Post your GAS MILEAGE!!
Old Mar 20, 2012 | 10:53 PM
  #1201
Blackulua's Avatar
old 22re 1988 4x4 straight front with r151f 5 speed turbo trans
Doug thorley header 2 1/4 pipe exhaust with super 44 flowmaster
4:88 front and back open diff with 33 x 12.5 BFG AT and 15x10 MT alcoas rims
tuned to stock specs and having 22 mpg city and highway driven.
Old Mar 20, 2012 | 10:58 PM
  #1202
zerokelvin's Avatar
nothing like renting a toyota and ringing it out. Reminds me of my last trip to vegas...and a brand spankin new toyota corola A few jumps and a bunch of vegas drifting left a huge smile on our faces as we flew out of town =]
Old Mar 21, 2012 | 07:50 PM
  #1203
_RaStA_RoCkEt_'s Avatar
Originally Posted by zerokelvin
I want to talk yota and drink some cold ones. Wonder how long it'd take to drive from California up to Oregon
We can have our own Yota talk here, with 70' weather!
Old Mar 21, 2012 | 09:06 PM
  #1204
runs-on-4's Avatar
i was getting around 13.5-14mpg with 33in swampers in my 91 ext cab. 3.0 with flowmaster and no cat in town
put on some 30s and i got 18 mostly hwy. to me thats pretty good.
cant wait to see what i can get with my 4:88S
Old Mar 21, 2012 | 11:31 PM
  #1205
zerokelvin's Avatar
sounds good rasta rocket =] The truck is down right now... 4:88's going in after a mess of misconception and bad information. I'll let you know when it's back up and we can hang out... I need to take a trip over 17 with her anyway... want to check the steering after some work
Old Mar 22, 2012 | 10:55 AM
  #1206
Redneck92's Avatar
17-18 everywhere no mater how I drive in my runner. 22re 4.10s and 35s
Old Mar 22, 2012 | 10:35 PM
  #1207
liveoffroad's Avatar
Ok, ........................now I REALLY have to figure this out! hahahaha. Actually, I can do 20mpg or so, HWY.... but still...
well i have a car engine....and i'm under-geared so my 5th gear is deep.
Old Mar 23, 2012 | 10:14 PM
  #1208
rykeebobee's Avatar
Gas Mileage Info.
88 Toyota Pickup, V6, 5Speed, 4WD, X cab, 31x10.50xr15, with 201K miles, I had about 80% highway miles and got 16.74mpg on the last tank with most of those miles on a stock(and dirty) air filter. Just installed a Cold Air Intake Kit within the last 50 miles of it( and caused a vacuum leak that was not fixed untill after the next fill up). I added some Lucas injector cleaner/lube to the next fillup and some Lucas Oil Stabilizer to the oil after that. I will report any change in mileage later. I do however need a new rear main seal and valve cover gaskets, fuel filter, starter, pcv valve, battery, brake pads and shoes and rotors and drums, and I'm also gonna replace the timing belt, tensioner, pulleys and water pump. And I may as well go for new wheel bearings all around being as old as it is. All things considered given the age of the truck it really isn't getting that bad of mileage. I have a 79 ford pickup with a V8 that doesn't get 10mpg on a good day.
Old Mar 24, 2012 | 06:27 AM
  #1209
Miyoda's Avatar
15 city/mixed, 18 on the highway at 65mph. I'm overgeared for the highway but it is great everywhere else.
Old Mar 24, 2012 | 05:30 PM
  #1210
04comaRider's Avatar
23 mpg highway 19-20 city 2004 tacoma 3.4 trd all stock.
Old Mar 26, 2012 | 08:40 AM
  #1211
Woody's Avatar
Lucky to get 10 in town and 15 on the highway. Running 305/70/16's.
Old Mar 26, 2012 | 12:48 PM
  #1212
zerokelvin's Avatar
I posted a little while back getting 10mpg. I realized because of the large tires that my speedo is reading slower than actual speeds and miles. Quick calculation (with help from some guys on here), turns out I was getting 11.9 mpg. I poured a bottle of carb cleaner stuff into gas tank.... now getting 16.69mpg after last fill up. Clearly the carb is nasty and gunked up so I'll put a couple more bottles through it and see if there's more improvement. The 4:88 gears going in right now should help a bit as well. \o/
Old Mar 26, 2012 | 01:10 PM
  #1213
BMcEL's Avatar
Seafoam it. About $10 per bottle but well worth it.
Old Mar 26, 2012 | 02:20 PM
  #1214
IluvwhatUdo4me's Avatar
I've got a '92 Pick-up with the 3.0 and a 5-speed 4x4. Tires are 31 10.50 Michelin LTXs. 106k on the clock...
I'm getting 15 to 18 city and up to 23 on the highway. I consistently get over 350 miles to the tank so I'm averaging around 20mpg.
Old Mar 27, 2012 | 05:30 AM
  #1215
oldmansimek's Avatar
21-24 depending on how much highway. 1988 reg cab shortbed 4x4 22re 5 speed all stock.
Old Mar 27, 2012 | 09:05 PM
  #1216
Grossboy88's Avatar
1994 4runner, 18-20 mpg. 31x10.50 15 BFG A/T V6.
Old Mar 27, 2012 | 10:35 PM
  #1217
YotaBoy83's Avatar
1983 long bed 4.10's fresh 22r weber3236, tri-y header, 2 1/4 exhaust, msd coil, 8mm wires, 31x10.5x15. 10-12 mpg!! Any help?!
Old Mar 28, 2012 | 03:30 PM
  #1218
zerokelvin's Avatar
Yota, you can try what I've been doing. Putting in fuel/carb/injector cleaners through the fuel lines and carb to clean stuff out. I've also pulled off a bunch of stuff since my last post and am cleaning everything. You've got an old one like mine (85) so chances are there are lots of nasty parts. Hope it helps
Old Mar 28, 2012 | 03:35 PM
  #1219
toyospearo's Avatar
Fuel pressure regulator, tune that Weber. You should be getting way better than 10 to 12!
Check for leaks.
Old Mar 28, 2012 | 03:47 PM
  #1220
YotaBoy83's Avatar
Yep I'm running a regulator the motor is brand new and the carb is tuned pretty well air fuel is 1 1/2 turns out and idle is a few turns in. I plan on putting in some fuel system cleaner today or tomorrow. I try not to hot rod it but every now and then I do for a few seconds. Any other ideas?
