General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Oild temp gauge Fuel Gauge Issue
Old Aug 8, 2007 | 09:56 AM
Tylerars24's Avatar
Hi everyone,
I just picked up my first toyota and I'm having a couple issues.
I've searched with out much luck.
The vehicle is a 1988 toyota pick up SR5 ext. cab
The fuel gauge and Oil temp gauges are both giving not reading, as if the vehicle is turned off. I'm not sure where to start. Are there localized fuses to the gauges?
Thanks
Tyler
Old Aug 9, 2007 | 04:12 PM
Tylerars24's Avatar
Ok,
When I leave the key in the position before I engage the starter while the motor isn't running, the needle on the oil press. gauge goes up to ~3/4 of the way to the top. When I start the motor the needle slowly drops back down to the bottom.
Any one got any tests for this?
As far as the fuel gauge goes, I'm starting to think I have to drop the tank to check the sending unit.
Anyone have some tests for the sending unit/gauge circuit?
Thanks
Old Aug 10, 2007 | 06:19 AM
ewong's Avatar
FSM..
Oil Pressure sender is near the oil filter assuming 22RE 4cly engine
Fuel Tank SENDER is in the tank and yes you ahve to drop the tank
OR
Remove/lift the bed...
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
