sloppy locker
Old Sep 19, 2005 | 08:13 AM
live277's Avatar
sloppy locker
I have a 94' 4 runner auto trans v6.I had a powertrax locker installed in the rear and it seemed kind of sloppy.When you put it into gear I hear a big klunk.We pulled the 3rd to check to see if it had loosened up but it's seems tight.Tranny ,t/c , r/p and splines are good(no bluing or shavings) so ,I'm thinking the springs in the locker are'nt holding tight enough,any suggestions?
Old Sep 19, 2005 | 08:18 AM
SloPoke's Avatar
Sound to me as your backlash isn't set correctly. Have you checked and rechecked it?
Old Sep 19, 2005 | 12:56 PM
live277's Avatar
sloppy locker
I should have mentioned that I put about 4k miles on it.If it is the backlash then I'll have to wait until I get out west,cause no one does it around here.
Thanks
Old Sep 19, 2005 | 03:19 PM
superjoe83's Avatar
if you have a lockrite, thats normal, there is allot of clearance between the cross pin and the locker
Old Sep 20, 2005 | 04:33 PM
straightaxle85's Avatar
either backlash or locker itself
Old Sep 20, 2005 | 04:53 PM
Ironmike4x4's Avatar
Try a wear pattern check on it and see if the gears are meshing right.
Old Sep 20, 2005 | 07:45 PM
phorunninduke's Avatar
As nerve rattling as it is, it is pretty normal for a locker to klunck alot. I can not speak for powertrax specifically, but those types of lockers are usually noisy.
Old Sep 22, 2005 | 12:40 AM
live277's Avatar
locker
There no wear patterns on the gears or locker.After numerous phone calls , re-pulling and checking everything else,I'm gonna have to go with "superjoe83" and"phorunninduke".I drove this to Co.and Wyo.with 800lbs of gear,spent 2 1/2wks 4wheeling with no trouble.I guess the truth will be told when I tow a trailer loaded.Again,thanks for all the input.
Old Sep 22, 2005 | 05:57 AM
ZUK's Avatar
ZUK
live277--- I think that clunk you have is normal......my old 1999 TJ with auto with SoftLocker /456 gears did the same clunk.
Most recently, my 87 Runner 22RE/auto/571/Detroit SoftLocker does the same BIG clunk.....even chirps the tires sometimes putting it in gear at idle. You might try turning the idle down.
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
