What is broken on YOUR Toyota
Old Jan 27, 2013 | 04:10 PM
  #1061
MuchTruckLove's Avatar
1986 4x4 p/u, it just happened today i just got the truck recently, i put it in 4lo and cant get it out, anyone got any ideas? other than that its mint
Old Jan 27, 2013 | 05:10 PM
  #1062
bone collector's Avatar
^^^ try to reverse the truck slowly and keep trying to pull it out of 4 low... and you might want to think about changing the fluids in the tcase. My old 87 did that
Old Jan 27, 2013 | 05:19 PM
  #1063
should i try pulling it out as im moving?
Old Jan 27, 2013 | 05:22 PM
  #1064
you can try. im talking like 2 mph speed...
Old Jan 27, 2013 | 05:29 PM
  #1065
im glad i tried it before hittin the hills becuase its all pavement to get there.
Old Jan 27, 2013 | 05:31 PM
  #1066
ok thanx ill definitely try tomorow im blocked in with a sleeping roomate, i really hope this worx
i need/want/love this truck
Old Jan 27, 2013 | 06:09 PM
  #1067
Ya i understand the whole need/want/love of your truck..... Life is cloud 9 when everything is working and it is the depths of despair when stuff doesnt work...
Old Feb 1, 2013 | 09:55 PM
  #1068
Patriot's Avatar
Lost my #2 cylinder today... 160psi in 1,3 and 4 but #2 only reads 30psi...GggRRrrr...guess I need a set of exhaust valves!!! Will see when I get the head off.
Old Feb 2, 2013 | 09:44 PM
  #1069
UbendImend's Avatar
Rear wiper doesn't work, rear window switch works intermittently, a/c needs recharge....but all that is the least of my worries as I lost 3 cylinders in the 3.0 and am halfway thru a 3.4 swap!
Old Feb 6, 2013 | 09:46 PM
  #1070
Toymadness's Avatar
My poor toyota needs alot lol...everytime something breaks and i go to replace it all the bolts snap off, as far as i know the truck was in WV its whole life ive had it for a year and a half and been through 50,000 miles of road and fields with it and as of now it needs ...
a new front a rear bumper
new rear brake drums
some rust holes here and there
a paint job
new tailgate, or hinges atleast
a valve adjustment
new hoses through out the whole engine
a new battery
a rear view mirror...
new seat
new wire for my cigarette lighter, it was cut when i got it
new lock on the back sliding windows
aaaand a few bolts drilled out and replaced in my driver side hub assembly
just a few things for now...
Old Feb 6, 2013 | 09:50 PM
  #1071
Toymadness's Avatar
quick afternote...yes i use pb blaster and still break them, most of em are rusted...for as much rust is on my bolts the frame is in decent condition..oh and none of my seatbelts work ^_^
Old Feb 10, 2013 | 07:47 PM
  #1072
83yotastockR's Avatar
The real question right now is what is not busted on my truck right now. rear winow is good doors open Have a nasty windsheild leak tho
Not sure where it could be leaking from???? Got some nice 4 runner seats now with lumbar support Im so spoiled!! If i could drive the truck with no engine my wife makes fun of me when I just sit in the truck!!
Old Feb 16, 2013 | 01:40 AM
  #1073
Dale Rosales's Avatar
driver side hub gear and rear sliding window! And oh yeah in case you lock your keys in your rig it is cheaper to break the side passenger or driver window then it is the rear! Ask me how I know lol there was no other option
Sent from my ADR6400L using YotaTech
Old Feb 28, 2013 | 02:02 AM
  #1074
Eilif9's Avatar
Water pump, rust hole as big as my head in the bed, and rust holes big enough to fit your hand through in the frame.
Old Mar 5, 2013 | 02:12 PM
  #1075
andy4x4's Avatar
i broke my t case
Old Mar 6, 2013 | 06:39 PM
  #1076
x2468's Avatar
Ug so much ˟˟˟˟ right now. Lets see, A/C compressor bearings are bad, door seal has a hole, air box has a small hole chipped out of it, xtra cab window latches, center console latch, windshield wiper fluid light won't go off..... oh and the battery was dead the other day for the first time ever and I'm worried it might be the alt
Old Mar 6, 2013 | 07:59 PM
  #1077
crazypaint's Avatar
My motor lol it's out new one waiting for parts then install I hope it worth it sure is a pia
Old Jul 1, 2013 | 11:38 AM
  #1078
noble's Avatar
This thread should be titled what isn't wrong w/ your toyota... Much smaller list ... Well grenaded 2 of 3 front ifs differential bushings and sheared both CV axles on the trail... Something about a full steering lock bump over rocks totally worth it SAS in progress which was the logical progression to a broken IFS haha... A dented in rear tailgate so the window won't roll down, a dying front stock bumper and a missing front DS turn signal, and the funny thing is I wouldn't have it any other way!!
Old Jul 5, 2013 | 08:41 AM
  #1079
Steve 87turbo's Avatar
well only thing is air inlet hose for an 87 turbo ... to bad the hose is discontinued
Old Jul 5, 2013 | 08:51 AM
  #1080
warmonger88's Avatar
My drivers side rear u bolt plate is split in half.
