Another 88 rebuild/questions thread (in Hawaii)
Old Apr 4, 2010 | 04:21 PM
  #241
92 TOY's Avatar
the only thing i can think of is some grease and a long / thick screwdriver to put in the holes and work them into place...other than that i'm gonna play it as i go along.
Old Apr 4, 2010 | 04:32 PM
  #242
rogerman's Avatar
what is screwing me up right now is the bushing thing that sticks out of the diff. I cant get the crossmember on without it hitting the bushing.
Old Apr 4, 2010 | 05:41 PM
  #243
92 TOY's Avatar
the thing that sticks out that has the one bolt going horizontally?
Old Apr 4, 2010 | 06:17 PM
  #244
stepside trd's Avatar
post some pict's, and we'll try and walk you through it as best we can. Snap a front, back, side to side, so folks on here can chime in on where the prob. is. Generally you want to keep every thing loose and in place before you tighten every thing up(cross mem. mnts, diff mnts, etc...).
Old Apr 4, 2010 | 06:19 PM
  #245
92, what exactly do you plan to do to your ride??......
Old Apr 4, 2010 | 08:48 PM
  #246
Philbert's Avatar
Roger, I haven't done the diff drop (I had a 4" IFS lift installed so I have the room for my oil pan), but if you're trying to cram something into a tight space, and line up some bolt holes on BOTH items, here's a tip I learned:
Use 2x4s or a large rubber mallet (or both) to wedge the one piece in between the other and adjust as close as possible to get some of the holes starting to line up.
Once you have some "daylight" in between at least one pair of matched holes, get a punch and a hammer - get the narrow end of the punch into the hole and start gently tapping...the 2 holes will slowly line up (the further the punch goes into the hole, the wider the punch amount inside the holes, and the more the 2 holes will line up.
I used this when doing control arm bushings on my Datsun - was a very tight fit, especially with new poly bushings - this worked great.
Hope this helps!
Old Apr 5, 2010 | 01:33 AM
  #247
92 TOY's Avatar
drive it...sell my sweeet cadillac and use the money to fix up my son's 88 4runner.
  #248
rogerman's Avatar
I'm gonna try it out either tomorrow afternoon or wednesday. I need to figure out what is giving me the code 51 and 52. Maybe the knock sensor I got is for the wrong year? I also have to figure out my vaccum line problem, and lastly get a down pipe bolt (my truck sounds like a diesel)Dad is coming this weekend so the gas is on.
Old Apr 5, 2010 | 04:07 PM
  #249
rog, support your diff. with your jack, LOOSEN the remaining two bolts that hold up your diff.(one will be located near your pinnion, the other is located on the drivers side, just under your motor mount.). The two bolts are either 15 or 17mm(might even be 19mm, can't rem.), and go up through the bushing (vertically, same kind of looking bush as on the diff cover). With your jack, move your diff. away enough to put the cross member on. Insert the four nuts and bolts to your cross, and just finger tighten to hold it in place. Use your jack to maneuver your diff. back into the cross member mount, insert bolt. Tighten cross member nuts and bolts to spec. torque and then tighten diff mount bolts (3 of them, 2-vert.,1-horiz.) to spec. torque.
Old Apr 5, 2010 | 04:11 PM
  #250
92, what I meant was, ru gonna do a head job, timing chain replace, full on frame off resto., rebuild motor,SAS,?????
Old Apr 5, 2010 | 04:23 PM
  #251
92 TOY's Avatar
i'm there dude...check out my thread in my sig....putting it all back together now.
Old Apr 5, 2010 | 04:57 PM
  #252
rogerman's Avatar
stepside that's another brilliant idea. You gotta post more prim!
Old Apr 6, 2010 | 09:04 AM
  #253
92, forgive me for not reading your thread. You have, like 71-72 pages, dude, I just don't have that kind of time! I did manage to read pg. 1 and the last pg., looks like you did alright. Are you still in the process of putting it together? How far along are u and what(if any) problems ru encountering??
Old Apr 6, 2010 | 09:18 AM
  #254
Lumpy's Avatar
Come on Stepside don't be a girl sit down with beer and a box of tissues and give it a read. You'll laugh you'll cry you'll wonder WTH was he thinking and WTH are they telling him to do.
  #255
Rog., I just try to help where I can. I try not to give too much help as that can lead to potential danger. If you give some one advice and they don't follow it to a "T" (and chances are they don't!!), they will hunt you down and blame you for more damage to their rig! It's also hard to diagnose problems with out physically hearing, seeing, touching the rig. I get a lot of phone calls at my shops from potential cust. asking why their veh. is making a weird sound, then they go into making weird noises over the phone......
Old Apr 6, 2010 | 09:21 AM
  #256
lumpy, I do that already watching my neighbors working on their rides.......
Old Apr 6, 2010 | 09:22 AM
  #257
Lumpy's Avatar
I'd tell them that cars don't make noises like that and have them try again...
  #258
I keep my phone next to my cooler w/ 911 on speed dial........
Old Apr 6, 2010 | 10:53 AM
  #259
rogerman's Avatar
here are the pre pictures of the vacuum lines I'm having a hard time getting connected
- I'm looking for the lines that go to the Red and Blue VSVs
- There are a couple on this side that I'm confused with. I plugged one vacuum line which was bigger than the rest (thicker tube, larger diameter) into what I thought was right but it has a lot of extra line to it. Make me think that it's the wrong place to plug it. I'll get more detailed photos after class today.
Old Apr 6, 2010 | 04:19 PM
  #260
92 TOY's Avatar
did you ever get the pan on and the diff back on?? did i miss that part?
