What is broken on YOUR Toyota
Old Jul 13, 2008 | 03:23 PM
  #261
crews462's Avatar
Windshield leaks,
pinion seal still leaks
can't lock doors
dented and rusting tail gate (hit an apple tree)
rusted out rear bumper
other than that she's in pretty good shape.
Old Jul 13, 2008 | 03:34 PM
  #262
nix4x4's Avatar
***UPDATE TO MY ORIGINAL POST HERE***
I now officially have only one undamaged body panel
left on my truck (driver's side fender)
I wear my scrapes and bruises like badges of honor, because I've earned them all
Old Jul 16, 2008 | 10:55 PM
  #263
firemaniac's Avatar
There are a few things broken on mine, but the main thing is the connection between my brain and my left foot, it seems to have a mind of its own.
Old Jul 17, 2008 | 10:46 AM
  #264
highridinyota's Avatar
ps pump,rear end acts up.(cheap fix when it went out on me),needs new tires .bed has a dent in each of rear corners from factory bumper vs cypress tree.needs tires and clutch master
Old Jul 22, 2008 | 10:34 AM
  #265
Evol_Monkie's Avatar
I might have a valve ticking problem too
Originally Posted by Mr.Spock
MMM.. let me see
-valve ticking(i know it's normal but i hate when someone ask me if i have a "diesel")
My '95 4Runner has a slight rattle from the engine when I push the accelerator. Is this the same as the valve ticking?
Old Jul 22, 2008 | 12:34 PM
  #266
toyota-erik's Avatar
everything still works right down to the factory cigarette lighter
Old Sep 26, 2008 | 01:19 PM
  #267
slisdexia's Avatar
factory lighter doesn't work, interior light is funky(I never know when it's gonna come on when I open my door, the big ass hole in the passenger floor(I don't even want to look at my side), no stero or speakers, fan switch goes beyond high, strange idle/running issue STILL haven't figured out, sometime the heater works, sometime it doesn't, the entire cab is as stiff as cooked spagetti... insert other issues here
Old Sep 27, 2008 | 08:23 PM
  #268
Matt16's Avatar
Timing chain snapped due to idiot PO not torquing the bolts on the T chain guide. Bolt backed out and fell into the timing chain.
I poked a hole in a CV boot. Probably a sharp stick, cause this was after manual hubs.
Passenger's side mirror is missing and the windows don't go down, but considering it flopped, that's not really surprising.
Old Sep 28, 2008 | 10:07 AM
  #269
schmooot's Avatar
only key is broken off in the ignition. Can't lock my doors or raise/lower rear window w/ key. I installed a hidden kill switch for extra security but until I find a keyed lockset I just leave a bunch of empty boxes and junk in there and hide stuff of value if I have to leave it
Old Sep 28, 2008 | 11:48 AM
  #270
phildelfino's Avatar
88 4 Runner, no original keys, door locks hard to open. Any fixes?
Thanks, Phil
Old Sep 28, 2008 | 12:50 PM
  #271
nieuwendyk-25's Avatar
Originally Posted by jimrockford
- Cable on gas cap lever is frayed and about ready to snap.
That made me bust out laughing...I don't know why....
Power antenna on the 4Runner is stuck in the up position (I just got tired of replacing them every 30 K miles)
...Nothing broken on the Sequoia....yet....I have kids you know....
Old Sep 29, 2008 | 03:43 PM
  #272
Trustyrusty's Avatar
Thought I'd update my list...
1986 4X4 @ 169,XXX miles...
-Front windshield has three rock chips...
-Needs new shocks & steering stabilizer
1995.5 Tacoma 4X4 @ 300,XXX miles
-Water pump out (Never been replaced)
-White smoke on startup (Slight)
I swear these Toyota's really are POS's...
Old Sep 29, 2008 | 03:55 PM
  #273
TOYOTA 1's Avatar
i need a speedo cable for my 91..
hey rusty, all rigs have a lil white smoke come out of the exhaust on startup!
specially when it is cold. its just the condensation in the pipe/muffler evaporating!
Old Sep 29, 2008 | 04:01 PM
  #274
bigarms23's Avatar
fix speedo cable
save money for a 609 rear end
fix passenger side wheel bearings
install arb in front axle
Old Oct 1, 2008 | 04:32 AM
  #275
saitotiktmdog's Avatar
Passenger side door is hard to open from inside.
Windshield is cracked
bed has rust holes
every bit of body work has dents and or rust spots
tranny makes noise, especially fifth gear
driveline vibration (possibly U joints or tranny output play)
oil pan leaks a bit
frame needs addressing (rear crossover tube rusted through)
My turbo and engine seems solid. Thats what I thought would give me the most problems too.
Old Oct 1, 2008 | 05:31 AM
  #276
bipolarandproud's Avatar
87 4runner 4x4 : So far ,
exhaust manifold ,
knock sensor ,
tps sensor ,
Egr valve,
tail gate,
front oil seal,
Old Oct 1, 2008 | 06:06 AM
  #277
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
I GOT a
rusty tailgate
broken power ant
shot axel
driveshaft
rust around rear wheel wells
Old Oct 5, 2008 | 07:23 PM
  #278
Jay351's Avatar
Originally Posted by Jay351
Hmmm... Fixed:
Door lock
Center console
tailgate (bolts are in the mail!)
sunroof.
New list of broken stuff:
-Fix number 6 cyl spark plug
-fix rust
-fix dents in bed from old bumper
-fix steering colum cover (missing bolt so it vibrates)
-get A/C working
-Re-wire all aux lights with 10 guage
Fixed:
Number 6 cyl spark plug
Steering colum cover
re-wired lights.
New list of crap to fix:
-fix rust
-fix dents
-clutch start switch
-VC (tps) wire is broken somwhere along the harness (woooo!)
-leaky passenger side valve cover (got the gasket)
-E-brake is a little sticky
-Weld in new rear cross support (rusted)
-Get a/c working (for next summer)
Well, thats a good sized list for the new year
Old Oct 5, 2008 | 07:26 PM
  #279
toyospearo's Avatar
My drivers side wing window whistles above 50 miles per hour. It drives me absolutely crazy as hell!!
well, since its been a week I can add a few things to list: Right CV blown to hell, Tail gate sticking, missing lug nut.
Old Oct 5, 2008 | 07:46 PM
  #280
eatmorechicken's Avatar
I gots me:
One leaky injector.
Cam timing retarded (need to get adjustable cam gear).
Windshield washer resevoir leaks (mud sux right now).
Every panel in the interior is missing or broken.
Horn doesn't work.
Need crossover steering conversion (i hate changing lanes every time i touch the brakes).
ETC.
