What is broken on YOUR Toyota
Old Apr 4, 2012 | 09:34 PM
  #821
zerokelvin's Avatar
STANZ, did you check your back window where the wires connect to the glass? Sometimes those things are STUCK on there, but have corroded and are not actually connected. A little solder will fix them right up and get them connected again. I had that issue and checked EVERYTHING but those little connectors at the glass...took off the old solder, put on some new and bang.. good to go. Good luck
Old Apr 5, 2012 | 09:32 AM
  #822
stanz's Avatar
Thanks. I did have a broken wire and some corrosion on the connectors. Fixed up the connections, got rid of the corrosion, but am unclear on what solder you're talking about. The connectors I'm speaking to are the factory blade connectors that were crimped onto the wire and then slide onto posts on the bottom of the window track.
It gets juice, I know that -- the relay clicks and the light on the dash only illuminates if I have the blade connects in place on the window track
Old Apr 5, 2012 | 09:41 AM
  #823
CountryYota's Avatar
The list to what was broken and what still is broken is fewer, but still plenty.... lol iv been trying to get the interior to par, this is way i stripped it. the ebake sensor was messing up, it wouldnt start with out the ebake light being on. so i changed it out with my parts toya. it worked Great after that...... for like 16 hours, started it over and over e-light off and unnin great. i got up this morning and hauled off some things, went to get back in it... and it wont start. you can hear my starter clicking but its a no go... little fella let me down... besides this, i have a bolt in my floor pan snapped off, the steering shock is bad, fuel gauge doesnt work, radio wires are jacked up, bed needs replaced, temp sensor needs fixed and god only knows what else ill discover[IMG][/IMG]
Old Apr 5, 2012 | 01:32 PM
  #824
Black_1985_SR5's Avatar
Head gasket on my pickup
Rod bearing on my runner
And my cousins 86 runner I'm borrowing has no reverse
Old Apr 5, 2012 | 01:51 PM
  #825
stanz's Avatar
So it's like a big motorcycle with doors?
Old Apr 5, 2012 | 05:32 PM
  #826
warmonger88's Avatar
thats a slow motor cycle
Old Apr 5, 2012 | 06:37 PM
  #827
SnowDrive215's Avatar
I just felt like giving an update on whats broken hahaha!
1995 4runner just rebuilt top end...
-Valves clackin a bunch, not sure if they were adjusted correctly.
-Speedometer stopped working
-trans still does not shift automatically(bad solenoids hopefully?)
-temp gauge is always very cold(maybe installing an extra one to monitor the rad temp?)
-leaks lots of oil..valve cover may not be sealed correctly...poop i hate leaking oil...
Old Apr 5, 2012 | 06:41 PM
  #828
Yota802's Avatar
86 4x4
-Rust holes in cab
-head gaskets blown
-carb needs rebuild
-Dash lights come on when brakes are applied?(i dont know why this happens but it does.)
Old Apr 5, 2012 | 10:15 PM
  #829
Gabe Ruiz's Avatar
Problem OIL PAN GASKET
. 1986 TOYOTA
. model PICKUP SR5
. transmission 4 Spd Manual
. drive type 4WD
. standard options Power steering, Power brakes, Tilt Wheel
Usta run good until I started looking for the oil leak now I cant find a oil pan gasket that fits. The standard 20102 gasket is too small. It was made in Japan, the sticker has been ripped off I think it’s a 22 re., never checked if it was just a efi cover. Took of the valve cover to change the gasket and every thing went smooth
I was talking to the people at napa and he told me about LC Engineering wondering ifn I had one of those. Wondering why the gasket won’t fit? When I put up the gasket it was to small, in size, and spacing between bolts.
Old Apr 5, 2012 | 11:41 PM
  #830
zerokelvin's Avatar
STANZ, I was speaking in general. Many vehicles with the back glass defogging element have "tabs" that come out of the glass on both upper corners and either plug in (like yours) or solder on connections. You have the plug in kind which is great. I would disconnect the connectors and check the element in the glass with a meter to see if it carries current. If it does, then the glass portion is fine. If it doesn't, you'd need a new glass with element to get it up and running. As for the wires, etc, you can check those as well, but you said they have juice so you should be good. Glad I could help.. that corrosion causes all kinds of problem, but you're bound to have it after decades of no attention. It's difficult to figure out problems when something isn't sitting right in front of you But don't go buying a brand new back window before you have checked and trouble shot everything, just saying a new back window could be one of the possible problems
Old Apr 6, 2012 | 03:38 AM
  #831
Bassmastry101's Avatar
. 1986 TOYOTA
. model PICKUP SR5
. drive type 4WD
Toyota FIPG..Dealership will have it.
Old Apr 6, 2012 | 06:14 AM
  #832
does anyone know or have a wiring diagram for the 87 yota fuel wires? tryin to track down why my fuel gauge doesnt work i took out the seats and carpet. and i tested the wires going to the back the only one showing hot is when i turn on the lights.. there should be a constant charge going back for the fuel correct?
Old Apr 6, 2012 | 10:00 AM
  #833
ChefYota4x4's Avatar
Hey Country...
The gauge is IGNITION activated(IOW< the key has to be on).... BUT, start with "87".... what? Which model? I'm not sure where the wiring goes, from the tank onward.... But I don't think it comes through the CAB...??? I thought it went foward along the frame and then up through the chassis into the dash cluster... But I'd just be guessing at this point. I do have FSM's(A link to them) in my sig. Just go there and grab the 86 or 88 one(Don't think they have an 87 in that site).... download it and hit up the electrical section. It's 84MB(?), so it can take a lil while, depending on the puter.
Old Apr 6, 2012 | 10:08 AM
  #834
PS> As far as "Constant Hot" to the fuel.... Neither for the Pump. That is kicked on through the COR, (Circuit Open Relay)........ You might know that, wasn't meaning to be insulting... Just wasn't sure what you meant at that part, to be honest.
Old Apr 6, 2012 | 12:22 PM
  #835
. 1986 TOYOTA
. model PICKUP SR5
. drive type 4WD
Maybe you can use liquid gasket??
Old Apr 6, 2012 | 04:51 PM
  #836
LOL. i know the key has to be on, i was testing with the ignition on, besides that. the wires run from the tank along the frame through the cab under the seat to the dash. the pump is a manual pump so there wont be power there. but there has to be constant current in order to keep the gauge in the cluster to stay working instead of the gauge gauge showing what its suppose to be and shutting off. ill figure it out.
Old Apr 6, 2012 | 04:53 PM
  #837
Torpedo's Avatar
my drivers window interior frame is fubar'd so the window wont roll up and down. Since its heating up outside i'll be tackling that pronto.
Old Apr 6, 2012 | 05:43 PM
  #838
rworegon's Avatar
AFAIK, nothing is broken at the moment, but I am getting periodic static through the stereo.
Old Apr 6, 2012 | 08:49 PM
  #839
Gabe Ruiz's Avatar
thanks MANG
chekin out the silicone gasket sealant FIP orange. im trying to change it without pulling oil pan all the way out. already started and dono weather to put pull the tranny or keep going with the inches i have. or if it goes out the front already cleaned it off. took hours . im thinkin going along with it under the truck got enough to fit my hand in there. been carefull to scrape away from the pan with a flat head screw driver.
. wondering how big of a bead to put on it? one corn nut size bead or 2 Q tip size beads. . or :
. if one, should i put it on the inside or outside of the bolts?
. worried about oozeage and if i can over titen.
. or wait for it to dry then titen.
. or combination of all q tip size bead on inside of bolts and let dry then corn nut size the outside to creat a tight silicone seal without pushing silicone in the pan.
i bet the sealant has directions tho
Old Apr 7, 2012 | 03:27 AM
  #840
So your not taking the pan all the way off? Even though it is possible to do it that way, I would recommend to pull it all the way off and seal it right.
I like to make sure I have a good even coat across the mating spots on the oil pan and block with my finger, then add a bead as necessary. You want good coverage, not so much it runs into the pan. Run the bolts up with your fingers until it starts to push out a little. Wait an hour for it to harden up some and then torque to spec. That way it will kind of form to the pan and the block and harden to it and when you tighten it down it will seal it up tight!
While it's still wet I like to run all the way around the pan with the excess..kind of like your caulking a bathtub, just for extra insurance.
