Post your GAS MILEAGE!!
Old Jul 22, 2008 | 01:30 PM
  #201
Jay351's Avatar
Filled up at 3/4 a tank. Got 18.5 mpg. Not bad
Old Jul 22, 2008 | 01:39 PM
  #202
Belize Off Road Team's Avatar
when i get my 3.4L installed i am aiming for 27+MPG highway, and why not when i get 25 with the 3.0 i should get around 30 with the 3.4L right? cause it is a newer motor???
Old Jul 22, 2008 | 01:41 PM
  #203
Spence1016's Avatar
i get 16.6 (mostly city with maybe 30% highway) with my 3.4 lol 2wd with 265/75/16 m/t's at 40psi but i just changed the spark plugs which were long overdue so ill post an update in a few days
Old Jul 22, 2008 | 08:54 PM
  #204
STEvil's Avatar
Originally Posted by Belize Off Road Team
Keep an eye open in the next 2 weeks, when i get my 3.4L installed i am aiming for 27+MPG highway, and why not when i get 25 with the 3.0 i should get around 30 with the 3.4L right? cause it is a newer motor???
If you have a better gear ratio yes... and a standard transmission to take advantage of that.
Otherwise not likely.
Old Jul 25, 2008 | 09:41 AM
  #205
Vanman's Avatar
I filled up this a.m. @ $3.69/gal. I averaged 18.2 mpg!!! WoW! Holy head gasket Batman!
Needless to say, I am happy with that. No mods for me. I do run the bigger of the two tires sizes recommended for the 4Runner. I'm thinking of taking the step board off, but my 6 y/o wants it left on
I need to get the butt lift as well....
Old Jul 28, 2008 | 06:12 AM
  #206
1987tanyota's Avatar
1987 22r PU stock. 22 city 26 high way. I drive at a dead set 65-69 mph the entire way on the interstate.
Old Jul 28, 2008 | 11:43 AM
  #207
Snotrocket's Avatar
My 22re with a fresh tuneup on 31's with 4:10's is getting 23-24 with a 50/50 mix of city highway driving.
Good enough for me
Old Jul 30, 2008 | 05:07 PM
  #208
Recoil's Avatar
just filled up, 16.2mpg pure city driving. best i've gotten recently is 21.3 coming back from tahoe (downhill helps, got 17 going up)
i'll be installing an mpguino in the pos soon so i can monitor it and see where the best shift points, cruising speed, and are. also disconnected the antenna so it stays down and threw 225s on it for city driving.
mpguino: http://ecomodder.com/forum/showthrea...pace-2115.html
'92 4runner, 3.0, 5spd, 1.5" bj spacer/springs lift
Old Jul 31, 2008 | 09:57 AM
  #209
jeremy93ls's Avatar
I've been getting 27mpg every time in my 95 2.4 liter manual tacoma. Of course, I drive like a little old man..
No mods, stock everything except camper top with Yakima racks/fairing.
I did get 28mpg once
Old Jul 31, 2008 | 10:27 AM
  #210
Evil.Dingo's Avatar
After full tune up (valves, oil, filters, plugs, wires, OEM cap and rotor, OEM O2 sensor, brake job, fluids) Im getting 25 MPG mixed driving with 22re pushing 31's. It's up from 18-20 MPG before I installed the O2 sensor. I am very happy with the improvement.
Old Jul 31, 2008 | 01:03 PM
  #211
fishmonger's Avatar
just back from a 4850 mile trip WI-CA and back. Average 22.2 mpg, peak 24mpg, worst 19.5mpg.
'93 4Runner V6 3.0 5speed, 31" BFG tires at 45psi to save some gas. Other than that bone stock and just easy on the gas, I guess.
Old Aug 4, 2008 | 10:42 AM
  #212
Georgiadave's Avatar
1994 4X4 Regular cab, Standard 225 75 15 tires 22RE, Manual Transmission. 20.5 MPG in city driving. Jacobs Ignition and wires. Everything else stock.
Old Aug 5, 2008 | 05:54 PM
  #213
lphillippi's Avatar
1993 2WD extra cab
31" tires
4.10 gears
5 speed
K&N intake
big bore throttle body
Downey headers
2 1/4" exhaust
DOA cam
rebuilt 22RE
18 MPG
I've run a few different cams and they make the biggest difference in gas mileage. The engine builder cam with the same set up was getting about 20 MPG. I get 10-15% better mileage using Mexican gas that isn't watered down with ethanol.
Old Aug 6, 2008 | 09:41 AM
  #214
99BlackRunner's Avatar
99 4runner 4x4 V6 with stock 265/70r16s getting 20 on average
Old Aug 6, 2008 | 01:31 PM
  #215
yoder519's Avatar
i got a 95 p/u 31x10.50s stock suspension stock exhaust... well... everythings stock except the looks.. i checked 2 days ago and i get 20.6mpg mixed drivin so pretty much 21
Old Aug 9, 2008 | 07:44 AM
  #216
stumpjumper's Avatar
90 ,3 slow 4runner ,k&n cold air ,msd ignition ,2.25 flowmaster,elec fan,about 21mpg
Old Aug 9, 2008 | 08:25 AM
  #217
ToxicTurtle's Avatar
87 Runner, 340,000 miles
37" Swampers
4:10 gears, header, custom exhaust, K/N intake.
at 30psi will get 18 on the highway at about 65 miles per hour.
With wheeling and driving to the trail, about 14 mpg.
98 FJ80 Das Tank, 260,000
265/75/16 Green Diamond tires
Stock gears
30 psi, on highway or city, rumbles along at 1800 RPM and gets 18mpg.
Towing the Turtle behind it, pulls a steady 13.5 mpg.
05 Corolla XRS, 50,000
195/55/17 Dunlop sports
35 psi
30 city, 38 highway.
Yeah, thats the DD.
Talk soon,
Old Aug 9, 2008 | 12:27 PM
  #218
Jay351's Avatar
Last three fillups:
50/50 driving, not really caring for mpg's = 16.49mpg
90% wheeling = 9.06mpg
Mostly hwy, lots of higher rpm driving = 20.58mpg WOOO!! Broke the 20mpg mark
Old Aug 9, 2008 | 01:36 PM
  #219
GONWHLN's Avatar
07 FJ TRD SE Automatic
Stock as of now w/ 265/75/16 BFG AT's
60/40 highway/city
19mpg
Old Aug 9, 2008 | 03:12 PM
  #220
pdyebrasil's Avatar
'98 4Runner SR5 3.4 w/ 163,000 miles.
I get about 17 city and 21 highway runnin' a 3" lift and 33's.
