What is broken on YOUR Toyota
Old Nov 25, 2004 | 10:56 PM
  #101
slammdrider's Avatar
theres a couple things that need fixing on mine
radiator core support
passenger fender
rear slider
sunroof
bed has rust
rust under slider on passenger side
carpet
grill
head lights
tail lights
these are all things that are broken and will be fixed in do time when i have the money and hopefully none of them get much worse to the point where i have to buy another used truck....
Old Nov 26, 2004 | 05:55 AM
  #102
E1's Avatar
E1
Front swaybar bushings worn out. I will fix'em as soon as I decide on factory or aftermarket urethane?
Old Nov 26, 2004 | 02:13 PM
  #103
seafarinman's Avatar
94-
Front swaybar missing (took it off since it don't do squat to help on the trail or the road)
Trip odometer (hit the reset button too hard once and broke it)
body damage
87-
Body damage
transmission console cracked (bought it like that)
tailgate latch for right side mechanism (need to go to boneyard and find one) but the tailgate is off anyhow-going to the net for my 94.
dashboard illumination (the instrument panel works, but not the ventilation, or shifter indications)
Old Nov 26, 2004 | 02:28 PM
  #104
jimstoy's Avatar
[QUOTE=4x4Lamm]Seeing all these rich kids at school with brand new cars is getting me depressed lately. I love my 4Runner but I also would love for it to work 100%.[QUOTE]
Just place your front drivers side tire in the middle of a ricer hood . Any thing that may be wrong with your 4runner, just won't matter.
Old Nov 27, 2004 | 03:14 PM
  #105
4x4Lamm's Avatar
[QUOTE=jimstoy][QUOTE=4x4Lamm]Seeing all these rich kids at school with brand new cars is getting me depressed lately. I love my 4Runner but I also would love for it to work 100%.
I'm soooooo tempted everyday. One part of the parking lot is a sort of gravel and sometimes with an auto locker you can't help but kick a few stones. I get some real nasty looks. I just can't see why these kids get BRAND NEW cars. At least I know what all those "doohickeys" and "thingamabobs" under the hood do.
Lamm
Old Nov 27, 2004 | 09:23 PM
  #106
Mad Chemist's Avatar
Aarrgggh, what weekend! Okay, the short list is outer tie rod on Driver's side, sway bar bushings need replacent, sheared grease fitting (again) on driveshaft, a few other misc. things that need to be fixed.
Old Nov 28, 2004 | 02:38 PM
  #107
bbagwell's Avatar
Where to begin...
Holes rusted through the floorboards
Holes rusted through the sides and bottom of the bed
Clutch master cylinder leaks
It is painted with Herculiner and it is flaking off badly
The alternator light and brake light stay on whenever it is running
Drivers side brake light won't work - yes I replaced the bulb
Really crappy redneck exhaust
Bad front end vibration with hubs locked
Broken windshield - I mean really, really cracked all over, not a little chip
Sliding rear window broken latch
Shifter is broken, you can twist it all around
Radiator mounts are broken
Leaks oil
Loose u-joint in the front
No e-brake
No sway bar - like I would leave it on anyways!
Bad idler bearing pulley
That is about all I can think of for now. Heck I only paid $300 for it. I have done a ton of work to it, two engine swaps and pulled the tranny once. It actually runs really good, a hell of a lot better then it did when I got it. I have almost no money invested in it. It is an 83 so solid front axle. It will wheel with the best of them, and no worries about hurting it! Actually a damn reliable beast.
Old Jan 6, 2005 | 09:11 PM
  #108
photoleif's Avatar
Not to brag... but almost *nothing* is wrong with mine. I go through upper and lower ball-joints enough to keep Toyota in the $$, and I need to get a new Pitman arm. Aside from that and the tranny I had put in, my 4x4 has been almost perfect. Awesome piece of machinery.
Old Jan 6, 2005 | 09:35 PM
  #109
slustan's Avatar
inner and outer fender on passenger side
control arms
hood
radiator support
fan
fan shroud
battery cracked in half
had a date with a phone pole.......they broke up
Old Jan 6, 2005 | 09:54 PM
  #110
bike4miles's Avatar
I have fixed a LOT of stuff on mine and the only things lefft are:
1. AC doesn't work
2. Check engine light is on.
Old Jan 7, 2005 | 10:56 AM
  #111
joatmon's Avatar
Here's the list off the top of my head....If I do some more looking I could probably find more. But with 227000 miles it's not doing too bad.
Replace the windshield (it's really pitted)
Fix the Tranny (It's about to die)
Replace the shocks
Replace all the bushings (most of them are about dust)
Passenger side valve cover leaks
Battery is starting to have issues
Rear diff is starting to leak
Passenger side window switch doesn't roll the window down only up
Need to add a brush guard, lights, hi lift jack, cb.
Old Jan 7, 2005 | 12:30 PM
  #112
Yoter's Avatar
Guest
My latest broken stuff or nearly broken.
spark plug wires are weak (repaired)
K&N filter is dirty
power steering lines are slightly leaking
every now and then when taking off from a stop I hear a pop in the front end
speedo cable needs to be lubed up
Old Jan 12, 2005 | 09:01 PM
  #113
lookin4x4yota's Avatar
I've got a couple things gone wrong with my '83 4x4. Well...
1. My defrost wont work on the left side. Once I flip on the defrost things will clear up accept for the left side of the windshield and my drivers window. I'm not sure why...
2. My drivers side floorboard is getting wet durring rain! I can actually feel the water dripping onto my feet right around where the gas pedal is. And I'm pretty sure its not due to a faulty windshield gasket...
Other than that I can't think of anything right now. Can anyone give me some ideas to fix these problems?
--Jonathan
Old Jan 12, 2005 | 09:04 PM
  #114
A couple problesm with my Toyota
--Jonathan
I'M NOT EXACTLY SURE WHY IT POSTED TWICE, SORRY ABOUT THAT.
Old Jan 12, 2005 | 09:09 PM
  #115
Racer944's Avatar
No problems right now, occasional weird squeaks, though
Old Apr 22, 2006 | 12:52 PM
  #116
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
on the runner: ac blower is insanely loud but stealership needs to special order a new one to fix it, not worth it
on the taco: i havent physically seen my taco yet, its back home and im stuck here at school, so ill just say its perfect, heh
Old Apr 22, 2006 | 01:13 PM
  #117
4unner4life's Avatar
broken passenger side cup holder...
Old Apr 22, 2006 | 02:26 PM
  #118
callmej75's Avatar
1 Leaking steering box
2 Leaking PS pump
3 Front DS CV about to grenade
4 Valve pans leak
5 Knock in bottom end
6 No fan shroud
7 Misfires sometimes
8 Speedo bounces
9 Shifter sloppy
10 Rear window doesn't work when its hot outside
11 No center vents
12 Some dents
13 Power rear window switches work 5% of the time
14 Tranny slips on takeoff, #1 Solenoid code
15 Inner tie rods bad
Old Apr 22, 2006 | 02:33 PM
  #119
jwbehm's Avatar
1. Clutch is going out
2. Transfer Case leaks oil
3. 4x4 does not work as it should (not worth explaining, probably has to do with #2)
4. 15 mpg
Thank goodness for extended waranty!
Old Apr 22, 2006 | 02:45 PM
  #120
JHupp's Avatar
1 Most clips broken on interior panels
2 Rear speakers do not fit in doors correctly
3 Driver's window makes weird noises
4 Right front fender squeks due to a crappy install by me after my accident
5 Mad scratches, dents and dings
5 Headliner is pretty beat, carpets are damn dirty, and interior forever smeels like Taco Bell
