Project daily driver 85 4runner
Old Apr 7, 2020 | 01:32 PM
  #221
5 Fists's Avatar
I love the decals on the doors! That is just awesome.
Old Apr 8, 2020 | 01:37 PM
  #222
Damion812's Avatar
5 Year Member
They came with the truck and are in real nice shape. The original doors aren't that bad either but are now part of the rear quarter panels.
Old Apr 14, 2020 | 11:51 AM
  #223
Damion812's Avatar
5 Year Member
it pays to know the less popular hiking trails these days.
Old Apr 15, 2020 | 11:59 AM
  #224
Damion812's Avatar
5 Year Member
I finally fixed the spare tire winder. Much better than the bolted up tire it was before with threaded rod and a ratchet strap. This spare that I've held on to for a back up spare would just be used in a dire emergency like to get off the highway or something since it is such a big difference in size. Also it's really there to keep the driver behind us from going too far under us in an accident. It bailed me out in the woods of Maine one time when we were 10 miles away from the nearest town. I Was already using my spare due to a flat a few days earlier when a rock shaped like an arrow went through another tire. Beats walking 😃
Old Apr 19, 2020 | 09:18 AM
  #225
Damion812's Avatar
5 Year Member
I just got around to adding a warning buzzer for the lights, I don't know why I waited so long. It's so easy. Thanks to RAD4Runner for the excellent right up!
Thanks, Terrys87!
I'm concerned about leaving my lights on and draining the battery. Per FSM, the light reminder relay is supposed to be here, but I only see a mounting hole on mine, confirming my suspicion that the light reminder circuit was only available on SR5 first-gens. Therefore, one lazy afternoon, I got busy
The circuit is simple. It will energize when there is positive voltage from the tail light circuit AND ground via the the driver side door courtesy switch when door is opened. (When headlights are on, there is also power to tail light circuit.)
Parts & Equipment Needed:
  • Buzzer PN 273-059 from Radioshack. I used an overhand knot and ran lead wire through mounting hole for strain relief. Also affixed foam-backed double-sided tape for mounting.
  • LED indicator light. (I used an LED lying around in my toolbox and appropriate resistor.) Easier to simply buy pre-assembled indicator LED light (i.e., from O'Reilly)
  • AWG 20 wire,
  • Heat Shrink
  • Other basic electrical assembly tools & supply
Schematic is here:
Attachment 191726
POSITIVE side will be tapped into tail light circuit between the tail light relay and the 15-amp tail fuse here:
Attachment 191727
GROUND side will be connected to the door courtesy switch ( provides ground when door is opened) here:
Attachment 191728
Assembled circuit is shown here:
Attachment 191729
To Install:
Remove Left hand dash panel that covers the instrument panel and holds the Clutch Safety Cancel switch.
Attachment 191730
Attachment 191731
Wher to get positive 12V power
Remove left-hand kick panel
Attachment 191732
Remove Tail Fuse (15A). Verify that left terminal (marked below) is the supply side by measuring +12V when tail light switch is in ON position, 0 volt when tail light switch is OFF. It is important that you connect to supply side of fuse so that IF headlight is on and even if tail fuse is blown, this will still power the reminder circuit.
NOTE: The cleaner method would be to solder it into the circuit in the back of the fuse block, which I would do later.
Slip red wire into supply side, and re-install fuse. Be careful that you do not cut strands that might fall on other circuits and cause shorts.
Attachment 191733
An option is to take positive voltage from this green wire (the section in yellow heat-shrink) that once supplied stock deck lamp circuit, but I disconnected in order to do my deck lamp retrofit. Verify that this green wire has 12V when, and only when, tail light is on.
Strip door courtesy switch wire at a convenient spot and connect ground side of circuit to that. Soldering then insulating with heat-shrink tubing or electrical tape is recommended.
Attachment 191734
Here's the circuit connected and properly labeled. Buzzer is stuck on fuse block with foam-backed tape. [Let us keep our wiring and and mods clean & properly documented to make it easy to troubleshoot or return to stock when needed/desired. This way our classic rigs can be considered improved, not molested. ]
Attachment 191735
Route LED next to clutch safety cancel switch:
Attachment 191736
Drill hole and install LED indicator or LED bezel, as applicable, next to clutch safety cancel switch opening.
Attachment 191737
Attachment 191738
Here is the LED mounted and lit when tested:
Attachment 191739
Video of Test here.
Old Apr 22, 2020 | 10:38 AM
  #226
Damion812's Avatar
5 Year Member
been cleaning up some electical connections and decided to fix the AC compressor plug on the wiring harness. Somebody replaced it with a regular spade and I used an appropriate one that was part of a wiring harness from a tailgate that I picked up a while ago for a good price. I was able to unpin the connector and solder it to the wiring harness on the 4runner and put it back together.
as for the tailgate though it's a rusty mess but the window motor works well , the glass is better than our current back window plus it is a defroster window and I was able to scavenge some useful hardware. Also it's from a SR 5 so now we can have a SR5 lol.
Old Apr 22, 2020 | 05:35 PM
  #227
Damion812's Avatar
5 Year Member
Old Apr 26, 2020 | 04:24 PM
  #228
Damion812's Avatar
5 Year Member
It's getting harder every week to get away from people so we can social distance hike properly 😁 Next trip will involve 4 Wheel low. These pictures are from a less popular local place to hike and the photo through the windshield is a state road. Very few roads like that around us these days but when I was a kid and in my early teens there were places to go wheeling. Of course then I didn't have 4 wheel drive but it didn't stop us.
Old May 12, 2020 | 02:14 PM
  #229
Damion812's Avatar
5 Year Member
some cool shots from another outdoor outing and some light 4 by 4 action.
Old May 14, 2020 | 03:20 PM
  #230
Damion812's Avatar
5 Year Member
just for fun shot.
Old May 17, 2020 | 05:10 AM
  #231
Damion812's Avatar
5 Year Member
Yesterday we went out searching for a more out of the way hiking locations in Tunxis State Forrest (CT) but it was just too popular out that way. This did end up to be a real good shake down run test for the 4runner since the engine rebuild. Lots of big hills to put it through the paces and the absolute farthest we have taken it.
I also decided to do a tire rotation when we got back. I don't know if I've ever rotated them before. And here is a shot of the spare tire for the FJ Cruiser on if anyone was woundering if the wheels fit. Somewhere I read that the centers were too small for the hub. I didn't think that was true. It fit.
Old May 18, 2020 | 04:52 PM
  #232
Damion812's Avatar
5 Year Member
I finnely got the duel horns installed and rewired the original horn for a toggle switch.
I found a relay plug I had from a Jeep Cherokee I used to own.
I still have some cleaning up the wiring to do yet but now have 3 functioning horns.
Old May 19, 2020 | 09:24 AM
  #233
RAD4Runner's Avatar
Nice to have so much room under that bumper!
AND lovely trip pics!
Old May 22, 2020 | 10:58 AM
  #234
Damion812's Avatar
5 Year Member
That bumper is one of the the things that caught my eye on this project! The best part of these trips is riding in the back with the top off ( not mine that's creepy ) it's as much fun as driving except I get to see more of the sceanerie. But I didn't figure in the tree branches hitting me in head when off road.
oh also found out the transfer case output seal isn't leaking since the replacement I over filled the gear oil. It seems like I do that all the time. It was cold when filling plus it's kinda hard to see in there, not as bad as the transmission though.
Old May 22, 2020 | 04:18 PM
  #235
Damion812's Avatar
5 Year Member
New fuel injectors in and tested. I know I should have done this when rebuilding the engine but it wasn't a bad job to go back and take care of buisnes.
Old May 23, 2020 | 12:20 PM
  #236
2ToyGuy's Avatar
Do you fill it through the top, where the shift levers are, or through the side, where the actual fill plug is? Drivers side, about 1/2 to 3/4 of the way up. Both the trans and transfer case have that set up. I think the bolt is a 22 or 24MM head. They're recessed into the case, with a circle of metal surrounding them.
I have a little, cheapie pump, that screws onto the top of the 1 GAL oil containers. It has a pretty long hose, plenty long enough to reach from the side of the truck to the fill plugs. You can sit on the side of the truck and fill 'er up!
It has a little device to hold it in the hole, and the actual pumping mechanism is on top of the oil container. You just plug it into the fill hole and pump the handle, until oil JUST starts to show up in the fill hole. Once it does, pull the hose out, put the bolt back in, and you're golden. Just the right amount of oil in the two locations. A small amount may leak out the fill hole until you get the bolt back in, but that's much better than the alternative. I believe the bolts have crush washers on them to seal things up, but I've only replaced mine once. They just don't leak, even a previously used crush washer, so I just never bothered replacing them. If it takes more than a gallon, and it will, just pump the first one dry, and swap the pump over to the next one.
Great way to prevent overfilling.
Just wanted to drop my 2 cents in...
Pat☺
Last edited by 2ToyGuy; May 23, 2020 at 12:26 PM. Reason: Forgot a point or two...
Old May 24, 2020 | 08:29 AM
  #237
Damion812's Avatar
5 Year Member
with all that's going on lately I haven't been getting shots of everyday life as a daily driver. Here it is getting the garden. The seat folded forward is a nice holder!
Old May 24, 2020 | 08:33 AM
  #238
Damion812's Avatar
5 Year Member
Pat☺
sounds good! I started the refill from the top when the shifters were off but not all. I topped off from the fill plug. Yeah them crush washers last a long time. The problem I run into is it may not have been sitting level at the time and the hose moved when pumping the oil in stopping it from coming out once it was full.
Old May 25, 2020 | 10:45 AM
  #239
2ToyGuy's Avatar
Yeah, that'll do it!
Well, all you can do is try to get it level, both front-back AND side-side. That will prevent the over-fill problem.
Alternatively, I guess you could drive it someplace that IS relatively level, and pull out the fill plugs. Pollute someone's parking lot with the excess
Good luck, however you do it
Pat☺
Old May 26, 2020 | 03:10 PM
  #240
Damion812's Avatar
5 Year Member
more fun in the sun. Lots of off roading back and forth looking for a good spot to take my son frogging . The main road in is getting smaller every time we go out there. It's getting grown over and I don't think many people know about the road these days.
