Pre 84 Trucks 1st gen pickups
flywheel-removal tips?
Old May 7, 2011 | 07:26 AM
west_89_'s Avatar
hey i am rebuilding my 22r and i need to take off the flywheel. i have been trying for the last hour and a half to take it off but the bolts are on prity good is there any easy way to get the bolts off?
thanks.
Old May 7, 2011 | 08:52 AM
drokliss's Avatar
lots of grunting and straining
I've heard a heat gun helps, but I wouldn't do that...they're on with about 80 ft lbs...
Old May 7, 2011 | 09:05 AM
west_89_'s Avatar
thanks man! your right! it also seemed to help to tap the heads of the bolts with a hammer. (for future reffrence)
Old May 7, 2011 | 09:07 AM
xxxtreme22r's Avatar
when you put them back on make sure you use locktite as well. Not only are they 80 ft-lb but they are loctited from the factory which makes them that much harder to take off. Same thing with the crank bolt.
Old May 7, 2011 | 09:21 AM
west_89_'s Avatar
ok will do. Now is that a brand or the product. if so what brand do you recomend?
Old May 7, 2011 | 04:10 PM
slacker's Avatar
locktite - blue
namebrand
Old May 7, 2011 | 05:26 PM
west_89_'s Avatar
Cheers!
Old May 7, 2011 | 05:51 PM
corax's Avatar
DON'T use the red Loc-Tite - you won't get them off without a torch next time if you do
JonG85
Jan 18, 2023 04:31 PM
Zach_trun
Jan 22, 2020 04:42 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Yont283
Sep 12, 2015 10:03 AM
