Post your GAS MILEAGE!!
Old Jun 23, 2011 | 01:03 PM
  #961
pfmedic's Avatar
12.8 city... Im working on correcting the problem.
Old Jun 23, 2011 | 04:21 PM
  #962
phildelfino's Avatar
Originally Posted by '86Owner
Well, I'll tell you how to figure actual mileage with oversized tires. You take the size in inches of the oversized tire and divide it by the size in inches of the stock tire and that will give you a number you multiply the mileage by. I think for your rig it should be 1.11 but with worn tires it could be as low as 1.07. So you could run the numbers and see.
Also, when you put bigger tires on it makes it harder for the engine to pull the rig, decreasing mileage. But, you aslo go further with each turn of the tire. Since mileage decreases with bigger tires exponentially and going further increases directly, you could increase mileage as you go bigger until the decrease is larger than the increase and off sets it. So as long as you don't go too big you get better mileage.
how do you account for gear changes. i went from 4.10 to 5.29. tires went from 28.28" to 35".
Old Jun 24, 2011 | 07:53 AM
  #963
'86Owner's Avatar
You would take 4.10 and divide by 5.29 (0.78) multiply that by your miles then multiply that answer by the number you got from your tires (1.24 in your case). Its a little off because of the exponential change off the radius, but I think its about as good as you'll get.
Old Jun 24, 2011 | 08:07 AM
  #964
'86Owner's Avatar
^ Wait, I take some of that back. It's not off, it's as accurate as you'll get.
  #965
'86Owner's Avatar
I think... Ya i'm sure.
Old Jun 24, 2011 | 08:49 PM
  #966
thanks.
Old Jun 28, 2011 | 06:32 PM
  #967
95blackToy's Avatar
95 3.0 truck with 33" tires, 1.5 lift. K&N, free flowing exhaust. Manual transmission. I get 10 city and 15 highway. Is this normal? I feel like i should be getting a little bit better than that. What do yall think? And my speedometer/odometer is dead on.
Old Jun 28, 2011 | 06:49 PM
  #968
chuntr's Avatar
on a high mileage motor with 33's that sounds about right. also, if you don't have gears done that will make a difference, but I don't see how your speedo would read right if you didn't.
Old Jun 28, 2011 | 07:09 PM
  #969
95blackToy's Avatar
well Im the third owner, got it from my grandma when it had 31s and she got it from someone who used it as a hunting truck and had 33s. Well i think the first owner either regeared it or changed the speedo gear, because 33s and it matches with 2 different gps'. So i figure its right on. Would you recommend lower gears?
Old Jun 29, 2011 | 12:18 AM
  #970
chuntr's Avatar
well I would figure out what you have now and go from there. you can find out what gears you have by marking the driveshaft, then jack up one tire and rotate it two complete turns in neutral and count how many revolutions the driveshaft makes. that number will be your gear ratio.
Old Jun 29, 2011 | 06:33 AM
  #971
'86Owner's Avatar
^ Or both tires and one turn if you have a locker.
Old Jul 4, 2011 | 03:13 PM
  #972
latrans's Avatar
85 toyota pickup...very stock. I can get about 21mpg on the highway with 235 7rR15 tires. I wonder what 30 inch tires would do????...
Old Jul 5, 2011 | 05:06 AM
  #973
Levinz11's Avatar
95 3.0 I got 17.5 mpg's on my first tank with this truck. Mix of highway and city. To be honest I was pleasantly surprised after reading through this thread and others.
31's, 165k 38 psi in the tires.
Old Jul 5, 2011 | 05:59 AM
  #974
Stuwy123's Avatar
93 Pickup xtra cab, 22re, 33x12.5 BFG's, 4.56's and most importantly a Check Engine Light.
13.5 MPG. Hahah
It's normally around 19 MPG.
I'll respond when I get it fixed and with 4.88's now.
Old Jul 5, 2011 | 03:39 PM
  #975
LilBlue88's Avatar
1988 4runner
NGK Plugs, new cap and wires
Cold Air Intake
2.25 exhaust with racing muffler
31x10.5's
No A/C, I live in Idaho
I get about 17 MPG. GO USA!
Old Jul 5, 2011 | 03:51 PM
  #976
pfmedic's Avatar
Best way to improve gas mileage, visually clear all intersections by slowly rolling through them. The further you slow down, the more fuel you have to use to get back up to speed. Be sure to explain your reasoning to the officer who pulls you over. The money you save at the pump outweighs the tickets and increased insurance premiums.
Old Jul 5, 2011 | 03:53 PM
  #977
'86Owner's Avatar
^Lol, well... I don't know about that. You would get better mileage though.
Old Jul 5, 2011 | 04:03 PM
  #978
pfmedic's Avatar
Well I suppose it all depends on where you live and how often you get caught. Financially, it would be worth it for me, but I would not do it at busy intersections or traffic lights.
Old Jul 5, 2011 | 04:30 PM
  #979
cjtexoma's Avatar
Stock 1998 extended cab taco, 4x4, 5 speed
Probably like 17mpg running 70 with air. Best, probably around 20 mpg doing 60-65 no air. In Texas, if you got the air, you run it, and mpg is not a factor!
Old Jul 5, 2011 | 05:44 PM
  #980
Supa's Avatar
Im finding it really hard top believe the posts claiming 19 mpg from a motor that makes 15 mpg from the factory new. Let alone with 200k miles and 33 inch tires.
I get 14 mpg on a motor with sub 100k miles and 31's. and thats mostly highway
