Post your GAS MILEAGE!!
Old Apr 18, 2012 | 07:31 AM
  #1261
83_hilux's Avatar
27 mpg. 90 2wd single cab 22re 4 speed.
Old Apr 18, 2012 | 12:21 PM
  #1262
ChefYota4x4's Avatar
Originally Posted by blakefogt
Your not alone chef! I get the asme mpgs as my buddies GX470.. With a v8
I hear ya, Blake! Ya know... I REALLY think I should put this on the front burner... Cuz I'm likely wasting around 20$ a week that I don't have to, ya know? That's 80$ a month, which OBVIOUSLY can go to better use than GOING NOWHERE, like it's doing now! lol.
Old Apr 18, 2012 | 08:33 PM
  #1263
blakefogt's Avatar
ug.. dont get me thinking about wasted gas money :'( I miss my bug with the 1200cc engine. 30mpg for days! I used to get farther on 10 gallons :/
Old Apr 19, 2012 | 12:44 AM
  #1264
Well,... in a way, it's on the front burner................ FAILED SMOG! lol. (I know, you commented.... And I might need that number! lol)
Old Apr 19, 2012 | 03:57 PM
  #1265
pfmedic's Avatar
87 pickup
87 pickup regular cab
MSD 6a igniter box
MSD blaster coil
De-smogged
K&N air filter kit
Richmond 4.88s
Downsized from 33" to 31" BFG all terrains
Northwest Offroad header
Flowmaster muffler
2 1/4 exhaust
Alignment
Rebuild with recent Tune-up
full synthetic oil
tuned Aisin carb.
SR5 cluster swap to help ensure proper shifting.
So far 20.5 mpg city driving.
Old Apr 20, 2012 | 11:39 AM
  #1266
pfmedic's Avatar
Chefyota that is more than likely your accurate gas milage. Before I did all the stuff I mentioned above I got 12.75mpg. I have gained almost 8mpg doing all the stuff mentioned above. The two biggest differences in milage came from the regear and change in tire size. Although the regear is a very expensive project, (about $2000) the annual savings I calculated in fuel costs is $800-$1000. Thus, it will pay for itself in 2 years and if you include inflation, all my purchases to improve gas milage will pay for itself in under 3 years.
Old Apr 20, 2012 | 12:38 PM
  #1267
Dayum, PF, that's great!
Yeah, I'm running 31's, 4.30 gears, LCE header w/2.25" exhaust to a Borla, EFI, but none of the ignition stuffs you did.
I've been told by so many Guru's that it's very normal considering where I live... I'll try to get the most of it with some tuning, etc.... But everything's pretty much new. so for now, I'll live with it and fish into the issue as I go. lol.
Old Apr 20, 2012 | 03:01 PM
  #1268
pfmedic's Avatar
If I were you I would look into the regear and a tuneup. They will give you a decent increase and with the US economy going in the toilet coupled with our crippling dependence on foreign oil, I don't think you can afford not to do everything you possibly can to increase that mileage per gallon of fuel. Email me if you have any questions about anything.
ford.paul@gmail.com
Old Apr 21, 2012 | 07:58 PM
  #1269
yodadude2's Avatar
mpg
86 4x4, 22R, 31" tires, all stock. 19 mpg city or highway. got 20-22 when brand new.
Old Apr 22, 2012 | 10:02 AM
  #1270
s2_4Runner's Avatar
1995
Sr5 v6
4x4
5 speed
31x10.5-15
And i get 14.3mpg
Old Apr 22, 2012 | 11:43 AM
  #1271
TN_GIJOE's Avatar
95 t4r auto 4x4, stock
V6 245,xxx miles
235 tires
16 mpg
Haven't had a chance to do tune up since I bought her at 240k miles
Old Apr 22, 2012 | 01:42 PM
  #1272
Hey Medic... THANKS!
Yeah, I'm not sure on the 'tune up' portion, as everything is new(aside from the Dizzy/coil/ignitor). Low mile LCE Wires/Denso Plugs/OEM Cap and Rotor/Mostly all new Sensors/Running like a raped ape(for a 22re) up the more formidable Mountain passes here in So Cal with NO pinging or smoking or ... well, pretty much no 'visible' or 'audible' drama, ya know?
I'm fishing through a current issue of 'failing smog' over on this thread I started;
https://www.yotatech.com/forums/f116...nvo-th-252467/
I did a LAMBDA Calculator Test and it read(on the portion I failed, 25mph) "Excellent Fuel/Air Mixture and Excellent Operation of CAT".... I posted all that on that thread, second page, few posts from the last.....
Hoping to find a correlation(at least in part) to the lower city mileage that's occuring. And, seeing that it's been a WHILE, even before the full rebuild with all quality parts, etc..(and running like I've described).. I'm hoping it's something I can find through testing with the tools I have/that I can borrow if not, lol.
Thanks a lot for chiming in.. And I WILL hit you up, asap.
Old Apr 22, 2012 | 04:50 PM
  #1273
diablo's Avatar
89 shortbed 22re 4x4 blocked egr supra AFM 32x11.50x15 tires and 4.88s, 300 miles per tank city and 340 miles highway at 2800 rpm, about 65mph with valvoline 10w-40, a little better mileage with 5w-30 but I swiched back to 10w-40. My speedo is off a little so you get a rough idea.
Old Apr 23, 2012 | 09:18 AM
  #1274
BMcEL's Avatar
3VZ (256k original miles), 5spd, 4.56s, 33x13.50s, Rotella T6 5w40, K&N cone filter, AFM 3 clicks lean, intake silencer delete, advanced cam and ignition timing, MSD Blaster SS coil, MSD 8.5mm spiral core wires, Denso plugs & O2, stock manifolds to Magnaflow high-flow cat & muffler.
Just got 20.15mpg with the cruise set at 70mph on the highway and 500lbs of gear in the back. Tried to get better by doing 55-60 but that lasted for about a mile.
Pretty consistent 14-15mpg around town lately.
Old Apr 23, 2012 | 11:26 AM
  #1275
blakefogt's Avatar
I dream of 300 miles on a tank.
Old Apr 23, 2012 | 12:27 PM
  #1276
STRAZZE93's Avatar
i get about 17.5 city and 19 highway. 305 miles to the tank!!
all stock
Old Apr 23, 2012 | 12:38 PM
  #1277
I hate you all............... Ok, just 'many' of you! hahahaha. JK, it's all good... got me on the hunt for the best mileage possible, nothing wrong with that.
Old Apr 25, 2012 | 10:07 PM
  #1278
pfmedic's Avatar
Originally Posted by Blackulua
old 22re 1988 4x4 straight front with r151f 5 speed turbo trans
Doug thorley header 2 1/4 pipe exhaust with super 44 flowmaster
4:88 front and back open diff with 33 x 12.5 BFG AT and 15x10 MT alcoas rims
tuned to stock specs and having 22 mpg city and highway driven.
Gorgeous!
Old Apr 25, 2012 | 10:18 PM
  #1279
^^^ I concur... MAN, what a sweet ride(Love the White rigs, too!)!!!
Old Apr 25, 2012 | 10:19 PM
  #1280
pfmedic's Avatar
I have just filled up for the first time since the header and exhaust install. Im getting 20mpg even though im leadfooting it everywhere enjoying the increase in performance.
Im also able to drive on the highway at 70mph at 2900rpm in 5th gear with all the other stuff I have done to the build.
