Post your GAS MILEAGE!!
Old Sep 28, 2012 | 09:28 PM
  #1461
ChefYota4x4's Avatar
Originally Posted by Dirt Driver
I think I said long ago in this thread that my '94 22R-E/2wd/5-spd gets 27mpg in mixed driving and 29+ mostly highway.
What I didn't know then that I do now is that a 4x4-esque 3.4L auto Tacoma PreRunner (faux-by-four) gets about 20 mpg on average. That said, it will still scratch rolling 31" tires on dry pavement, which I doubt even a healthy 3VZ-E could do on wet grass.
Hahaha... that really cracked me up!
Originally Posted by daved5150
yes, the 22re. I'm getting some hesitation, and oil and water is dropping, so I'm doing the headgasket as i said. I know I can get better.
Ok....keep us posted. But I can't see it going much higher than that, esp. with a 4wd. Let some other guys chime in here.
gliding to stoplights actually uses more fuel. slowing down with engine braking in gear, uses almost no fuel, while you're using idle-fuel in neutral.
Ok, so our trucks shut off the injectors when the truck is in gear and foot is off the pedal? (Just checked this out online...)
Fuel cut actually engages anytime the idle is above 1000rpm and you begin breaking.(and with the throttle stop setting, which is why we have to check that throttle stop screw before Adjusting our TPS)... It's even more important in Auto's, as when you come to a light and have to suddenly stop.... You don't want the injectors continuing to get fuel...... /// ....... Works as well in the 22RE's... If I hold my RPM's at 1100rpm and hit the brake and hold it.... just sitting in the driveway on flat ground.... It will repetitiously cut the injector pulse off, every second or so. Seeing that we're coming to a stop in a 5spd, traveling down hill let's say, obviously we'll still be in gear... then it makes sense that the Injectors get cut as we're at 2500rpm in 3rd doing 40(or whatever it is, lol).. Totally contrary to logic to 'need injectors firing' when applying the brake and holding it there.
At idle, fuel 'PRESSURE' only is regulated, mechanically on mine, with the FPRegulator... Injectors keep on firing. BUT, if you keep your foot on the brake and race up the motor to 1200rpm or so... It should drop, continuously, every second, down to 750rpm, then back up to 1200rpm, over and over.
Seen many threads over time, with "My idle is going up and down, over and over", where a person would chase their tail and throw many new parts at it, from CTSensor to TPS to 02's to even AFM's... When most often, it was just the Idle/Air adjustment screw a bit off or in one case an IACV(AAV) stuck open, along with a perfectly normal function, "Fuel Cut". I've even seen, on one, a Tach was off(like mine and most of them are).... Where the tach read 800rpm and it was actually 1000rpm in reality... He went to a buddy that owned a repair shop and the buddy hooked it up to his Sun Scope.... "Your rpm is 1050, not 800"... VOILA, ..he reset it and it stopped doing that, haha
Old Sep 28, 2012 | 09:31 PM
  #1462
PS> Dirt Driver..... Seeing as you MIGHT be a Mel Gibson fan(at least of his acting, lol)... Curious if you saw, 'Get the Gringo'? hahaha.
Old Sep 28, 2012 | 09:42 PM
  #1463
ktetch's Avatar
PS> Not happy with 23mpg's? It's Average or above for a 22RE, far as I remember the Window Sticker's claim... (which is usually not something they 'reduce' in order to be 'humble or honest', hahaha... NOPE, they actually drive it with 10 computers on it and CRAWLING through town and never above 2200RPM and... so on, lol)
Oh, I know how they're done. Even looked into doing some car design/import work after I moved to the US, to give it some more capable cars (even the hemi charger is slower than the volvo's the UK police have been using for the last 20 years, and the cargo capacity is a whole nother story - so I had to look into EPA stuff hten)
Funny thing, I was going through the glove box yesterday, and found the original EPA window sticker. And the bill of sale (Feb 89, it had a sticker price of $19k and an 88 pickup was traded in on it)
I'm not sure what size tyres are on it, just know that they're the 'stock size' (http://i32.photobucket.com/albums/d3...ck/DSCF0039.jp gives you a look at them, this is from last year when the wife's uncle decided he'd give it to our eldest, when she got her license - he drives the 78 wrangler renegade in the background)
I will keep y'all informed on how the mileage works out!
Old Sep 28, 2012 | 09:49 PM
  #1464
Sounds good, Ktetch, I'll be watching to see. Far as the stock tires... That's a BIG difference, for sure.... I'm running 32's... and while they're not huge, they're not stock, lol. I guess maybe 4" over stock height? Maybe 3" over in width? >>>
But, I normally run 31's... And I do have 4.30's, which aren't the 4.56's the 31's SHOULD have to be 100% accurate...BUT, they're helpful at least.
Old Sep 29, 2012 | 08:50 PM
  #1465
daved5150's Avatar
Thanks for that tech explanation, Dirt and Chef.
Chef, beautiful 1st gen dude! Nice.....
Keep us informed Mr.ktetch.
Old Sep 29, 2012 | 11:47 PM
  #1466
Dirt Driver's Avatar
I don't think it's supposed to engage fuel cut if there is any throttle input at all. It might do that if the TPS is reporting 0% throttle when there is more than 0% being commanded, though.
Old Sep 30, 2012 | 12:49 AM
  #1467
Yeah.... I'm not sure I threw that out there properly, lol... Thanks, Dirt. TRUE, the TPS trippin can do things.. But what I think I mentioned, which is really what I've noticed, myself, is that "if the idle is set around 1100 or so.... When sitting at a light even, the idle will drop and back up, over and over, every second or so." ......
I noticed some odd things for a while now... I've got a lil 'mind of it's own' on occasion. Seems to be ambient temp related(seems to idle up when it's cold out, just around 100rpm or so)... I've adjusted the TPS many times, and made sure this one was pretty solid on the 'specs' dept... and of course, first set my throttle plate stop screw, before adjusting the TPS.
Anyway.... Thanks, Dirt... And i really need to read up more on the 'Fuel Cut' and a few other things.... (I see mudhippy throwing up stuff that really makes me want to get a few more things down, lol).. Not bad from where I was a couple years ago/spare time... BUT, can always learn more, eh?
Old Sep 30, 2012 | 09:10 AM
  #1468
Kingjerd's Avatar
On a tank....and i was terrified to go any further.
Bone stock 88 4Runner 5speed with 283,000 miles. Stock 22re rebuilt about 3000 miles ago.
Old Oct 5, 2012 | 12:00 AM
  #1469
dodge106's Avatar
1993 extra cab 4x4 205000 miles 31x10.50/15 13 mpg no matter where im at
Old Oct 5, 2012 | 04:05 AM
  #1470
Renegade4x4's Avatar
1995 SAS 33" tires, reg cab, 22RE 5speedwith about 156000 miles on it and I get about 20-25 with it. It only gets in the low twenties when I am slamming through the gears with a heavy foot.
Old Oct 5, 2012 | 01:12 PM
  #1471
ktetch's Avatar
I didn't do the head gasket int he end - It started raining, and engine in bits + rain = bad results from experiance.
I did do coolant, put in oil+filter (penzoil high milage 10w30 and a pureone filter) and cleaned and regapped the plugs, plus a new set of wires and blew out the air filter, AND cleaned the crap from the airbox. I also took the chance to liberally squirt carb cleaner in the plug holes to break down any crap that might be in the cylinder.
Did a 100 mile run yesterday (had to go into Atlanta to pick up some Glasses). Usually it kinda hovers at 60mph tops, now it was cruising at 70 effortlessly, and I even had enough power to pass on the 2-lane state highway that comprises the 20 miles between I-20 and my home.
Clearly I'm expecting my MPG to go up :-)
BTW, I recommend pulling your plugs and checking them semi-regularly. It's your window on the inside of the cylinder. Personally, I use a dremel+wire wheel on the electrodes to clean them up. any deposits degrade the spark. I used to do it weekly on my MG Metro twin-turbo, just because it was just a quick+simple job and helped me keep an eye on how it was running (although I cheated after 2 months, and had 2 sets of plugs - I'd just swap them then clean the set I just took out with less worry about stuff getting in the hole or damaging the plug and being stuck.
Old Oct 5, 2012 | 01:39 PM
  #1472
Old Oct 6, 2012 | 07:28 AM
  #1473
crjunkee's Avatar
Hi I am new to the site and thought this would be a good start on the site to say Hi
I have a 1994 2wd extra cab truck, with the 22re , automatic, wheels are stock 6" steel with Michelin tires 207/75/14 from Costco
The truck has 246,000 miles on it and I believe my head gasket may have just gone as I am loosing radiator fluid.
Around town 22MPG
Freeway driving 55to 60 mph I get 26.5 MPG
Freeway at 80 MPH I get 21 to 23 MPG
Old Oct 6, 2012 | 09:36 AM
  #1474
Dumpolina's Avatar
94 xcab 4wd 22re, 255/85's, 4.88, 180,XXX
surging cold idle from pluggy IACV
non-ethanol - 19.5 city hwy mix , 15-16 offhighway (60/40 2wd/4wd lowrange)
Ethanol blend cuts it to 17 city hwy
Old Oct 7, 2012 | 07:26 AM
  #1475
daved5150's Avatar
Hey dodge, you rocking the 3 liter?
What are your diffs gear ratio?
Old Oct 8, 2012 | 08:33 AM
  #1476
dodge106's Avatar
i have 410 in it right now not sure why i get the poor mileage other than most of my driving is in town and in the woods doesnt see much highway
Old Oct 9, 2012 | 07:01 PM
  #1477
daved5150's Avatar
What motor with those 4.10's, the 2.4 or 3.0???
Old Oct 10, 2012 | 03:35 AM
  #1478
dodge106's Avatar
its the 3.0 good news is im going to look at a 1986 4runner tomorrow. hope its worth the long drive.
Old Oct 10, 2012 | 07:04 AM
  #1479
BMcEL's Avatar
Plenty of information on the 3vz if you search around. Some people love it, some people hate it. Read:
https://www.yotatech.com/forums/f116...k-3vze-187741/
Old Oct 12, 2012 | 05:48 AM
  #1480
dvaldi's Avatar
95 4runner stock everything except K&N filter, 15-16 mpg..lame! My 2000 Landcrusier gets 18-20 mpg.
