What is broken on YOUR Toyota
Old Aug 7, 2013 | 01:34 PM
  #1101
crazypaint's Avatar
Bad radiator rusted out rear axle housing wnd some shakey breaks wife gets mad but i dont mind tho
Old Aug 7, 2013 | 09:50 PM
  #1102
warmonger88's Avatar
My rear u bolt plate on the drivers side is torn in half. I drove it 90 miles like that without a problem. I never would have thought to look at the plates when I bought the truck.
Old Aug 8, 2013 | 06:07 AM
  #1103
ramblah96763's Avatar
I wish I knew so it could get fixed! and rust. a good dose of rust. and by rust I mean gashes and holes in my roof floorboards and bed with more rust around it
Old Sep 21, 2013 | 11:29 AM
  #1104
malvagio yota's Avatar
1989 Toyota Pickup
-Wipers only have one speed and that is fast
-Oil pan seal
-Front main seal
-Steering Stabilizer
And thats it haha thankfully
Old Sep 24, 2013 | 10:51 PM
  #1105
jes3se's Avatar
My 95 4runner needs some love.
Mechanically :
New shocks and stabilizer
New f/e bushings and tie rod ends
Diffs, tranny and transfer oil changes
A potential leak in the waterline under the plenum (alumaseal is taking care of that for now)
Big 3 upgrade
CV Boots
Battery
Interior/electrical:
new cargo carpet
New speakers all around.
More general de-funking
replace faded tint
Install CB
Interior Rear window switch (for camping)
3 way rear work lights (reverse, dash on, in hatch on, all off)
Install HID offroad lights leftover from another project
Rocklights left over from same project
New Ham radio to replace the one from the old project.
Somedays:
Tow hitch, rear bumper delete/replacement
Front Bumper
Possibly a drop in trunk box (under floor)
Sliders
So far I've done tires, Speedo cable, shifter bushings, oil change, coolant change, general defunking, oil cooler hoses, removed running boards, interior LED domes, blower relay, reverse switch, moog coils,
Not bad for a month's work and it still being a daily driver. and being out for a week with surgery. I feel somewhat accomplished.
Old Sep 25, 2013 | 12:43 PM
  #1106
Murcielago's Avatar
Originally Posted by KING
If you're speaking about an axle seal, then no.
It looks like a brake line because the grease is accumulating in my rim.
Brake fluid isn't greasy. And if for some reason you HAVE a brake fluid leak, you should fix it ASAP as the fluid reservoir on the master cylinder holds about 4 oz of fluid, so there's not a lot to spare.
Old Sep 30, 2013 | 01:14 PM
  #1107
rgOO6's Avatar
I do not know if this is broken, and I am new to the 4Runners. My transmission is not smooth when I am in 4WL and reverse. It is almost like the transmission releases and then takes a second to clamp again, so it causes the vehicle to jump slightly. I dont know if this is normal for the v6 automatic or not, but any advise would be great.
Old Oct 1, 2013 | 03:30 AM
  #1108
JakeMcGuire's Avatar
Missing both of my front corner lights. Just don't have the heart to pay so much to replace them.
Seat also needs recovered, but I'm leaning more more towards buckets. Any direct bolt ins for a 92 regular cab?
And I'm missing the steering column plastic.
Old Oct 1, 2013 | 10:37 AM
  #1109
ChefYota4x4's Avatar
Lots of info available on here and iH8mud and etc.... Not being sarcastic, I'm serious>>> try googling "3rd gen pick up/89, 90, 91(you get the Picture) - pickup seat swap".... You'll find lots of options.
Just try them out as my recommendations. If you go to the yards, synonym for a half an hour. I made a mistake and jumping the gun a couple times and I have a really wide back, especially at the ribs, and most everything I tried dug into my ribs at the bolsters.
You will find quite a few are almost to direct Bolton... But if you want a really solid see the last a long time, is fairly comfortable and has quite a few adjustments, maybe try A Scion tC f*** it. They are super comfortable and were just a little bit narrow for me in the back. A lot less narrow than many of the other ones I tried. I can't handle the prelude seats or any of the other ones that seem to Bolt in fairly easily... They're just tuner on the back and shoulder blade area,... They basically kill me after about a hundred miles. I've seen supra seats and a member on here name of Irab88 has put in Mustang seats I believe of the 90's era, and has since removed them and replace them with something else if I remember correctly.... It's a little different for pickups and I'm sure the 3rd gen Pickups are slightly different than the 2nd gens..... But you will find something that will fit. My last recommendation is to find the seat that is the most comfortable and that you think would fit with a little work or changing mounting brackets or tracks... Rather than trying to find the easiest seats to fit. A bad seat on a 300 mile trip is agonizing. Just doesn't seem worth it to me to compromise on this mod. I think there's even a thread on this, so have at it and good luck man!
Old Oct 1, 2013 | 10:49 AM
  #1110
PS: $22 each .... For the entire corner light assembly w/lens is too much?... For brand new?.... Come on man, bite the bullet and give her some plastic surgery to get rid of those crows feet! Haha. .. In all seriousness though, I have to pay that much just for the lens on my rear ones and it's almost impossible to find the front one for less than 35 bucks! ....
Here you go, go for it! Hahahaha... Sorry for the manipulation, I just think this looks like a pretty good deal. I may be wrong.......
http://www.carparts.com/details/Toyo...28-34-PLK.html
Compared to here?...... eeek! Lol
http://www.jcwhitney.com/1991-1992-t...91-1992j1.jcwx
Still, I would bet dollars to donuts at the dealership charges a little more? Bout 60-100 $ each?
Old Oct 8, 2013 | 03:48 PM
  #1111
rworegon's Avatar
Windshield washer reservoir is cracked and leaking....time to order a new one.
Edit: reservoir replaced, held on with four bolts....super easy job.
Old Oct 15, 2013 | 12:54 PM
  #1112
Roark's Avatar
1. Rear passenger leaf mount is almost rusted through..
2. There is NO fluid reservoir or motor for the wiper fluid.
3. The muffler is not much more than a big tin can with a pipe running through it.
4. Two of my tires are worn VERY badly from the previous owner running them for 20,000 with no rotation.
Old Oct 15, 2013 | 01:13 PM
  #1113
Just saw this on Toyota parts site the other day. The reservoir was reasonably priced iirc.
Of course, I was only surprise because that was regarding my truck. Little bit of year difference, lol.
Old Oct 15, 2013 | 05:55 PM
  #1114
rworegon's Avatar
Hi Chef! I ended up picking one from 1sttoyotaparts for less then the local auto parts store wanted for it. It's installed and all is good.
Old Oct 24, 2013 | 06:57 PM
  #1115
6840's Avatar
'83 pickup
I've got a bad "rumble" when in 4wd and deccelerating. I thought it was a bad ujoint, but that didntfix it. time to pull the front axle apart, I'm thinking ring/pinion or xfer output bearing...
Old Oct 24, 2013 | 06:59 PM
  #1116
6840's Avatar
Oh, and another one - '88 4runner V6 5spd. The darn thing will only start/run if I run a hot lead from the battery + to the coil... I'm guessing a relay isn't picking up but heck if I can figure out which one...
Old Oct 31, 2013 | 05:03 AM
  #1117
Lukeyota92's Avatar
Cannot figure out how to get my speedometer and odometer to work again? Everything else works on the cluster!
Old Feb 14, 2014 | 03:55 PM
  #1118
muddmadness's Avatar
Hmmmmm.....
Leaf springs are flat
tailgate doesn't like to stay closed
charge lamp stuck on
Brakes are iffy
have to double pump the clutch
window crank completely gone on driver side
rust holes on driver and passenger side floorboard
and finally we still haven't put her bumpers on
But this is the shortest the list has been since we bought the truck......
List getting shorter:
Tailgate doesn't like to stay closed
Rust in floorboards
still no bumpers
still no window crank
Leaf springs still flat
Charge lamp still stuck on but will fix this week
Old Feb 14, 2014 | 05:02 PM
  #1119
Teuf's Avatar
Nothing now.
Old Feb 18, 2014 | 08:11 AM
  #1120
lioneltrain513's Avatar
my 2004 toyota 4 runner back hatch won't open. i can here the motor trying to open it but it won't open. any help?
