Post your GAS MILEAGE!!
Old Jan 1, 2011 | 10:13 PM
  #801
BIGR79's Avatar
93 x-cab, 3.oL
33'' tires
dana 44 front end
no emissions at all
4-11 gears
7k on rebuilt motor
14 mpg city&highway
Old Jan 3, 2011 | 04:32 PM
  #802
erwatt's Avatar
1990 pickup, 2WD, 5 speed, standard tires, clogged EGR, over 330K miles, original clutch, original everything except starter, alternator, & fuel pump, 70 to 90 MPH on interstate, consistently 26.2 to 28.6 MPG.
Old Jan 3, 2011 | 05:31 PM
  #803
DRM's Avatar
DRM
When I used to daily drive my 87 4Runner, on 31" ProComp A/T's, bone stock 22re/5speed - I got a consistent 20 mpg.
I know this because my fuel gauge was broken, and I had to - without fail - always fill the tank up all the way, reset the trip meter, and keep mileage records... or I was screwed
Old Jan 13, 2011 | 09:36 AM
  #804
kooolr's Avatar
92 4rnr bored/rebuilt 3.0 auto 40-flowmaster ISR mod 265/75/16 4.56...
when it decides to run smooth- i average 18-21mpg. other times- about 14-16.
when her motor croaks, i plan on a V8 swap for even worse mpg. lol
Old Jan 14, 2011 | 06:34 PM
  #805
Sansocal's Avatar
this doesn't make sense, lots of people are saying 14-17 with a 3.0, 31" tires, ect.. my truck barely gets 15 on the highway and consistently gets 12 around town, but no codes are showing and ive almost gone through the whole truck.
Old Jan 14, 2011 | 10:59 PM
  #806
thurlo76's Avatar
87 4runner
33x12.5x15 a/t
4.56 gears
22re
19 in town and 23 on open free way
Old Jan 15, 2011 | 09:23 AM
  #807
Brazos's Avatar
I just bought a '93 4wd Ext. Cab pickup with the 22re, 5 speed manual, unsure as to what rear end gears I have. I put new 235/75R15 tires on it. Everything is stock and original w/ 186K miles. My first real test of milage yesterday when I filled up came to 21.4 mpg. I think that it pretty darn good for an old truck with that many miles.
Old Jan 18, 2011 | 12:22 PM
  #808
dave_n_ky's Avatar
gpm(gallon permile)
12highway ,9ish town, less off road. #6 cylinder roblem, valves last adjusted 220000 miles ago.
(Never)
Old Jan 18, 2011 | 02:26 PM
  #809
rainman88's Avatar
15.5 last i checked
Old Jan 18, 2011 | 03:24 PM
  #810
94toyota's Avatar
18 mpg city 25 highway (75 mph) 31's 3.o stick k &n drop in isr mod
Old Jan 18, 2011 | 11:26 PM
  #811
jeffe's Avatar
13 mpg city 19 mpg hwy 93 4runner 3.0 31's with a bad idler arm and tie rod
Old Jan 18, 2011 | 11:44 PM
  #812
LSD Rob's Avatar
In the summer I get about 20-22 mpg and winter holding a steady 15.5 mpg.
Old Jan 19, 2011 | 10:26 AM
  #813
mountaingoat's Avatar
20-22 around town in the winter, bit better in the summer. Just got back from a highway trip that returned 26.1, running 65-70MPH and including two snowy passes in 4-high. Quite pleased, this is the best highway mileage I've had on winter gas.
22R-E with 248k miles on original motor, 5-speed, Thorley header (best boost to mileage so far) Engnbldr 261 cam, 235/75/15 tires.
Old Jan 19, 2011 | 10:47 AM
  #814
Swimmerboy2112's Avatar
Last fill up - 20.4mpg 22re also that's with 4.10's and 30x9.5's
Old Jan 19, 2011 | 10:49 AM
  #815
Oops double post
Old Jan 19, 2011 | 10:50 AM
  #816
blake.nemitz's Avatar
ok guys here is one for ya, i used to get 300 miles per tank around 20 constantly and now im down to 220 miles per tank if im lucky but the truck has more life than it ever has as soon as the milage went down the power went up, any ideas?
Old Jan 19, 2011 | 11:25 AM
  #817
You're clearly running a lot richer than you were, that's why you have more power and worse mileage. Why are you running richer? Who knows?
Old Jan 19, 2011 | 11:41 AM
  #818
Junkers88's Avatar
Although I'm unsure about the power increase I know that fuel millage goes down with the introduction of the "winter" fuel that some states use. Crap my millage drops every winter here.
Old Jan 19, 2011 | 11:59 AM
  #819
Redneck92's Avatar
I get about 20ish with mine. 6" of lift, 35's and 4.30 gears, 5spd and 22RE.
Old Jan 21, 2011 | 11:19 AM
  #820
GreenYot's Avatar
Best i ever got was 25 mpg all highway with old oil, intake/battery swap, shorty header and flowmaster 40 at 60mph. usually around 22 mpg on highway though.
BUT, just put in new motor with engnbldr's 268 and OS valves. Excited to see what the change will be.
