sloppy locker
sloppy locker
I have a 94' 4 runner auto trans v6.I had a powertrax locker installed in the rear and it seemed kind of sloppy.When you put it into gear I hear a big klunk.We pulled the 3rd to check to see if it had loosened up but it's seems tight.Tranny ,t/c , r/p and splines are good(no bluing or shavings) so ,I'm thinking the springs in the locker are'nt holding tight enough,any suggestions?
Sound to me as your backlash isn't set correctly. Have you checked and rechecked it?
locker
There no wear patterns on the gears or locker.After numerous phone calls , re-pulling and checking everything else,I'm gonna have to go with "superjoe83" and"phorunninduke".I drove this to Co.and Wyo.with 800lbs of gear,spent 2 1/2wks 4wheeling with no trouble.I guess the truth will be told when I tow a trailer loaded.Again,thanks for all the input.
live277--- I think that clunk you have is normal......my old 1999 TJ with auto with SoftLocker /456 gears did the same clunk.
Most recently, my 87 Runner 22RE/auto/571/Detroit SoftLocker does the same BIG clunk.....even chirps the tires sometimes putting it in gear at idle. You might try turning the idle down.
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
