Do I need a panhard drop bracket?
Old Sep 20, 2005 | 02:29 PM
Dr.Feelgood's Avatar
I have a 2" BL. I have a set of Daystar 1.5" spacers for the rear, but not on yet. Is that 1.5" enough to facilitate a panhard drop, or do I not need one? As of yet there is no lift on the front. I'd just like to know before I put these spacers on. Truck is in the sig. Thanks.
Old Sep 20, 2005 | 02:40 PM
Tofer's Avatar
Sponsor
1.5" isnt enough lift to need a panhard drop. you only need it when you go 3"+ i have LC coils and still havnt had the time to build/buy one and havent had a problem yet, but its on my to do list
Old Sep 20, 2005 | 04:56 PM
benthere25's Avatar
what does that bar even do....i've never understood
Old Sep 20, 2005 | 05:13 PM
4Crawler's Avatar
Panhard bar is a locating link on the rear suspension, goes from the frame rail to the axle. Should be roughly hozontal to work best. Lift the truck, the panhard bar takes on an angle. Being a fixed length, at the angle it is at when lifted, it pulls the axle to the passenger side of the vehicle. Let the axle droop and it'll pull the axle farther over, to the point that the rear driveshaft hits the gas tank. So the drop bracket does just that, drops one end of the panhard bar to restore it to the stock horizontal orientation so that it works properly.
Old Sep 21, 2005 | 03:48 AM
Thanks Chris. Just wanted to make sure before installing them. Roger always gives great explanations, doesn't he?!
Old Sep 21, 2005 | 07:53 AM
benthere25's Avatar
thank you roger......can you custom make a diff drop spacer for a 91 2nd gen 4runner.....v6 for the front....i got your ball joint spacer andturned my tbars way up....
Old Sep 21, 2005 | 07:54 AM
benthere25's Avatar
who provide a good drop bracket for that pan hard for a 2nd gen runner
Old Sep 21, 2005 | 08:08 AM
4Crawler's Avatar
You bet:
- http://www.4crawler.com/4x4/ForSale/...shtml#Ordering
I think Downey makes a panhard drop brkt. for the 2nd gens.
Old Sep 21, 2005 | 03:17 PM
4rnr's Avatar
cut the panhard bar and intall a piece of tubing with the same id as the pan hard bars od. locate it and weld it. Wow I just realized how much i am going to love it when I switch to leafs.
Old Sep 21, 2005 | 06:53 PM
RLJ3RD's Avatar
Call Summit Racing (1-800-230-3030), ask for Arnold. Ask him for a Explorer Pro Comp Panhard drop bracket for your 4runner. They do not list it in their catalog or website so you have to call. I called and they called Pro Comp while I was on the phone, BAM! $35.99, $44.94 drop shipped from Pro Comp to my door. Part Number is EXP-90-1268. Very excellent item and very good price.
Old Sep 21, 2005 | 07:16 PM
Tofer's Avatar
Sponsor
ditto
Old Sep 22, 2005 | 07:34 AM
benthere25's Avatar
thanks rlj3rd.....our rigs are almost the same....i on it with the panhad drop from pro comp...and i'll be getting to you roger about the diff drop spacers.....is it really nessary to lower the sway bar also....it seems ok....well those t bars are going to the sky this weekend so i guess i need to change them
Old Sep 22, 2005 | 07:40 AM
4Crawler's Avatar
On the sway bars, you need to check clearance under the front driveshaft for the sway bar. As you can see in the image below, the clearance is pretty tight even with the bar dropped to match the diff drop amount. If you have enough clearance, then you may not need them.
As a side benefit, your sway bar will work better lowered, it'll help counter the effects of the lift changing the angles of the ends of the bar. Ideally you want them to be horizontal for most efficient operation.
Old Sep 22, 2005 | 09:11 AM
benthere25's Avatar
if i want this i need to get your diff drop spacer witch i have the link to and sway bar drop, and extened sway links....next week i will make the order for all....i kind of want quick disconnects....a friend of mine told me about tk sliders....he said they are great....any refference for sway link disconnects thats are extended.....i dont mine the price due to cheep stuff creates a domino effect on all parts
Old Sep 22, 2005 | 09:26 AM
4Crawler's Avatar
Here is a link to some sway bar quick disconnect info. If running the stock sway bar location, you'll want to measure for and get the disconnects longer that stock to make up for the lift:
http://www.4crawler.com/4x4/CheapTri...#DisconnectsV2
pplusent
Sep 2, 2015 11:56 PM
Duppie007
Aug 20, 2015 04:39 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
Motomonty
Aug 9, 2015 05:53 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
