Project daily driver 85 4runner
Old Mar 19, 2020 | 05:04 PM
  #201
Damion812's Avatar
5 Year Member
Originally Posted by 2ToyGuy
Is that the nest of a gigantic mouse, or a gigantic nest of a normal sized mouse?
One of those is really scary!
Sorry, I couldn't resist...
Pat☺
oh I never did consider the size of that mouse! I saw something run through the back yard the other night.. thought it was was the naked naighbore but could of been that giant mouse........
Old Mar 20, 2020 | 11:34 AM
  #202
2ToyGuy's Avatar
Well, there ya go! You can't be too careful with those giant mice. If you see your cat running for the hills, go getcher gun!
By the bye, does you neighbor run naked through your yard often? If she's pretty, no problem, if HE looks anything like me , well, you know what you must do
That's a great looking engine, too. Now, keep it that way
Pat☺
Old Mar 20, 2020 | 03:33 PM
  #203
Damion812's Avatar
5 Year Member
I figured I'd try the daily driver thing to work with it myself till all this blows over. The town is shutting down and I may not be considered essential personal as of now. So I drove two days in a row!
Old Mar 20, 2020 | 03:36 PM
  #204
Damion812's Avatar
5 Year Member
Pat☺
your close she does look like a he and there was that one time she just dropped her pants to piss in the backyard but she may be living somewhere different these days since a run in with the law for a whole other deal. Can't make this stuff up😃
Old Mar 21, 2020 | 04:57 PM
  #205
Damion812's Avatar
5 Year Member
Oh yeah forgot to add this to my previous post about rebuilding the power steering pump. Great information here.
https://www.yotatech.com/forums/f116...g-pump-250677/
Old Mar 24, 2020 | 09:10 AM
  #206
Damion812's Avatar
5 Year Member
all the remaining vacuum hoses have now been switched to silicone plus I replaced the fuel hose from the charcoal canister going to tank with new ethonal resistant fuel hose. The only thing I have had for issues with the silicone is any place it may rub it wears through easily. I'll keep an eye on that.
Old Mar 24, 2020 | 11:33 PM
  #207
RAD4Runner's Avatar
all the remaining vacuum hoses have now been switched to silicone ...
Damion, do you remember total length of each size hoses you used? I'd like to replace mine, too.
Old Mar 25, 2020 | 04:41 AM
  #208
Damion812's Avatar
5 Year Member
I got the kit from LC Engineering and just cut to fit each one as I went. The power steering pump air hoses and PVC hoses are from 22RE performance.
and I'm wrong two hoses remain. The IAC valve hoses are still old. 76 bucks for them. I'm thinking about some other way for that.
Old Mar 25, 2020 | 01:01 PM
  #209
Damion812's Avatar
5 Year Member
Better than me measuring here the actual measurements that came with the kit 8 mm 1', 6 mm 4', 3 mm 12'. Or part #1 072442 from LCE .
Old Mar 25, 2020 | 03:26 PM
  #210
RAD4Runner's Avatar
Sweet. Tnx! I see cracks on some of my hoses that I merely pushed farther into the rigid tubes so they don't leak.
Old Mar 25, 2020 | 05:59 PM
  #211
Damion812's Avatar
5 Year Member
That's how it's done! I did that also. The vacuum hose on the EGR valve was becoming an issue though. I wasn't sure if I was going to be able to do that one but it was doable.
Old Mar 26, 2020 | 08:11 AM
  #212
Damion812's Avatar
5 Year Member
Latest score on e bay. For slightly more than the rebuild kit on the drag link I've got the complete OEM drag link. I'm guessing the original is not going to come apart on the hub side. It's fairly rusted together. I'll still attempt to free it up though but no worries now.
Old Mar 27, 2020 | 12:03 PM
  #213
Damion812's Avatar
5 Year Member
Yup the original drag link was a loss the end on the hub side had to be cut off . It had no grease in it and was rusted together. I'm glad I went with this.
Old Mar 27, 2020 | 01:25 PM
  #214
Melrose 4r's Avatar
5 Year Member
I remember what an improvement rebuilding the drag link on my 1984 4Runner was. It will be great! Nice score!
Old Mar 29, 2020 | 11:59 AM
  #215
cabot's Avatar
It makes a huge difference getting the steering sorted out, huh...
Old Mar 29, 2020 | 12:08 PM
  #216
Damion812's Avatar
5 Year Member
Actually the steering was already good but that end of the drag link on the hub\ carrier was going to become an issue fast. No grease was going into it and the rubber boot was split letting water in for who knows how long. Even after cutting the drag link apart the inner cup is still rusted to it.
Old Mar 30, 2020 | 10:29 AM
  #217
Damion812's Avatar
5 Year Member
a couple more improvements. I was working on fixing and repainting the 4runner side badges but they are in bad shape and didn't really come out too well. So I just slapped some decals on the spots for now. The 4 speed shift knob is from my first Toyota truck and first new vehicle 1990 2WD. The original shift knob was missing the label like so many and this one was basically new since I switched to a T handle with in a month of owning that truck . It's just kinda nostalgic 😂
Old Mar 30, 2020 | 02:08 PM
  #218
Melrose 4r's Avatar
5 Year Member
Side badges look good!
interesting that your console does not have the “window lock” button between the wiper and rear window control.
Old Mar 30, 2020 | 04:38 PM
  #219
Damion812's Avatar
5 Year Member
yeah, that switch must of come later. How about the symbol that looks like a guy standing next to a UFO?
Old Apr 7, 2020 | 12:30 PM
  #220
Damion812's Avatar
5 Year Member
the top is off! For now anyway. I needed to set up my portable garage to do some work on it so figured I would see what it looks like without the top again.
