Post your GAS MILEAGE!!
Old Mar 10, 2011 | 02:58 PM
  #841
gamudslinger88's Avatar
Originally Posted by Magnusian
22R/RE? That seems a little low for a 2wd. I can't say what my mileage is like but my dad's '88 longbed with a 22R used to get over 30mpg.
Its a 22re. I just bought it 2 weeks ago and that was the first tank of gas I ran through it. I only drive it to work and home which is 30 miles on the nose so I used that to calc my milage. My speedo doesnt work (the gear on the output shaft is missing the clip or whatever holds it on there is missing) so I could have missed a day of travel when I figured it up. It was also running a little rough and I have since done a tune up and good ole seafoam treatment. Should be better next tank full. Now if I can figure out my speedo deal.
Old Mar 11, 2011 | 02:55 PM
  #842
boogieboarder's Avatar
10-11 mpg
Camry vafm swap, isr mod, manual hubs, moog rear coils
Not sure why my mileage is that bad, i would expect at least 12 or 13.
Seafoamed the intake and fuel a week or 2 ago.
Have been driving it slightly fast with the new intake though haha, i like the sound of it but even before the intake it was still that bad.
Old Mar 14, 2011 | 10:03 AM
  #843
'86Owner's Avatar
When I first got my truck about a year ago I got 25 on the highway, 20 on country roads(about 40 mph). But the carb was not adjusted right, and it had less power than a metro it seemed. Had to floor it in 4th at 55 just to get up a little hill. After adjusting the carb and doing other tune up stuff(normal stuff and then rejetting the carb), I got a lot more power but mileage gradually went down. Right now with 22re/weber intake, headers, 2.25 exhaust, 31" tires 32psi, stock gears, 5spd, removed vacuum hoses, off-road lights, tailgate open, driving really easy at about 40 mph(average), I got 17 on the last tank. Anybody have a similar set up with weber carb? I'd like to know your jet settings and compare with mine. I'm guessing I've got about 140-150 hp, which I'm happy with but would like some better mileage. Any suggestions?
Old Mar 14, 2011 | 02:17 PM
  #844
chris01081's Avatar
saving gas
any idea to get more mpg's i get 15 mpg 90 3.0 v6 stock 31's
Old Mar 14, 2011 | 04:58 PM
  #845
chad450r's Avatar
89' reg cab pickup 22re 4x4 235/75-15 tires 204,000 miles been fighting a code 25/26 getting 17-19.5
Old Mar 15, 2011 | 04:55 AM
  #846
blake.nemitz's Avatar
hey chris i have had luck with the afm mod and timing advanced to 15 degrees and egr blocked off. do at your own risk but im getting 20 mpg about 300 miles per tank
Old Mar 15, 2011 | 07:20 AM
  #847
'86Owner's Avatar
15 degrees? Wow, how does that affect your power? Stock is 5 right?
Old Mar 15, 2011 | 12:14 PM
  #848
more than it had before and sooner too and stock is 8-10 i believe
Old Mar 15, 2011 | 12:15 PM
  #849
BUT.... i live in colorado and have less effective compression here than someone at sea level and can get away with that much timing without a ping
Old Mar 15, 2011 | 08:55 PM
  #850
'86Owner's Avatar
Hmmm, and it helps your mileage too?
Old Mar 16, 2011 | 04:51 AM
  #851
maybe or im just lucky i guess it seems some of these turds get crappy milage no matter what, i also have a free flowing exhaust
Old Mar 16, 2011 | 07:35 PM
  #852
T.O'Brien's Avatar
Mileage??
3VZE | 5spd | K&N cai w/AEM dry filter | 2.5" Magnaflow catback | 31x10.5x15 ProComp X-Terrain's on KMC wheels | VMAF mod (3 clicks lean, might do more once I get a AF meter in her | timing usually around 12* BTDC.
Mileage (mpg) before VMAF mod:
14 City
16 Highway
After VMAF mod:
15 City
18 Highway
If I use Z-Max fuel treatment on the highway long distance trips then my mileage is: 21-22mpg
Old Mar 16, 2011 | 07:59 PM
  #853
DEATH RUNNER's Avatar
Hmm...seriously I get 5mpg, 3VZE 5 speed 33x12.50's. I have a bad knock sensor, TPS, hit or miss dizzy, maybe 110 miles to a full tank on a good day!
Old Mar 17, 2011 | 01:53 PM
  #854
zquinn85's Avatar
94 pickup 22re 31's and im getti like 10 mpg in town wtf is going on
Old Mar 20, 2011 | 05:50 PM
  #855
ZAP Toyota's Avatar
1994 Toyota 4runner sr5 3.0 v6 with 31x10.5 Baja Champion tires wrapped around 15 inch stock Toyota rims for now. It's about 20 miles to the gallon on the interstate but this new K&N air filter I just got, Got it to about 21 or 22 mpg. When I'm not driving like an idiot that is lol
Old Mar 20, 2011 | 05:56 PM
  #856
ZAP Toyota's Avatar
Originally Posted by HelliphinoN8
Come on!! Are 90% of you from Canada?? We a$$-hole americans haven't quite adopted the metric system yet. If you can't post your MPG!! don't post. We have no clue ''aboot'' these things you call killometers, or liters. We're not socialists yet!
I was seriously just thinking th same exact thing and doing the voice from South Park whilst reading about their kilometers and liters lmao. Only liters I care about are the 3 in my engine
Old Mar 20, 2011 | 06:08 PM
  #857
ZAP Toyota's Avatar
Might wanna check your overdrive and maybe change your transmission fluid. I don't get that bad when I'm flooring it at ever stop sign lol.
Old Mar 20, 2011 | 06:13 PM
  #858
sebastianholmes's Avatar
test your throttle position sensor. hows you cap, wires, rotar, plugs, Etc. Etc.?
  #859
BertMcGert's Avatar
95 4runner, 3.0, 5spd, 4.56 gears, 31x10.5s, i get about 18 with 50/50 city/freeway
Old Mar 21, 2011 | 07:29 AM
  #860
87Roxanne's Avatar
Hey 86owner, do yourself the favor and don't drive with the tailgate down, it actually creates more wind drag(in a down force on the back of the truck) making your 22re work harder.... have u ever had a trash bag in your bed? notice when u drive at higher speeds, the bag float arround and not fly away? well that vortex of wind gets created in your bed, and makes wind flow over it..
anyways etc... you get better millage with tail up. just a thought.
