Post your GAS MILEAGE!!
Old Feb 19, 2010 | 04:45 PM
  #661
Teuf's Avatar
wow cool, thats so green.
Old Feb 19, 2010 | 08:12 PM
  #662
Philbert's Avatar
1987 4runner
32 inch tires
4 inch lift/IFS
15 city | 18 HWY | 1-17 combined
Just got LCE headers and exhaust on so we'll see if that changes anything
Old Feb 19, 2010 | 08:14 PM
  #663
ramtime's Avatar
'02 Excursion V10 Limited
8MPG on a good day!!
Old Feb 20, 2010 | 09:51 AM
  #664
t.suzuki's Avatar
My first post!!
93 22RE 4Runner IFS 380,000+ Km (24600+ Miles) BONE STOCK...
Tires: 235/75/15 @ 35ish psi
City: 20 mpg
Old Mar 5, 2010 | 07:11 AM
  #665
1sennafan's Avatar
22re 5spd 410s and 31x10.5
17 or 18 highway
about 2mpg in 4 low
Old Mar 5, 2010 | 03:23 PM
  #666
t84bird's Avatar
1994 4runner 3.0 auto. 31.50 bfg's 120,000k
17mpg mixed driving, lead foot at times.
Just replaced head gaskets, and everything that goes along with that.
New factory toyota plug wires, plugs, vacuum switch, oil filter.
Purolator air filter, casterol synthetic oil (toyota oil filter).
Drivers side cam timing was retarded by one tooth. Had one bad exhaust valve on pass side head, so low compression in that cyl. Head gasket failed on that side, front cyl. Driver side gasket looked to be failing at back cyl.
Dealer didnt replace headbolts when doing the previous head gaskets under recall back at 60k, not sure why?
Code 25/26 too rich/too lean also went away after all this work, so I'm guessing it was from the cam timing being off.
This thing was such a dog before, really I have no gripes about the 3.0 being that underpowered now. Its no rocket, but does everything I want it to do.
I could barely go 70mph @ WOT before, now I can coast at 90mph barely on the gas...lol This thing takes hills fine.
Could barely get 100 miles out of a full tank before, now its about 250 and I bet I could stretch it farther with more conservative driving.
Old Mar 6, 2010 | 07:14 PM
  #667
prelude85's Avatar
Apparent 40k 3.0 engine swapped in. Required a mini rebuild ended up cleaning out the inkate mani, plenum and throttle body.
From my move from Cali to Colorado PACKED, i actually managed 17mpg average. Rolling on wornish 31s. Pretty amazing i say.
In Cali it was around 14-16 mixed. Here in Colo it's about 12-13 mostly highways. The hills and 75mph highways are killing me.
Old Mar 6, 2010 | 07:29 PM
  #668
dromomaniac's Avatar
94 xtra cab with the 3.0 and 5spd. 32x11.5 tires, no lift. Oil leaks.
When driving is >75% highway: 18-19 mpg. I drive it like a grandma on the highway. Pass big rigs slowly enough to read a full page of a book, if they held one up.
When mixed, probably around 15.
When mostly city, or on back roads: 10-14. Depends.
The worst I've gotten was all on forgotten roads in the desert in the summer, and that was bout 10 mpg.
Old Mar 15, 2010 | 11:04 AM
  #669
24Runna's Avatar
Good news! I found that the wire going from the coil pack to the cap had so much corrosion or something that the resistance was 60kOhms! Fixed that, changed the oil, and changed the diff fluid.
Was getting around 15-16 on the highway (75MPH, 4 people and all their luggage from college), now I'm getting 18.67!
Made me pretty damn happy, haha.
Old Mar 16, 2010 | 05:44 AM
  #670
jammer1313's Avatar
my 88 truck,3.0,lifted and on 31's gets 15 mpg
my 86 4runner,22rec,auto tranny, and on 30's gets 20 mpg w/ a/c off, 17 mpg w/ a/c on
Old Mar 23, 2010 | 05:55 AM
  #671
Wrenchinjoe's Avatar
I have typically gotten 15 - 16 mpg around town. Over the past 6 months I have replaced the spark plugs, rotor, cap and wires, installed manual hubs to free up the front end and done the ISR mod. My cat went out last week so I only have a muffler on currently.
I took a road trip to Boone, NC last weekend, mostly interstate but some city miles through JC and Elizabethton, also up and down some significant climbs.
I have NEVER gotten 300 miles out of a tank before, but this time I rolled back into Knoxville after 310 miles with a quarter tank left!!!!
Just filled up, put in 15.9 gallons, the trip odometer was at 359.1 (drum roll please........) that is 22.58 MPG!!!
I recently picked up a set of Thorley headers to install once the weather warms up reliably, so my mpg could still improve a bit more
Old Mar 23, 2010 | 08:54 AM
  #672
24Runna's Avatar
Wrench, what was your avg. speed?
Old Mar 23, 2010 | 09:15 AM
  #673
MB4runner's Avatar
Originally Posted by rangerruck
just make sure your engine is hot, when you do the treatments. wait at least 15 mins, before you restart, blow all the stuff out with hi up and down revving for about 5 minutes, and do 2 treatments in a row 6 ounces each time, throw the rest of the can in the gas tank.
Well I finally got around to seafoaming my truck, but I also put 35's on haha.
Anyways, on 31's I got 10 mpg in winter (super cold winter)
After sea-foaming and 35's, I'm still getting 10 mpg but it's spring now.
So between the seafoam and spring I put on 35's without affecting my fuel mileage!
Old Mar 23, 2010 | 09:29 AM
  #674
prelude85's Avatar
wow amazing, 22.58...
I have hubs on the way so i'm hoping that'll boost my mileage. Would a cat really make that much of a difference? I gotta look into this ISR mod.
The time before last i managed 15.xx miles per gallon. I added oil to my differential and transfercase. Turned out i overfilled it as it was spewing out of the transmission ha. So kinda new fluid in there.
This last time was i think mid 17s. Properly inflated my tires. I had a random set of numbers going. 50, 40 30 and my spare was at 20. ha! (i'm stripping and clearcoating my rims so my small spare is rotating through) Got them all to 40. I also decided to put some Lucas gasoling treatment.
The final day there was a heavy snow storm so i had to run around in 4wd. Otherwise i think i'd have maybe made it to 250 maybe even 260 on a tank.
My tires at this point are on the verge of balding as well. I'll be picking up new tires shortly. Not sure what i'm going with. Maybe stick with Toyo's or take a plunge with TKO's...
Recommendations?
Old Mar 23, 2010 | 10:23 AM
  #675
My average speed on the interstate was 70 mph (thanks to cruise control), and that portion of the trip represents about 200 of the 359 total miles. The other 159 miles was in town, stop and go, up and down western NC hills on pavement.
My tires are Michelin LTX, about half used up. All set to 35 psi prior to the trip.
I still can't believe it, maybe I had a tailwind going uphill to Boone, and the return trip was mostly downhill. I doubt I will continue to see 22 mpg around town, but am hopeful I am realizing some improved economy in a 17 year old 3vze.
Old Mar 23, 2010 | 10:41 AM
  #676
prelude85's Avatar
my old rears were LTXs. I really don't recall the mileage. I had some random knobby front tires. I think it was at 15 mpg in town. I wonder if putting new grease the shafts and joints would help out. I'm interested in seeing improvements with new tires and yeah i'll be greasing up soon.
I'm jealous of my lady's 27mpg Honda here.
Old Mar 24, 2010 | 06:41 AM
  #677
rangerruck's Avatar
wrenching joe; if that is a 6cyl, and a 4x4, whether it is standard or auto, that is excellent I must say. Also what is your tire size, and are they radials, or a/t's? Because if they are a/t's, that is even more excellent...
Old Mar 24, 2010 | 08:11 AM
  #678
Rangerruck, it is indeed a 3.0 liter 6 cyl. 3vze, 4x4, with the 5 speed manual transmission. The Michelin LTX's are standard m/s rated radials (not all terrain) in the factory size 225/75/R15. Crazy huh.
Old Mar 24, 2010 | 04:18 PM
  #679
BackGateYota92's Avatar
my 1992 3vze 3.0 v6 with an auto tranny and 33x13.50 swampers on 15x10 steel rims gets 9-11mpg depending on how i drive. time for new gears. lol
Old Mar 25, 2010 | 08:26 PM
  #680
se7enine's Avatar
my 86 4runner 22re 5spd w/ 33's, 4.88, 3" body lift gets about 20 hwy/city commute, my new 93 4runner 22re 5spd w/ 31's stock height was getting about 15 but since I upgraded the plugs, wires, air filter it's climbing up to 18-20. Still working on getting it timed and dialed in. Oil change w/ some Lucas Stabilizer and fuel filter should be about all it gets for now. I guess if I spent the extra 25 cents more a gallon for premium gas I might be better off.
