need to know if it will work
Old Jun 23, 2014 | 08:33 AM
dantheman120's Avatar
so i was figuring out what lift kit i want to put on my 4runner for 33x12.50x17
the thing is i have a 2WD 6V 3.0L 92 4runner ( Automatic tranny)
so out of these which will work
tuff country- http://www.suspensionconnection.com/548023.html
Performance accesories 3" BL- http://www.jcwhitney.com/perf-access...2166y1992g12j1
OME lift kit- http://toyteclifts.3dcartstores.com/...ner_p_224.html
which would be the best to get enough clearance for 33x12.5 BFGoodrich A/T
REMEMBER I HAVE A 2WD AUTOMATIC
Old Jun 23, 2014 | 08:38 AM
MaK92-4RnR's Avatar
http://www.4wheelparts.com/Lift-Kits...FURqfgodWqMAng
3" body lift is hideous
Old Jun 23, 2014 | 08:39 AM
Originally Posted by MaK92-4RnR
so between the tuff country and the OME...the tuff country says 4x4 so i dont know if it will work on my 2WD
Old Jun 23, 2014 | 08:41 AM
JasonYota's Avatar
Tried calling them? 2wd and 4wd 4runners have the same suspension but something may be different.
Old Jun 23, 2014 | 08:50 AM
okay i will try that... but both those lifts will give me enough room for 33x12.5 right?
Old Jun 23, 2014 | 08:58 AM
JasonYota's Avatar
I've got 285/75/R16's almost 33x12.5 on my 4runner with cranked torsion bars and aftermarket coils in the rear.
Old Jun 23, 2014 | 09:01 AM
ohh solid i will have to look into that....thank you!!
Old Jun 25, 2014 | 02:22 PM
SLAYfriknBODIES's Avatar
Www.4crawler.com
Ball joint spacers are $80 a pair and can set your front end high enough to accommodate 33s without maxing your torsion bars to the stops.
I don't know much about 4Runner rear suspension so you'll need another Runner guy to help you there.
Old Jun 25, 2014 | 04:30 PM
highonpottery's Avatar
if you already know you want BFG AT's in 33" size - do you already have 17" wheels? If not, my suggestion would be to skip buying 17" wheels and a lift kit, then simply buy some 33x10.5-15 BFG ATs on your stock wheels and then just get a sledge hammer to massage the pinch weld in the wheel well of your rig - done. spend the rest of the money on something else.
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
