Post your GAS MILEAGE!!
Old Oct 12, 2012 | 06:30 AM
  #1481
BanzaiTacoma's Avatar
2006 Tacoma
2006 Tacoma SR5 4x4 access cab 2.7 litre 2TR-FE with 5 speed gearbox General AT2 LT245-75R16 120/116S M+S tires (studs in winter) not alot of "stuff " just a jack with handle, basic tool roll,spare belt , fire ext, spare upper & lower radiator hose, 2 gals of spare coolant in cab. bed is Empty with cover spare tire under bed. 12 mile NYC highway commute at 55mph with cruise ctrl and 3 city blocks from Highway to driveway, doing about 20 21 MPG using 2 to 3 gals of High test a week give or take
Old Oct 12, 2012 | 09:46 AM
  #1482
Dirt Driver's Avatar
This is the '86-95 forum...
Old Oct 15, 2012 | 06:48 AM
  #1483
coops2k's Avatar
Was getting ready for a trip and found out my brakes where hanging up a bit, Changed out the front calipers and then had to replace the master cylinder. The master cylinder was not releasing all the way. Also found the right rear axle seal was leaking. after all of this was fix, my MPG went up by 1.5 mpg. Now around town it is about 19.5 mpg for 1987 extra-cab 4x4 on 31x10.5 with a 22re 5speed.
Old Oct 15, 2012 | 03:40 PM
  #1484
blueknob's Avatar
94 4runner, 3.0l, 5 speed manual, 4.56 gears, p235/75r15 tires, 18mpg around town
Old Oct 16, 2012 | 08:41 AM
  #1485
runs-on-4's Avatar
okay so i just got back from naches for hunting, from my house to whistle and jacks lodge is exactly 100 miles. i left my house with a full tank. when i got to whistle and jacks i filled back up it only let me put it 5.5 gallons... thats 18.1 mpg in my 3.0 5sp with 35's on stock gears... last time i did this i was on 33's stock gears and i could only fit 5 gallons more in the tank. and thats 20mpg....
my motor has rebuilt heads, no cat and a flowmaster with 3 inch pipe. ive messed with afm a bit, is there anything im over looking to why i can only fit 5.5 gallons in my tank. because i feel i should be getting like 14 or 15 mpg
Old Oct 16, 2012 | 08:46 AM
  #1486
aa1911's Avatar
I hit 17mpg's with the 4Runner last week, and that's without any alky injection!
pretty happy with that number after throwing some 14 mpg's.
gas is so inconsistent lately, sucks
Old Oct 16, 2012 | 10:08 AM
  #1487
atownturbo's Avatar
95 4RUNNER 3.0 5 speed, I drove 260 on a full tank, so about 14mpg. When I changed the oil and spark plugs one of the plugs was not even the right one.
Old Oct 16, 2012 | 10:13 PM
  #1488
dodge106's Avatar
i found that i had a bad bearing in my front third member probably causing some drag along with the warped rotors on the front. fixed bearing and put manual hubs on when i did the brakes so hopefully some added mileage now.
Old Oct 20, 2012 | 01:48 PM
  #1489
85celicagthatchback's Avatar
29 mpg going from nor cal going to reno. hill climing. city 20mpg highway 39mpg if i drive for more then 30 mile highway idk y that is.if not only about 26mpg
Old Oct 20, 2012 | 01:49 PM
  #1490
if u have a 22re make sure if u get ur plugs from autozone to get the right ones my local autozone had ngks that where way to cold and i fuel fouled them idleing for 5 mins so if ur getting poor mileage check that
Old Oct 20, 2012 | 01:53 PM
  #1491
could find the plug i had that where to cold but i remeber they have blue writting on them instead of green writting for the part #
Old Oct 21, 2012 | 04:24 PM
  #1492
ThatGuy1295's Avatar
is there a point to any of those 3 posts above? Or were you trying to be confusing?
Old Oct 21, 2012 | 06:25 PM
  #1493
Badger62811's Avatar
Uh... moving along....
Only got 315 miles outta this tank. Course I haven't fueled up in nearly 2 months Comes out to just over 19.6 mpg....
Old Oct 21, 2012 | 08:10 PM
  #1494
NickB47's Avatar
JUST picked up this '93 yota w/ 4" lift, 33" x 12.50 mud tires, 3vze. PO got ~16 mpg, I'll update when I get through the first tank.
Old Oct 21, 2012 | 08:43 PM
  #1495
ford97's Avatar
getting 27-29 out of my 94 2wd 22re
Old Oct 31, 2012 | 12:51 PM
  #1496
zspeed130's Avatar
I drive like grandma with the trailer attached. Even with 3000lbs being pulled I can snake out about 16MPG. Pure highway I run about 24MPG. This is an awesome improvement over my 89 F250 which averages 8-9MPG and is a PITA to park and drive! I really enjoy driving this truck and am getting ready to sink some money into it to keep it a daily driver instead of spending a few thousand on a car or S10 type truck to be a grocery getter. I love my 87 22r 4x4!!! I once left the stone supplier pulling/carrying nearly 6000lbs!!!!!!!!!
Z
Z
Old Nov 1, 2012 | 08:21 AM
  #1497
BuzzardsGottaEat's Avatar
1993, 22R-E, 4x4, 4.10s, 265/75r16s, averaging 21.6
It will come up, I ordered new exhaust from the headers back and intake and spark plugs etc from LCE a couple days ago and plan on boring out the Throttle Body and Intake Manifold and replacing the fuel injectors.
IF at that point I'm not happy with my gas mileage/power I will call up ECGS for some 4.56s, but I may keep it 4.10 for a few tanks to see if the lower rpms are suitable for my long highway trips
Old Nov 1, 2012 | 02:54 PM
  #1498
93Xtra-Cab's Avatar
Just filled up again today.
Drove 279.2 miles, 297.81 corrected due to tire size
Filled up with 16.075 gallons for a average fuel economy of 18.52 MPG.
85% highway driving, 15% country roads.
3VZE and a 5 speed.
I like to keep everyone updated since I get some of the best fuel economy on here among those with the 3.0L V6.
Old Nov 2, 2012 | 05:34 AM
  #1499
Filled my Durango last night and got 13.6... I'll post mine when I fill her up today. Definitely gonna be better than 13 :-|
Old Nov 6, 2012 | 01:17 PM
  #1500
OK finally filled my truck.
The first half goes forever..
Ignore the fuel cost. It's always wrong. Took 14.41 gallons, $48.00. Comes out to 21.6 mpg per GPS mileage. Odometer w/ incorrect mileage comes out to 19.9 mpg. So far I've gone 60 something miles and it's still on F. Our Durango has gone 80 miles and is under 3/4. And it takes $70.00 to fill. Can't wait to get our 2013 Volkswagen Passat TDI.
