Old Feb 9, 2016, 09:59 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Eliminating the metal windshield trim aka rust maker
Old Aug 2, 2023 | 07:11 AM
  #321
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
LOL.
See? THIS is what makes a fantastic thread. When folks update what they did way back before the BigOne WW2 and how that worked out!
Thanks for updating
Old Aug 2, 2023 | 12:54 PM
  #322
slacker's Avatar
Originally Posted by vulture86
Hey coopster, thanks for the reply. So that's one person who says yes, sealant should be used to hold the glass in the rubber gasket.
we do these still in my shop , and YES , I urethane them in .. even the 79-83's which are stock with the rubber gasket . heres why the 84 + dont use the gasket here in North America , Its "safty standards "
in a rollover , the gasketed glass can "pop" out very easily , and then the roof crushes , and you could be dead ! , with the glass urethaned in , it actually becomes a structural part of the truck , with almost
zero chance of it pipping out ... so If you do the gasket , my recomendation , is absolutly urethane it in .
Old Nov 24, 2023 | 12:04 PM
  #323
mckidyll's Avatar
Couldn't agree more about the useless stainless trim. I found a local independent glass guy, who took out the windshield and all old rubber, repaired ALL the rust (and there was plenty), primed and painted, and installed a new windshield with generic rubber material, well sealed in. Total was $600 and very well worth it. Looks terrific.
Old Dec 20, 2023 | 05:31 AM
  #324
dwsutton's Avatar
Windshiled Rubber Gasket - Same Result
I too found the windshield too large by 3/8 on the bottom and 3/16 on the sides. Following your instructions I sanded the windshield down and it fit well. Cant see how it would go in without the removal on a US windshield. It is a nasty job sanding the glass but easier than I thought and it looks great. Video soon on my Youtube channel on it.
Windshield rubber gasket
Originally Posted by depiante
I had two different glass installers come out and try to make an FW471 windshield work with the infamous rubber gasket. No, it doesn't work and it will never work. The windshield that works with the gasket is not available in the United States.
I took the truck to Safelight, and the installer (who is WONDERFUL) spent hours with me trying to make some king of universal trim work. He was not satisfied, and asked why not use the gasket. I explained it to him and he told me to just resize the window, so I could use the gasket. Then he told me how. So, here's what you want to do...
  1. You will want to remove a full 3/8 inch from the bottom, and 3/16 inch from each side.
  2. Super clean the glass.
  3. Lay it out using tape (see the picture).
  4. Put tape top and bottom because you will have to alternate sides often as you work.
  5. Make sure the tape is very well adhered. This helps prevent the inevitable chipping from running in too far.
  6. Put 80 grit paper on your belt sander.
  7. Keep the sander moving constantly, but not too fast.
  8. Start by breaking the sharp edge (called "seaming") of the glass on all three edges and rounding the top corners.
  9. Do this for top and bottom. This keeps the edges from chipping.
  10. You can use a random orbit sander to seam the edges also.
  11. Run your belt sander vertically (assuming the glass is horizontal), tipped forward a bit.
  12. Again, this is to keep from chipping the bottom edge.
  13. Turn the glass over and do the same from the other side.
  14. After about 5 million passses, you will end up with a slight point around the plastic layer in the glass.
  15. This point will probably be a bit chipped. Run the sander vertically to clean that up.
  16. You will now have new square edges top and bottom.
  17. Seam the edges, top and bottom, and repeat the entire process until you are at your tape line.
  18. Seam the edges one last time to clean up the chips.
  19. Install it using the old rope trick. Use heavier rope to avoid tearing the gasket.
Top picture is of seamed top edge. Bottom picture is shows the slight point around the plastic.
Taper your corners evenly. Lay it out with tape, top and bottom. Ensure the tape is very well adhered.
The end result. WAY better than a universal trim solution.
Old Jan 24, 2024 | 05:33 PM
  #325
Gome60's Avatar
Originally Posted by xX88yota4x4Xx
Ok everyone got it done and i can say i could not be happier!!!!!! i would say go for it but like mentioned in this post before dont let them do it unless they are confident they can do it. i talked to probably six different people before i found this guy.
before
Attachment 172740
Attachment 172741
and after!!!!!!
http://i297.photobucket.com/albums/m...7/DSC00816.jpg
Attachment 172742
Attachment 172743Attachment 172744
i know ur post was years ago. I wanna do same to my '87 xtra cab. Do you happen to know part# and where to get that rubber seal?
Old Jul 28, 2024 | 11:03 AM
  #326
vulture86's Avatar
I finally found a good shop that could fix the rusted spots on my 1986 Pickup windshield frame. Marx Hot Rods in Albany, OR. Here is a before and after photo. They applied white primer, still need to paint over it.
Old Jan 2, 2025 | 03:11 AM
  #327
3vz92's Avatar
Hellooo
I would like to change the chrome windshield trim on my 1992 truck. What i understood from the discussion on this thread is that I need to replace the windshield itself by a smaller one !!!!! or the Gasket Reference Number : 56121-89121 through the following link : https://www.ebay.com/itm/384944947740 can fit the windshield without replacing it by a smaller one. Please advise if this item is enough...
Old Jan 2, 2025 | 07:01 AM
  #328
coopster's Avatar
My neighbor was getting his windshield repaired from some local guy two years ago. (colorado) I asked the guy if he could mount a replacement I had. He had some sort of gasket with him on his truck.
Took him maybe 1/2 hour. I think I paid him 100 bux? Works great, looks good. A 95 body. Don't know what the source of the material was. No more chrome. I do miss the extra horsepower tho...
Old Jan 2, 2025 | 08:23 AM
  #329
davefarr's Avatar
My ad shoud still be up- I had to purchase a whole role (about 5 winshields worth) of the gasket, works nice and there is a groove with urethane that sticks to the edge of the winshield. For my 90- the windshield is oe piece.
https://www.yotatech.com/forums/f109...rim-fs-318786/
Old Apr 16, 2025 | 09:16 AM
  #330
ToyOverland1's Avatar
Did you have to remove the defroster plate to get the seal in?
Old Nov 3, 2025 | 10:21 PM
  #331
Kindovah's Avatar
88 4runner trim chrome to rubber
So im looking to replace my whole windshield and want the chrome gone and swap to rubber while keeping the glued in as i am from cali what are good rubber seals to swap in.
Old Nov 4, 2025 | 04:38 AM
  #332
davefarr's Avatar
I have one length of rubber seal left.
Old Nov 7, 2025 | 04:47 PM
  #333
notele's Avatar
Originally Posted by Chainlink
Im in the windshield buisness, the trim on your truck is merely cosmetic and serves only that purpose. I hate it and have often pondered a alternative. Biggest problem is that the windshield is alot smaller than the space it fits. So adding a flexable trim around it that would fill the space would look even worse( and would pull out quickly anyway). I haven’t tried but thought of maybe trying, grinding clips for moulding, then body filler in spots needed, then using a wide flex but in reverse. So in a way would act like an actual rain channel. There is a little more to my idea, but you get where I am going with this if I want to drive a Toyota in Oakville?
Yes, it’s possible to replace the metal trim with rubber, but you must ensure the rubber trim seals properly to prevent leaks and water damage. Improper installation could still allow water in, which might cause rust. Use high-quality weatherstripping and make sure the windshield is not compromised during the process.
Old Feb 17, 2026 | 12:37 PM
  #334
notele's Avatar
Hey Tulsa, can you post pics of what yours looks like? I have a Can Am Commander 1000 and have been on the phone all day calling people that said it cannot be done......right, to put the molding back...grrrrrr!!!! This pisses me off the worst. So they actually put the universal trim on the glass then glue it in, like glue the trim to the frame? If so, the only thing holding your windshield in is a glued piece of rubber??? I am asking cuz I want to explain to them how I want them to install it.
Yes, that’s basically how it works with the universal trim. They put the trim on the glass and glue it to the frame, so the windshield is held by both the glued trim and the frame. It sounds flimsy, but if installed correctly, it’s secure and sealed. If you want it done the way you prefer, make sure to tell them you want the windshield seated firmly in the frame first and then the trim glued on. This gives it proper support and keeps it from feeling loose.
jdfnnl
Jan 7, 2022 02:07 PM
letted
Aug 27, 2014 12:07 PM
4WDarren
Jun 21, 2012 09:18 PM
woodyth
Dec 6, 2011 09:52 PM
DanStew
Jan 27, 2008 12:13 PM
