Post your GAS MILEAGE!!
Old Feb 13, 2012 | 04:12 PM
  #1161
TinMan's Avatar
Getting 17-18 mpg, no matter local and hwy. not to bad for the way my runner is built.
Old Feb 26, 2012 | 09:42 AM
  #1162
Hellvision251's Avatar
92 pickup ext cab. 4x4 3.0. The only real test I've given it is with 2 dirtbikes and two sets of gear, tool boxes etc. and I got about 14mpg. I'd like to get a wee bit better any opinions?oh it has 31x10.5 tires.with exhaust
Old Feb 26, 2012 | 09:57 AM
  #1163
bobby_duce's Avatar
^^ id say thats pretty good with a full load! some people get 14 mpg with with no load! what gears you have?
Old Feb 26, 2012 | 04:01 PM
  #1164
bwill808's Avatar
thats impressive for a 3.0. my old 3.0 got 16mph with a feather foot on the freeway and it had stock tires, your probably getting worse gas mileage than registering because bigger tires means more ground covered per spin and the ecm speed o it's calibrated for it
Old Mar 6, 2012 | 05:30 PM
  #1165
zerokelvin's Avatar
gas milage
Hi, just signed up on yotatech 3/6/2012
recently bought a 85 from original owner and put in a new long block. Perhaps it still needs some proper breaking in, however it's getting terrible gas milage. About 10-15mpg running premium unleaded. This truck needs alot of work and the float is busted so my gauge is all over the place.
22r new long block (900 miles)
33's
6'' lift
stock gears (4.10) gonna switch those this weekend to 4.88 among tons of other things..... bought them from trail-gear for a decent price
Old Mar 6, 2012 | 09:19 PM
  #1166
JohnVH's Avatar
been getting killer mileage in mine lately, 19.6mpg is my best so far, just under 16 is my worst.
http://www.fuelly.com/driver/fr0gstrangler/4runner
Old Mar 7, 2012 | 01:01 AM
  #1167
4x4climber's Avatar
33's
6'' lift
I would just throw it out there... but you will save money and get better gas mileage running 87 instead of 91. Even give you a little more ponies.
Running high octane gas in low performance motors only waste money and gas and being your motor can't even burn that fuel right
... less power....
Switch octanes... run your mileage test... remember run a better brand
.. not a higher octane... I know from more then just a hunch. Proven facts.
Old Mar 7, 2012 | 03:25 AM
  #1168
zerokelvin's Avatar
Thanks for the info, I will switch. I would have normally run 87 but my uncle was telling me to run 91 as the engine is a brand new long block and something about the heat transfer in 91 is better and would break in the engine better. Although.. I have read a BUNCH of different approaches to breaking in a 22r...seems like a lot of opinions and not much fact. The only consistent information I got was to start off with like 15 miles, then 20, 25, etc... stepping it up little by little and letting the engine COOL all the way down in between runs...AND cycling the gears (reeving from low to high rpm's through different gears) during these short trips. Anyhow, got about 900 miles on the new block and it's getting horrible gas mileage. I've been going through the service manual all night making a plan to attack the fuel delivery system and carb in attempt to adjust these issues. All advice welcome , I actually haven't messed with this system ever, so it's probably my weakest area on my 85'. Thanks again
Old Mar 7, 2012 | 09:37 AM
  #1169
chuntr's Avatar
33's
6'' lift
running 33s with 4.10 gears on a 22r is going to mess with your gas mileage no matter what the engine is like. the 6" lift will knock it down too cause of aerodynamics.
and second on ditching the premium. you only ever need high octane gas if you have a high compression engine like some sports cars and motorcycles have, and even then its just to prevent pre-ignition (knocking) which happens cause of the high compression. it doesn't offer a performance increase, just keeps those motors from running like crap.
Old Mar 7, 2012 | 10:10 AM
  #1170
Black_1985_SR5's Avatar
1985 auto 4runner efi 22re 32in tires 248k on the clock unknown miles on rebuild? getting just a hair over 16 mpg driving like a mad man going 70-80 on the freeway and i think this thing scoots for an auto
Old Mar 7, 2012 | 02:50 PM
  #1171
zerokelvin's Avatar
CHUNTR- Yep, the 33's on 4.10 just bleed all the power and torque out of it, gonna get rid of the bogging down effect. I already bought the kit and the ring and pinions, they are planned to go in this weekend. I will post and update next week sometime after I put a couple tanks through it. I've switched to 87 and the gas mileage actually shows some improvement (over 200 miles) but not a significant amount. I was contemplating switching over the intake manifold, etc and converting to a 22re. Do you know or anyone for that matter... know if this will improve the gas mileage and performance any? I'm not really concerned what my gas mileage is, but if it can be significantly improved by making a easy swap or tweaks... why not? Thanks for the info guys
Old Mar 7, 2012 | 03:00 PM
  #1172
brino1's Avatar
13.5 on a 90 22re with 31x10.5s on steel wheels.4.56s with auto trans.i bought this thing thinkin id save a little gas.not the case at all.i get 22 out of my 02 3/4 ton duramax.its got no tail gate(hunting for one) and no cat.not sure if thats good or bad.needs a fan clutch too.any ideas on what could be causing such bad mileage?
Old Mar 8, 2012 | 09:32 PM
  #1173
90_4x4's Avatar
14mpg city.. Don't drive enough on the highway for mpg but that's with 4.56 gears and 32" tires.
Old Mar 8, 2012 | 10:56 PM
  #1174
ChefYota4x4's Avatar
Okayyyyy, now we're talking. I've been REALLY scratching my head about my mileage after my fully/solidly rebuilt 22RE continued to get me 180-240miles on an average 14Gal. fill up.
1. MANY Sensors are new and MOSTLY OEM(CTS is Napa)
2. 22RE/20over/261 CAM and all new Guides, ESki Dual Springs, Viton Seals, New Valves/10-10 Crank/OEM Bearings/LCE Header w/2.25" to the CAT/Borla and out/New OEM Fuel Pump/Fuel Filter/RC Injectors Service
3. 31x10.50x15's on 4.30 Gears/Locked Rear
4. 2" Lift
5. All new and properly working brake system(Nothing hung up)/Suspension/Koyo Wheel Bearings
6. Mostly City Driving/UP a 2K FT Hill every day, 2x a day, fairly steep grade
7. When HWY driving, seem to do more around 19-20....
8. I have tried to stay out of the skinny pedal this tank, most of the way through... And I'm most likely at around 14.5 gallons down from the last fill up and at 190Miles on the ODOMETER.
13.103448 mpg -20 mpg ??????? WTH? That CAN NOT be right..... Something in 'around town' driving(aside from the obvious, LIVING IN LOS ANGELES! lol) is KILLING my mileage! At 4.40$ a Gallon.... I NEED to figure this out or just go for a 24-30MPG SWAP! lol.
Things I'm going to look into;
1.Check the AFM, thoroughly(it's a donor from JBM715), for optimal performance/efficiency(I'll have to study a bit, see if I want to tweak it/if it's needed)
2. Check TPS readings again(New/OEM)
3. Investigate my Charcoal Canister Mystery-Hiss(it makes a sound almost like electrical current buzzing away/Like a Soda Bottle barely cracked)
4. Check into the DAMPER(Had a buddy with a poorly performing one and he replaced it and solved some mileage issues/rich issues)??? lol.
5. See if I can't weld the LCE 02 Bung closer to the Collector or on the 4-Pipe Joining
6. Then, probably scratch my head some more
PS> I REALLY doubt it's anything to do with the internal/mechanical end..... As I got around 20mpg/HWY all the way to Havasu, including the CAHON PASS during the time I was running that TOTALLY SUBAR'd first rebuild I had from that builder/machinist from hell!(at that time, I was getting bad city mileage as well)
Old Mar 19, 2012 | 11:27 AM
  #1175
liveoffroad's Avatar
just clocked 24mpg highway!
Old Mar 19, 2012 | 11:46 AM
  #1176
EFI85's Avatar
15-18 with new motor and stock 4:10gears and 35's .
I just put in 5:29's and the mileage went to ˟˟˟˟ barely 15 mpg . give me one more tank to see if it gets better after I stop driving so fast lol. news gears n motor runs pretty darn good .lol.
Old Mar 19, 2012 | 01:43 PM
  #1177
Ok, ........................now I REALLY have to figure this out! hahahaha. Actually, I can do 20mpg or so, HWY.... but still...
Old Mar 19, 2012 | 02:01 PM
  #1178
93Xtra-Cab's Avatar
Filled up today and calculated 17.3 mpg. A heck of a lot better than the 16 in the dead of winter
Old Mar 19, 2012 | 03:12 PM
  #1179
_RaStA_RoCkEt_'s Avatar
I run 91 Octane from Shell or Conoco-Philips, and in SWB 94' 22RE 4x4, I get about 10mpg around town. I attribute this to 134K on stock injectors, a air intake line behind the Mass Airflow Sensor thats got 19 years of mess inside it, 31' MT's and a VERY Flat custom front bumper with No air holes or aerodynamic efficiency.
Old Mar 19, 2012 | 03:27 PM
  #1180
Teuf's Avatar
Save your money, 91 is a waist of good cash, run 87 oct.
