4R first gen temp gauge doesn't work
Old Feb 28, 2018 | 12:49 AM
SomedayJ's Avatar
Hi guys!
The temp gauge of my Toyota 4Runner first gen (1988 SR5 22RE, no airco, manual trans) doesn't work.
I'm following this sticky thread:
https://www.yotatech.com/forums/f116...ge-fix-271152/
and this recent one:
https://www.yotatech.com/forums/f116...sender-303548/
but they're solutions if the gauge sometimes works, in my case that gauge doesn't move at all.
Anyway, before dismounting the dashboard, I'd like to check the temp gauge sender, the problem is, and this is the shame part, I don't know where it is.
RAD4Runner's 4R has it in the thermostat housing:
https://www.yotatech.com/forums/f199...l#post52391719
but it's not in my 4R. I think, in my case, it's the one inside the red circle (please see pic attached), is that correct?
The pigtail's blue and the wire's yellow with green stripes, like the one the temp gauge receives (see red arrow in the electric schematic attached).
Thank you!
Attached Thumbnails 4R first gen temp gauge doesn't work-t.jpg   4R first gen temp gauge doesn't work-tr.jpg   4R first gen temp gauge doesn't work-ts.jpg   4R first gen temp gauge doesn't work-s.jpg   4R first gen temp gauge doesn't work-es.jpg
Old Feb 28, 2018 | 08:42 AM
RAD4Runner's Avatar
Here's to test the "gage" half of the system:
Originally Posted by 881stgen
Picked up a 3.4w bulb and hooked it up per the manual and the needle went right to normal and the light lit up. The manual says if results aren't as expected then test the actual gauge but since they are as expected I guess my next step is to pull the sensor, clean it and test it. I was getting a false reading before when I tested the resistance. I made sure I got a good connection and each time it gave me different readings. Usually in the 40-75 ohm range. I'll report back when I get it cleaned and tested and I will clean the threads as well.
The sender on top of T-stat housing is the Coolant Thermo Switch (TSW for ECU), not the temp gage sender. The temp gage sender is the one on your photo...
(THANKS FOR THIS PHOTO! I could not even find sender on mine)
Coolant Temp GAGE sender.
Here's the test for the sender. It only have one wire connected to it so needs clean, bare, metal contact with the block.
Old Feb 28, 2018 | 08:43 AM
Co_94_PU's Avatar
Dash gauge temperature sender is located below cold start in the middle of the lower intake, what you see in RAD's photo is a temp switch.
Old Feb 28, 2018 | 08:45 AM
RAD4Runner's Avatar
Originally Posted by Co_94_PU
Dash gauge temperature sender is located below cold start in the middle of the lower intake...
Yes, this...
https://cimg6.ibsrv.net/gimg/www.yot...33ee8646cb.jpg
Old Mar 1, 2018 | 12:40 AM
SomedayJ's Avatar
I'm going to test that gauge water temp sender, and I'll report back.
Thanks a lot for your help, guys.
Old Mar 25, 2018 | 04:37 AM
SomedayJ's Avatar
It works!
Hi guys!
I wanted to update this thread. It works now.
I removed and cleaned the gauge water temp sender. In fact I cleaned the other two senders also like in this 22RE Performance video:
After that I flushed the cooling system, I replace the thermostat. I put everything back together. I blocked the rear wheels and I jacked up the front wheels to be sure the top of the radiator was the highest part of the c.system. I slowly filled with Toyota red coolant. After 25 minutes with the engine running waiting to purge, the temperature gauge needle went up a quarter. Happy with the progress, but I expected to go a little bit higher. Is that good?
Attached Thumbnails 4R first gen temp gauge doesn't work-20180325_135557.jpg
Old Mar 25, 2018 | 06:05 AM
SomedayJ's Avatar
Update:
I think the engine was not warm enough.
After running the engine for other 30 minutes to purge the cooling system, the needle went up a little bit more. It looks good now.
Attached Thumbnails 4R first gen temp gauge doesn't work-20180325_155354.jpg
Old Mar 25, 2018 | 09:56 AM
RAD4Runner's Avatar
Awesome! Thanks for the update. The temp gage normally sits below the halfway point. It's never exact. It just indicates:
1) Cold,
2) 1/3 of the way = Normal op. temp
4) 1/2 of the way = Working harder than usual
5) About 3/4 of the way = Do something about it (turn AC off, slow down if going uphill, turn heater on, check radiator/fan, etc.)
6) Red mark = overheat, stop, check everything.
An electrical sender with digital read-out would be nice.
starko357
Nov 20, 2013 09:43 AM
Yotalover01
Feb 19, 2013 11:24 AM
Brandon87
Dec 29, 2012 10:50 AM
woodi
Sep 25, 2009 06:36 PM
Tylerars24
Aug 10, 2007 06:19 AM
