What is broken on YOUR Toyota
Old Apr 21, 2012 | 03:41 PM
  #861
Teuf's Avatar
well I am thinking the 02 did something, no more smell at a stop light.
Old May 2, 2012 | 01:02 PM
  #862
old fart's Avatar
Crap hitting the fan, co-worker put a sack of crap, literally right by the fan, the smell is god awful, coming into the cab.
Old May 2, 2012 | 01:47 PM
  #863
ChefYota4x4's Avatar
........ what's wrong?... well, I apparently have NO FREAKIN CLUE on this one! hahaha.
I'll letcha know what it WAS when it's solved.... Till then, it's a 'NOX FACTORY', lol.
Old May 2, 2012 | 02:36 PM
  #864
cheapneasycrndog's Avatar
I've got rust through by the gas filler gauge
Fuel Gauge inop
defrost/floor switch inop
horn inop
exhaust leak
both diffs seep a little...
Old May 2, 2012 | 07:53 PM
  #865
bassbro1's Avatar
Originally Posted by old fart
Water coming from exhaust pipe, was told that after i had by top end rebuilt 6 months ago, to re-torque the headbolts to 110ft lbs, instead of the recommended 100ft lbs? Tires are 8 years old, used when i got them, then sat for 6 years in storage, going with more used tires, 29x10.5/15's texas ots? good tread, just look really weird. Also just discovered LF cv boot is shredded.
How much water? A little water is not a problem. It is just condensation. What color is the water?
Well as I came around to 431K, I'm throwing in a clutch kit, new rear main seal, and new shocks. I am letting (with supervision) the students at the college do my clutch since I am doing my CWE (Certified Work Experience) at the moment. I decided to put my rear shocks on, and I found these:
New leaf packs coming next week :/
My rack and pinion needed replacing too
Old May 2, 2012 | 11:44 PM
  #866
macneill5's Avatar
Just replaced the knock sensor wire and radiator as both were old, and needed replacing. had gotten code 52. put the intake system back together, and went to start it up, and it made a high pitched whining noise. got out, and the whole passenger side of the engine was covered with fuel. it seemed like the fuel was coming from under the intake manifold, but not sure exactly where. I am going to be taking it apart again these next few days, any suggestions? or common mistakes that I could have made. Thanks, any tips would be great.
Old May 2, 2012 | 11:50 PM
  #867
macneill5's Avatar
It was my first time attempting to take apart the intake manifold on this truck...I also believe I might have messed up the timing belt, obviously nothing intentional, I know enough to know to match the markings, but feel like there is something else that I am missing that would make it much easier. once again, any tips or advice will be greatly appreciated, thanks.
Old May 3, 2012 | 09:28 AM
  #868
macneill5's Avatar
^Messed up the timing on the timing belt.* thought I would clarify.
Old May 3, 2012 | 07:19 PM
  #869
warmonger88's Avatar
My heater and defrost still won't work, radio has no power, 3rd set of front leaf springs are bowed backwards, and my patience has been destroyed.
Old May 3, 2012 | 07:36 PM
  #870
wii_tarded's Avatar
my 33's rub at full lock. and I've cranked the t-bars.
Old May 5, 2012 | 08:30 PM
  #871
rgraham13's Avatar
Have a first Gen 87 4runner, and my inclinometer will not work.., the little green light comes on but that's all, and if anyone has any pics of the inside of their 87 4runner please email me, cause my landlords son is who I have gotten mine from and the inside is almost stripped.. Thanks
Old May 5, 2012 | 09:44 PM
  #872
Asuarez737's Avatar
the only thing wrong with my 4Runner is that the A/C doesnt work but it was cuz i removed the wrong bolt. on the back drivers side i have a huge dent from an 18 wheeler who hit my truck while it was parked. my engine is dirty, and im losing coolant. just remember, toyota trucks are the only vehicles with a soul and they never die...no matter what!
Old Jun 4, 2012 | 06:15 PM
  #873
Mahuhu's Avatar
I busted both cv axle shafts and rounded out the splines at the hub this weekend out at Moab. :0( Need help replacing. Where do I get the spindles?
Old Jun 4, 2012 | 06:17 PM
  #874
Mahuhu's Avatar
As a sidenote: I replaced TWO driver side axles in as many days just one week before going out to Moab! Aside from going with a SAS, is there anything stronger I can throw in there? I've had the truck about a year and have replaced 5 axles (not to include these two new breaks).
Old Jun 4, 2012 | 07:07 PM
  #875
OJ Simpson 4Runner's Avatar
Rear trunk hatch doesn't lock or fully close if you shut the door lightly, also the the light in the trunk area that lights up when you open the door doesn't light up.
Old Jun 14, 2012 | 11:31 PM
  #876
logansrunner's Avatar
Bad rear window motor. I know you can get them on ebay, but why did Toyota discontinue or quit making them??
Old Jun 15, 2012 | 05:44 PM
  #877
Go to villagetoyotaaprts.com These guys have all sorts of factory parts from every model toyota since 1975. You could almost build an entire truck from this website.
Old Jun 18, 2012 | 08:42 PM
  #878
gooberclese's Avatar
Turnsignals, wipers stoped but motor, switch, and linkage are good (so are fuses and links..I cant figure it out) dome light and guage lights are out and the "box" by the pedal is just gone. No heater blower power. Have to slam the gears..does not grind just have to muscle it into first and reverse. The grill is busted. So so soooo many others.
Old Jun 19, 2012 | 01:20 AM
  #879
rear window motor
Thanks for the link, but I didn't see the window motor assembly for sale there. The couple local dealerships I asked about it told me that because Toyota discontinued making them, that they would not sell me one. There are plenty of them on ebay, but I would prefer a warranty on parts from a dealer or some type of automotive shop, over an ebay vendor.
Old Jun 19, 2012 | 08:48 PM
  #880
I hear that, I usually use the site for the diagrams attached to each part. They show an exploded view with all components labeled with part numbers. It helps when trying to track something down. Don't forget about the page though, there are some serious gems on there.
