Post your GAS MILEAGE!!
Old Mar 21, 2011 | 07:43 AM
  #861
Swimmerboy2112's Avatar
19.6 today with my 22re lifted 2" with 4 roof lights a basket and 28's
Old Mar 21, 2011 | 10:40 AM
  #862
Redneck92's Avatar
17.6 on my last half tank, not to bad considering how I drove it. I'm kinda scared of what'll be when I get new 35s.
Old Mar 21, 2011 | 10:45 AM
  #863
edeslaur's Avatar
87 4Runner
AT (no, really), TEC turbo at 7psi (so can run 87 octane), 2.5" exhaust, factory 4.10s, 245/75R16s, DOA turbo cam, recently rebuilt engine with 1mm larger valves.
15-17mpg around town, odo reading adjusted for tire size. No recent road trips.
On crap CA gas with the hills around here, I'm not unhappy. The R151 is in the garage tho...
With a Stage II Crane Cam (so they said) MPG and power was down a lot. 10 mixed, 13mpg highway (10 over limits).
Old Mar 22, 2011 | 06:38 AM
  #864
'86Owner's Avatar
Originally Posted by 87Roxanne
Hey 86owner, do yourself the favor and don't drive with the tailgate down, it actually creates more wind drag(in a down force on the back of the truck) making your 22re work harder.... have u ever had a trash bag in your bed? notice when u drive at higher speeds, the bag float arround and not fly away? well that vortex of wind gets created in your bed, and makes wind flow over it..
anyways etc... you get better millage with tail up. just a thought.
Hmmmmm..... never thought of that... you might be right.
Old Mar 30, 2011 | 05:11 PM
  #865
mick cassidy's Avatar
17.5 MPG freeway @60 mph
14/15 city
31" tires manual trans
3vze stock gears
Old Mar 30, 2011 | 07:14 PM
  #866
Diablo22RE's Avatar
Full stock 1991 Toyota Pickup 22RE regular cab 4x4 5-Speed.
I get about 16MPG, and that was with a dirty air filter.
Old Mar 30, 2011 | 08:07 PM
  #867
man theres got to be something wrong with ur motor i got a v6 getting better mileage than a 4 cyl??? i keep my tires at 45 psi now windows up on the fwy.
no more than 60 mph take off easy at the light , gas here in LA is now $4.10 gal for reg. in Saudi Arabia its a $1.73 a gal damm
Old Apr 1, 2011 | 07:45 AM
  #868
'86Owner's Avatar
Ya know 87Roxanne, I think your right, I haven't done a test but I googled it and found an article by Truck Test Digest on whether or not to leave your tailgate up. Most engineers agree that it is less drag to leave the tailgate up. With it down it actually pulls air backwards into the bed and acts like a brake. So thanks for the suggestion.
Old Apr 1, 2011 | 09:06 AM
  #869
andrewflores17's Avatar
22 MPG
4 inch lift 33s tires and 22re manual
with my new 4.88s and crusieing along at about 70mph agh feels good lol
Old Apr 1, 2011 | 09:58 AM
  #870
tlrskunk's Avatar
Mythbusters proved the Tailgate down thing was a Myth. Then they showed why on a scaled down model in a water tank. it was actually a really cool episode.
Old Apr 3, 2011 | 03:30 PM
  #871
'86Owner's Avatar
Ya the article I read mentioned Mythbusters' test on that.
I recently just jetted my carb smaller, and I am waiting for the results, though I can tell I am getting better. And I got the tailgate up lol.
Old Apr 3, 2011 | 05:11 PM
  #872
huntersk2k5's Avatar
88 Std cab 4x4 22re 5 speed stock suspension stock tires i was averaging 19-20. Now with 33x10.5 im averaging around 16-17 without corrected speedo.
Old Apr 3, 2011 | 06:26 PM
  #873
85gijunk4x4's Avatar
for my 1988 p/u....about 14-16mpg....calculated it tonight...
3vz 35x12.50's, no lift (the t-bars are cranked up i think, but im not 100% sure) 5spd. re-geared (to idk what, bought it like that and the previous owner had no idea because he bought it like that too)
...and the 85 is still gettin about 6mpg
Old Apr 4, 2011 | 01:09 PM
  #874
Cmayer's Avatar
'89 22re, 5 speed, manual hubs, 245/75/16 tire. 15.6 mpg based solely on odometer readings and gallons at the pump.
Old Apr 4, 2011 | 02:04 PM
  #875
Inu's Avatar
Inu
95 Runner, Auto $x4, factory 4.88...., 31 10.5 with street meats up front and aggressive AT's in back. K&n drop in. 12-14 timing advance. Fresh engine and trans. E fan Under testing
100% short trips 10m or less 11.9 last night have to run ac on the way to work was getting 12.3
freeway...13 man i just love Cajon pass.. i need gears
Old Apr 5, 2011 | 06:33 PM
  #876
ryotto's Avatar
So I tried again today to see what the best gas mileage I can get out of my Pickup.
It's an 88 4WD Standard cab 22RE 5speed Toyota Pickup with over 200,000 miles on it. I've been getting 12-15mpg this winter with it in town in this harsh North Dakota weather. That includes screwing around in 4WD in the snow (that eats gas fast). The weather has been nicer and I've been driving it easier and got 19mpg in town this last tank.
Today the temp was 45-50 degrees with little wind and low humidity. I pump up my 235/75/15 Goodyear Duratracs to 50 PSI and literally topped off the gas tank. I then drove to a highway with little traffic and drove between 40-50mph though the hills (get up to 50mph at the bottom of a hill, slow down to 40mph at the top and everything in between). I did this both directions on the same road. I then found another highway that was more flat and was able to maintain 43-45mph in fifth with very little throttle. Again going both directions.
I drove 96 miles and the gas gauge was still above the full line (I thought the gauge was broke, but its not). I went to the same pump and topped it off again (filled till it about spilled). Used 3.1 gallons. So I got about 31MPG, which was the same as my previous best. I think I could have gained a few MPG if it wasn't for driving through town and going up those hills.
Believe it or not my 22RE 4WD Pickup got 31MPG over the course of about 100 miles going both directions. Try it yourself. Drive about 40-45mph in fifth (sometimes needing fourth up hills) without lugging the engine and be very careful with the gas pedal. This is a very slow way to get anywhere on the highway and I got a cramp in my right leg trying to maintain minimal throttle input. For me,if I want to get 31MPG, I'll just drive my Integra GS-R 75mph at 4,000rpm. My pickup can do it too, but it sucks trying.
Update. Today I tried to do better then 31 MPG. I Drove both ways on the second highway with very small hills and avoided in town driving. I still drove 43-45mph. Temp was around 50 degrees and the wind was calm. I drove a about 50 miles and got 33mpg. I think this is about as good as I'm going to get without descending in elevation, drafting, or having a tail wind. I wonder what a 2WD 22-RE could get in similar conditions with it's less weight, better aerodynamics and smaller tires. I can say my 22-RE is running great. It's been making great torque with very little throttle at 2,000rpm.
Old Apr 11, 2011 | 07:08 AM
  #877
coops2k's Avatar
That is great mileage, but I just can't drive between 45-50 every place. I am glad you did it, so the rest of us could see the results. My best with 31x10.5 at 45psi is 23.8mpg, staying under 60 most of the time.
Old Apr 11, 2011 | 07:23 AM
  #878
annamarie.johnson's Avatar
'92 PU, 5-sp, ex.cab, 22RE, 4x4, totally stock... about 22 city, 26 hwy.
not bad for 270xxx, I like to think.
Old Apr 11, 2011 | 08:27 AM
  #879
'86Owner's Avatar
^No kidding, thats really good!
Old Apr 11, 2011 | 08:44 AM
  #880
A.Paris's Avatar
88 pickup, 3VZE, 5sp, 31x10.5, stock 4:11's, 219,000 miles. 19mpg with a mix of daily driving and stomping around in the mud
