Post your GAS MILEAGE!!
Old Jun 11, 2009 | 03:45 PM
  #461
dutchboy's Avatar
Originally Posted by jmlmarine
I have a 90 runner, 31's, bone stock auto but i am only getting 13-14 mpg with mine. the others on here are getting a lil bit more, I wonder y?
Don't feel alone,Im getting 14 city/17 highway.
I also have a 90 4runner,automatic,stock with same size tires.
I was told,that if I change the O2 sensor,I'd pry gain about 3-5 mpg.
My rig has 227,000 miles on the factory O2 sensor.
Gonna change it here,real soon and Im anxious to see the difference in that little bit of mpg increase.
Old Jun 11, 2009 | 03:54 PM
  #462
geminiroq's Avatar
I have a 1987 4runner turbo and I get...on a good day...about 16mpg running on 31inch tires.
I think the reason my runner is getting that kind of milage is the fact that my auto trans is slipping bad and I need to have the rear bearings done.
Just a thought....
Thank you
Old Jun 12, 2009 | 07:02 PM
  #463
mrddk92's Avatar
I'm trying to decide whether to get a bosch or a denso o2 sensor, the denso is like $19 more. What would be better? They look almost exactly the same to mee..
Old Jun 12, 2009 | 08:52 PM
  #464
mrddk92's Avatar
Old Jun 12, 2009 | 08:56 PM
  #465
Dirt Driver's Avatar
All reports I have seen say to get the Denso/NTK sensor because it works better. I don't know why the operating parameters would be different, but that's what I saw.
Old Jun 13, 2009 | 07:49 PM
  #466
Junkers88's Avatar
Just got back from a 450 mile trip to go fishing and averaged 23.37mpg for the trip.
22re, 218,000 miles, 5 speed in a loaded to the gills (with camping crap) 1989 4runner.
I'm thinking when I go synthetic next week I might get even better economy.
Old Jun 13, 2009 | 08:47 PM
  #467
BoostedRNR's Avatar
So far I'm getting around 16-17mpg. 22rte, T-3 turbo, 2 1/2 exhaust, Sweet ass intake, 31" tires, Gay ass auto, and the rest is bone stock. Can't wait to post after I get the manual swapped in, better exhaust manifold and better gears.
Old Jun 16, 2009 | 01:42 PM
  #468
Clayship's Avatar
1991 4X4 DLX EXT Cab 3VZE 5 spd 17" street tires 253,000 miles with low compression in the #6 cylider=12-13 mpg city.
Old Jun 16, 2009 | 02:59 PM
  #469
Tubbyfatty's Avatar
I replaced my spark plugs (NGK g power) in my 94 4runner, im getting about 16-18mpg. Mixed driving.
I was getting around 13 or so before i changed em
Old Jun 18, 2009 | 06:53 AM
  #470
monoxide_85's Avatar
1994 2wd with a 22re, 255/70/15 tires, manual trans, heavy foot, same 20 mile stretch of road to work and back everyday and I get 15 mpg. It's running rich though, I can shoot fire out the tailpipe! K&N air filter and an exhaust with no converter and a glasspack
Old Jun 18, 2009 | 10:02 AM
  #471
vivagoa's Avatar
I have a stock 1991 22re Xtra Cab 4x4, it is less than 2 weeks old, I had to add a new speedometer cable, the odometer does not function properly trip meter right three digits work. so I have fill up before hit 100 miles. I got 21 one time and 17 one time. I am not sure why the vast difference. Anyway I am open to suggestion. Truck has 31" if I switch it down to some 235 or 225 will that help. I am doing 90% highway driving. I will ad more mpg as days go by.
this time I got 18mpg, any suggestions on changing the tires sizes back to factory.
Old Jun 18, 2009 | 02:06 PM
  #472
jmcgowan's Avatar
dude, it's running WAY rich, you should get twice that. I have the same basic truck but automatic and it gets 22-24mpg
Old Jun 18, 2009 | 03:14 PM
  #473
JaredL's Avatar
my mpg's on 85 4runner and 93 pu
Both are 4x4.
4runner is an 85, auto, 22RE, 260,000 miles, 2 inch lift, 32 inch AT Yokohamas. The 4runner gets around 17-19 mpg.
Pickup is a 93, Manual, 22RE, 160,000 miles, no lift, 31 inch AT Yokohamas. The Truck averages 19-23 mpg.
Old Jun 18, 2009 | 04:11 PM
  #474
jmlmarine's Avatar
Yeah I got under my Runner and noticed that my o2 isn't even hooked up and then I wired it up and fried my fuse box but that is fixed now. I have to get a new o2 sensor now also. i guess that is why i am only getting 12-14 mpg!?!
Old Jun 24, 2009 | 03:52 AM
  #475
Ezrider_92356's Avatar
i recently checked my millage 22re 5 speed 2wd lifted running 31x10.50r15's when i checked it running about 70% 20% city with spedo correction and light foot i managed 24mpg
Old Jun 25, 2009 | 03:35 PM
  #476
borz170's Avatar
'94 4Runner SR5 3.0 vz-e 31x10.5's. K&N air filter, replaced O2 Sensor, High $ NGK's (unsure on exact model), new cap/rotor, wires, plugs and fuel filter. Newer fuel pressuer regulator.
I only get 11-14 mpg with mixed driving, but I used to get as much as 17 on 90% highway. This was back in cooler weather with no a/c running. Everything else the same.
Since the ethanol 10% fuel mixture has been messing up our FL vehicles, I have been running a product called sea foam. This stuff can go in the gas tank or the crank case. When added to fuel, it supposedly cleans fuel systems. When added to oil, it cleans engine deposits and carbon buildup. One thing it doesn't advertise is it's leak slowing/stopping qualities. I added 1.5oz/qt oil =7.5oz to the crank case after losing a quart in 1200 miles. I then only lost about 1/4 quarts in the remaining 1800 miles 'til the change. As far as mileage, it doesn't do anything, but the truck runs smooth.
Old Jun 26, 2009 | 12:51 PM
  #477
kodiak90's Avatar
1990 3.0L 4x4 rollin' on some 32inch BFG AT's I get around 15-16 MPG. If I'm playin' in the mountains I get about 8-9MPG.
Old Jun 26, 2009 | 01:14 PM
  #478
vital22re's Avatar
totally a bro
92 5spd 3.4 swap 4.56 gears 265/75/16 10ply terra graplers with a high rise canopy gets 18-19 for now. Gonna sea foam the engine and fuel system see if it changes.
Old Jun 26, 2009 | 01:18 PM
  #479
jackwolf's Avatar
12-16 mpg
Old Jun 27, 2009 | 12:55 PM
  #480
88greyyoter's Avatar
88 toyota pickup stock tires 22re 4spd auto 25 mpg highway 70 mph
