2011 | 08:19 AM
  #758
thedrewski86's Avatar
Head gasket. Gettin' in there Saturday I hope.
Old Nov 9, 2011 | 08:39 AM
  #759
OH Mike, ... sorry man! Man that was a bear of a gremlin to chase for me(the steering issues I had)....and eventually..... the fact that it was Steering fluid that ruined my gear box that was supposed to be getting ATF! ....yeah, that was a hard lesson, hahaha.... But I can laugh now. Bleed it well and ENJOY, BUDDY!
Old Nov 9, 2011 | 04:57 PM
  #760
Thanks Chef....well I couldn't figure out why I was having problems only when I turned right, everything was fine coming straight again or turning left. I just kept putting in fluid thinking there was a blockage in the line and it would work it's way out. Parking on leaves and not noticing any fluid on the ground is why it took me a while but once I got the truck back in my garage and saw the little puddle forming....that and I asked my mechanic's what would cause this....added up pretty quickly. Now all I have to do is wait for a new one to arrive from The 4Runner House, get it installed and all will be good again.
