Post your GAS MILEAGE!!
Old May 2, 2010 | 02:16 PM
  #701
pjb00stin's Avatar
get around 12mpg. v6
Old Jun 16, 2010 | 06:38 AM
  #702
rhinoliner4runner's Avatar
87 4Runner, 22re, Safari Snorkel, shot exhaust ( new one soon ) 32"BFG AT's, all aluminum radiator, fully 'rhino' lined, soft top and add a leafs with rancho 5000's and I average 18.8 city, and around 23 hwy
Old Jun 16, 2010 | 07:14 AM
  #703
xxxtreme22r's Avatar
87 pickup, 22r, weber 32/36, EB 268 cam, fresh 30 over rebuild, block milled 20 thous, cam has not ben corrected for change in cam timing due to milling, brand new EB stock complete head, factory fuel pump regulated to 3 1/2 psi, 31" tires with factory 4:10's wooden flatbed with about 100lb (guessing here) of tools in tool box and a 31" spare.
13-15 MPG up a mountain to work every day
23+ highway.
Old Jun 16, 2010 | 07:24 AM
  #704
diablo's Avatar
22re w/ header, 4.88 gears runnin 32/11.50/15 and 2.5 in. exhaust 5 speed I can not get better than 23 mph no matter what, thats highway, around town and the farm looking @ 18-20 mph 217,xxx total and 32,xxx on rebuild with a little hotter cam
Old Jun 16, 2010 | 08:03 AM
  #705
Tofer's Avatar
Sponsor
89 3.0 auto 4.56 gears and 265/75R16s i got 19.88 mpg average of 6 fill ups on my last road trip. my best was 21.1mpg.
Old Jun 16, 2010 | 08:07 AM
  #706
az4x4runner's Avatar
Originally Posted by diablo
I can not get better than 23 miles per hour no matter what, thats highway, around town and the farm looking @ 18-20 miles per hour
That sounds about right.. but what about your gas mileage?
Old Jun 16, 2010 | 11:45 AM
  #707
rangerruck's Avatar
Rhinoliner; my 88' 5 speed 4 runner setup sounds a lot like yours, 'cept the 32's. I've got the tweaked heavier torsion bars( I think Rough Country's), addaleafs, and ranchos. Plus I added 2 , 12 x2.5 inch springs under the back bumps, to raise up the asssag. for the 32's did you get any rubbing, did you do any cutting?
By the by, my last mileage check, with that setup, plus stock size all terrains, was 15.2 gallons, and went 312 miles. That is about exactly 20mpg, on mixed driving. However, I keep my 4 runner loaded down with 3-38 gallon igloos, filled with tools, liquids, wiring, more tools, gas, straps, etc. I'd say an extra 200lbs, maximum, at all times.
I expect even more though, I am riding on tires that are at least 10 years old, from the origional owner, and am about to get a new set. Hopefully an extra 2 mpgs, on a new set of boots.
Old Jun 16, 2010 | 12:20 PM
  #708
coops2k's Avatar
I have had my truck about 4 months now about 3000 miles
87 Sr5 4x4 xtra cab, 22re with a 5 speed and a shell, stock, except for 31x10.5/15 on stock rims.
uncorrected MPG has avg 22.5 60% highway/40% city, all around the Houston area
best was 23.5 worst 19 (wife with her lead foot)
wife's 02 Double Cab 4x4 3.4L supercharged 265/70/16
wife driving 16 city / 19 highway
me 19 city /20-21 highway
unless going through west Texas, then around 16 mpg - 80MPH speed limit doen't help gas mileage when the supercharger was to be boosting all the time.
Old Jun 16, 2010 | 01:07 PM
  #709
rangerruck; The only thing I had to cut when I put them on was a little bit of the plastic inner fender near the doors. Now that I lifted the rear up to get rid of the sag, I didn't have to grrr. I am going to be tweaking my torsion bars here shortly, to try and get some more clearance out of the IFS. The only other rubbing I get is if the front is flexed and I have to cut the wheel hard, it just barely rubs the sway bar. Other than those couple of things its good. I used newer Taco rims. The tires are also 32x11.5xr15 too.
Old Jun 16, 2010 | 01:58 PM
  #710
rustyboltz's Avatar
I have an 88 base model pu, 22R, 4 speed, everything stock, daily driver with 14" tires, I get 26 mpg.
Old Jun 16, 2010 | 02:55 PM
  #711
ohgood's Avatar
89 22r 4x2 extra cab 5sp, 220 70 16 tars, and 19-26MPG
stock, stock and stock
Old Jun 17, 2010 | 08:42 AM
  #712
rangerruck's Avatar
Coops2k; Hello to another Houston arear homie. If you see this heap, it is
mine. Look about just shy of halfway down this page/
https://www.yotatech.com/forums/f116...l#post51340582
You know, it is amazing just how much better gas mileage the 4x2's, whether standard or auto tranny, gets. As opposed to the 4x4's, even though they are driven primarily in 4x2 mode.
Old Jun 17, 2010 | 11:14 AM
  #713
Duckie's Avatar
I posted back when I first got my truck, but for some reason my MPG went up.
I used to get 300km/tank, now I get over 400km/tank lol. Only mod I have done if the Zuk Coil mod, don't think thats what did it, but it did lol.
Old Jun 18, 2010 | 07:42 AM
  #714
se7enine's Avatar
My gas milage got a little better when I took off the Magnaflow straight-through muffler and put a stock setup back on minus the header. Solid 18-19 mpg city, up from 15-17 mpg.
Old Jun 18, 2010 | 02:58 PM
  #715
rangerruck's Avatar
makes sense se7; the straight through was causing your computer to up the richness proly. and for other dude; maybe when you did the Zuk mod,
your aerodynamics improved, and that lets you get bett mpgs? whadya think?
Old Jun 20, 2010 | 07:04 AM
  #716
waynesworld's Avatar
last time i checked it 18.39 all highway drivn
Old Jun 20, 2010 | 07:58 PM
  #717
Brad.'s Avatar
23-24MPG highway/wheeling. Bald 265/70's
Old Jun 21, 2010 | 05:51 AM
  #718
T_F_E's Avatar
88 pickup, 22re, rebuild 50k ago, 235/75/r15 aluminum wheels, 5 speed, locking hubs... best mpg 27.32 with a canopy about 22 average without.
Old Jun 21, 2010 | 07:17 AM
  #719
Blurr's Avatar
just drove 225 miles on a full tank before the gas light went on, definitely a record for my 4runner. 16mpg
Old Jun 21, 2010 | 07:49 AM
  #720
wsntme's Avatar
Best Of 15.2 MPG
Typically 13-14
Terrible
Stock '92 4Runner 3.0 A/T 4x4 240K Mi
