Old Feb 9, 2016, 09:59 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Eliminating the metal windshield trim aka rust maker
Old Aug 26, 2020 | 10:36 AM
  #281
MaK92-4RnR's Avatar
So in the grand scheme of things, do we have a link to a seal that actually fits and works with the 84-88(89) windshields?
Old Aug 26, 2020 | 10:56 AM
  #282
5 Fists's Avatar
Excellent question. I'd like to replace my cracked windshield one of these days, and eliminate the chrome trim and replace with the rubber seal. A link to the proper seal would be great.
Old Aug 26, 2020 | 11:03 AM
  #283
FGZ's Avatar
FGZ
His link in the youtube vid did not work for me, but I think this is the seal he used: https://www.ebay.com/itm/Front-Winds...p/153609592203
Old Aug 26, 2020 | 11:37 AM
  #284
MaK92-4RnR's Avatar
Same here. my windshield is cracked to all hell... would be nice to just do it all at once.
Old Aug 26, 2020 | 12:36 PM
  #285
5 Fists's Avatar
Nice, I'll look into that one, thanks!
Exactly, get two birds stoned at once, as my buddy Ricky would say.
I'll re-read this thread from the beginning, as it's been a few months since I've researched this.
Old Aug 27, 2020 | 04:40 PM
  #286
Dr Phat's Avatar
http://toyheadauto.com/Toyota_Truck_...therstrip.html
I haven’t used this product yet but found this result when recently searching to do away with my chrome trim. They also sell a version that will allow the trim to clip into the rubber trim as well.
Old Aug 27, 2020 | 08:22 PM
  #287
SomedayJ's Avatar
The Toyota part number in the video is 56121-89117
This is other eBay provider, but in this case the item is located in Japan:
https://www.ebay.com/itm/TOYOTA-5612...F/164105425565
Old Aug 27, 2020 | 08:34 PM
  #288
SomedayJ's Avatar
You can't clip the OEM chrome trims in the "windshield weatherstrip" they sell. They offer an aftermarket "flexible chrome plastic trim" you have to glue on the ""windshield weatherstrip". The product is similar at the one you can see in this video at 2:50:
Old Aug 27, 2020 | 08:37 PM
  #289
Dr Phat's Avatar
https://www.youtube.com/watch?v=7D4LfZfzhLQ
Ah ok thanks for clarifying! I wonder how that worked, I was looking to ditch my chrome trim entirely when I got my truck painted anyway but still useful for others who might see this!
Old Aug 27, 2020 | 08:46 PM
  #290
SomedayJ's Avatar
I believe that "flexible chrome plastic trim" is a good idea in case you want to keep the chrome trim look without the rust risk around the windshield and wheel arches.
Old Sep 25, 2020 | 11:43 PM
  #291
RAD4Runner's Avatar
Windshield project 4 years in the making - lol!
MY PROCESS FOR TOTALLLY ELIMINATING RUST-PROMOTING WINDSHIELD TRIM - NO CHROME NOR RUBBER TRIM THAT TRAPS MOISTURE AND DIRT.
FALL OF 2016:
Adhesive of previous replacement was not sticking to the spray paint- repaired surfaces. This time I did a thorough prep.
As you can see, the rusted spots are were clips for the stupid chrome trim trapped dirt and moisture. That is why I detest the chrome trim with a passion!
This time I used POR-15 Starter Kit:
I removed all finish and most rust on the pinch weld and its sidewalls with a steel-brush.
Steel brush does not completely remove loose (brown) rust (merely glazes over it and makes it seems like you had hit bare metal) so I used tiny grinding wheels (part of Dremel-style kit) that I attached to my drill. This removed all the loose, brown rust, and I was left with tiny spots of grey metal where there was pitting. I think POR-15 would take care of sealing that.
A video of the pinch weld in process. I would further grind the brown, loose rust from pitted areas is HERE.
I used POR degreaser and then Metal Prep, then applied 3 coats of POR-15 (waited for each coat to get tacky before applying next coat). I was too busy to take picture of the POR'ed pinch weld and wall, but here's one already with bead of Sika brand windshield adhesive on it...
A picture of bead being applied to bottom pinch weld. Bead is pretty thick so I hope that helps with sealing.
Glass now installed:
Adhesive squeeze-out completely fills underneath edge of the glass.
NEXT STEPS:
Prime the POR-treated area inside the gap, feather the POR and paint on the lip, then repaint.
FALL of 2020:
Adventures got in the way, so ALMOST 4 YEARS LATER
(LOL!) I FINALLY HAD THE CHANCE TO FILL GAP AROUND THE WINDSHIELD WITH BLACK SILICONE.
Lessons Learned:
1) Paint the POR-15 as soon as cured to protect it from the elements, AND
2) When applying silicon sealant, squeegee it right away - before it forms a "skin"
See below.
POR-15 HAD DETERIORATED AND SOME EXPOSED METAL HAD RUSTED SO I HAD TO PREP AND PAINT THE METAL AGAIN. I MASKED THE GLASS AND THE URETHANE ADHESIVE SO SILICONE WOULD BOND DIRECTLY TO THEM.
POR-15 HAD DETERIORATED AND SOME EXPOSED METAL HAD RUSTED SO I HAD TO PREP AND PAINT THE METAL AGAIN. I MASKED THE GLASS AND THE URETHANE ADHESIVE SO SILICONE WOULD BOND DIRECTLY TO IT.
Since there is no longer a trim to hold down / finish the rear edge of cowl cover I did the following:
Old Oct 9, 2020 | 10:38 AM
  #292
dh12791's Avatar
Will the plastic a pillar trim fit back in after install or it needs to remain out?
Old Oct 9, 2020 | 11:31 AM
  #293
RAD4Runner's Avatar
What's that? You need to read the thread to see what people have already done
Old Jan 13, 2021 | 04:18 AM
  #294
depiante's Avatar
Originally Posted by magnet18
Sanding the windshield to fit
I like that solution
How many days of sanding did it take?
About 4 hours, over two days
Old Jan 14, 2021 | 08:46 AM
  #295
Dr Phat's Avatar
Just wanted to post a pic. I installed new glass and the rubber trim from ToyHead when I had my truck painted. Came out great, even has the correct gasket thickness and “relief” cut into it to support the front hood cowl. 100% recommend.
Old Jan 14, 2021 | 09:38 AM
  #296
depiante's Avatar
Some questions...
Did you do this yourself?
Did the gasket seat on the pinch weld on all four sides?
Did you trim the glass?
Old Jan 14, 2021 | 09:44 AM
  #297
Dr Phat's Avatar
Sorry I dont have any info on that unfortunately, I just dont have the patience for body work. But my guy at the shop said it went in fairly easy and without issues. The OEM glass broke taking it out, so had to replace the glass.
Old Jan 14, 2021 | 06:44 PM
  #298
dbittle's Avatar
So the gasket has a feature to capture the cowl? I have been trying to figure out how that worked.
Old Jan 14, 2021 | 07:04 PM
  #299
Dr Phat's Avatar
Yup! My body shop guy was worried once he got the glass out since the clips that support the trim also support he cowl so we talked about just building up some RTV behind the cowl, but we all figured out the rubber trim it all
worked out perfectly.
Old Jan 15, 2021 | 12:40 AM
  #300
SomedayJ's Avatar
That looks perfect! What truck do you have?
